Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-07-2016, 04:39 AM | #43 |
Drives: 86 GTS 2015
04-07-2016, 04:40 AM | #44 |
Drives: 86 GTS 2015
Probably, but I'm wondering what the new improved OFH sounds like with overpipe (in particular the overpipe which comes with OFH3) and stock everything else. Never seen a video of UEL headers + overpipe + stock everything else before.
The Following 2 Users Say Thank You to alchemy For This Useful Post: | NyC Zn6 (04-07-2016), shellslinger (04-13-2016) |
04-07-2016, 09:32 AM | #45 |
Drives: 2014 BRZ
From my research, it'll be a tick louder than without an over pipe. Just bear in mind that typically exhausts will sound pretty significantly different in person, but I'll try to get close by using a gopro with an external mic
The Following User Says Thank You to nastynate88 For This Useful Post: | Yoshoobaroo (04-12-2016) |
04-07-2016, 10:07 PM | #46 | |
Drives: 86 GTS 2015
Can't wait to hear it! |
04-12-2016, 08:26 PM | #47 | |
TRACKBREAD
Sent through a series of tubes |
04-13-2016, 08:23 AM | #48 |
Drives: 2014 BRZ
Still working out some kinks with the exhaust (AZP Installs is doing the work).
So far in the cabin, it's barely louder than stock. Power band is noticeably smoother, and the car pulls all the way up to redline without the dip. |
The Following 2 Users Say Thank You to nastynate88 For This Useful Post: | ST-A (04-13-2016), Yoshoobaroo (04-13-2016) |
04-19-2016, 09:32 AM | #49 |
Drives: frs
What kind of wait times are there for the Ofh3?
04-19-2016, 07:14 PM | #50 | |
Drives: 2013 Subaru BRZ Limited (Black)
You will be able to hear it outside of the car if you are behind, but no increase in cabin volume for the most part (at least no increase in nice noise... you do gain a bit of header-noise from the thin-wall headers). |
06-03-2016, 04:36 AM | #51 |
Drives: Frs
Can anyone tell me what is included in the OFT350, since SBD doesn't feel like replying to my emails? http://www.openflashtablet.com/shop/...-turbo-system/
I'm not sure if a sti pcv valve is even needed anymore or is included. |
06-03-2016, 01:43 PM | #52 |
Drives: Blue BRZ limited
Just got my ofh2 installed the other day.
Currently have Perrin catback 3" non res exhaust Boy did it open up that exhaust lol Looking into options for getting rid of drone and rasp Haven't drove much yet so not much to comment on there |
07-23-2016, 03:49 AM | #53 |
Drives: MY15 BRZ WRblue
Some folks asked for a OFH3 sound clip. Here you go:
[ame="https://www.youtube.com/watch?v=W1z9Rf9qMPg"]Subaru BRZ MY15 E85 OpenFlash Header 3 (OFH3) + stock front & mid-pipe & muffler sound sample - YouTube[/ame] |
07-23-2016, 07:29 AM | #54 |
Drives: 13 frs red
That sounds nice once warm. Catless makes these cars sound like sawmills during cold start.
08-25-2016, 10:41 AM | #55 |
Drives: Something fun.
OFH3 installed, sounds great and seems to perform awesome so far.
Currently running the OFT UEL 91 STG2 tune since I was not able to see anywhere if the OFH tune was safe for canadian 91, anyone knows? I'll be doing logs and reviewing them but before spending time on this i'm trying to see if anyone knows |
08-28-2016, 06:02 PM | #56 |
@Shiv@Openflash
What is the size of the header to overpipe clamp on the OFH3? I'm chasing an exhaust leak and will be replacing it with a wider/better clamp when I get it up the lift. |
Similar Threads | ||||
OFT350 (SBD/ZAGE) on E85 Dyno results | Shiv@Openflash | Forced Induction | 19 | 02-05-2016 12:00 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
TRD cat back, any dyno results | MTCRX | Engine, Exhaust, Transmission | 4 | 11-26-2012 06:26 PM |
