12-20-2013, 10:24 AM | #127 | |
Drives: Toyota GT86
We do not support using ProECU with any type of virtualisation software due to timing issues that may or may not cause timing issues on various laptops - when programming your ECU, you really don't want to have comms issues! With Bootcamp on Mac, you get all the benefits of the Mac hardware running Windows. It does however mean you need a copy of Windows for your Mac. Last edited by EcuTek; 12-22-2013 at 08:27 AM. |
The Following 3 Users Say Thank You to EcuTek For This Useful Post: |
12-20-2013, 12:25 PM | #128 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
And so, the first coming of ECUTek Retail Tuning Software came to pass. Enthusiasts everywhere rejoiced in its release, For this day will now be known to all as, ECUTekmas.
12-20-2013, 12:42 PM | #129 |
i got it. if the software is half as good as the documentation we're in for a treat. very good docs.
12-20-2013, 01:18 PM | #130 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Enjoy fellas, make sure to really dig into it and the instructions. Not something you want to miss. Lots of shortcuts and ways to navigate it that make it really easy too, mouse is mostly optional by the time you figure it out. |
12-20-2013, 02:49 PM | #131 |
Drives: UK GT86
It looks like you can edit all for map modes if they are already enabled on the .bin file from your tuner. I can certainly edit the fuelling, base and advance ignition for all 4 as well as enable the FFS, LC and auto-blip. What I do find odd is that while I can edit those, I can't chose which maps are enabled. The map in question has 3 selectable via CC but all 4 show in the editor. I guess to enable/disable the maps requires the full RaceROM functionality.
.: Stealth 86 :.
12-20-2013, 04:16 PM | #133 |
Drives: UK GT86
John, how sure are you about that?
I can certainly change values in the tables and save them I find it's the exact opposite. I can edit and save but have no way to select how many of the maps I want. FYI, this is 3 mode map provided to me by a tuner.
.: Stealth 86 :.
12-20-2013, 04:19 PM | #134 | |
The updated RaceRom code won't have everything you see but has updated code that's much better John |
12-20-2013, 04:23 PM | #135 |
Drives: 2013 White Out FR-S
If you dont have The PRO version of the Retail software you will not be able to use map switching.
12-20-2013, 04:28 PM | #136 | |
Drives: UK GT86
That's it I guess. I've just realised that I have no access to edit the auto-blip settings. Where are the base maps available from?
.: Stealth 86 :.
12-20-2013, 04:30 PM | #137 |
The software has the available roms store in the EcuTek directory.
12-20-2013, 04:30 PM | #138 |
The Following 2 Users Say Thank You to Visconti For This Useful Post: | EcuTek (01-14-2014), Kodename47 (12-20-2013) |
12-20-2013, 04:32 PM | #139 |
Drives: UK GT86
I hadn't run the update a 2nd time, cheers John!
.: Stealth 86 :.
12-20-2013, 04:34 PM | #140 |
No problem.
For those of you who want the map switching with different tunes... I'll be offering a inexpensive service where you send me the ignition and fueling maps and I'll put them all together in a Map switchable tune. I will also be offering a tune review service John |
Tags |
ecutek, edit, proecu, racerom, tuning |
Similar Threads | ||||
EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 09:17 AM |
So what ECUtek software do you need to make changes to the ECU yourself? | seven | Engine, Exhaust, Transmission | 30 | 01-04-2013 11:58 AM |
EcuTek's BRZ / FT86 / FR-S ProECU Software available for Pre-Order now | Visconti | Engine, Exhaust, Bolt-Ons | 7 | 07-27-2012 01:00 PM |
Toyota will announce the FT86 in Tokyo 2011 motor show? | ossme | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 12-05-2010 02:36 PM |
