Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
Yes (Please only vote after you have 300 miles or more on the odometer) | 3,100 | 85.21% | |
No (Please only vote after you have 300 miles or more on the odometer) | 538 | 14.79% | |
Voters: 3638. You may not vote on this poll |
03-23-2015, 11:23 AM | #4621 |
Hail Magnet
Thank you for reading. Yes, it is. Grade of gas doesn't seem to matter, although ethanol may or may not be a factor. Ambient temperature may be a factor as well (it has been in my experience at least).
03-30-2015, 02:41 PM | #4622 |
Drives: Waiting for the ND Miata
Wow this thread is still going. Besides the noise has anyone have actual fuel pump failures? From reading the latest posts looks like this is still an on going issue.
03-30-2015, 02:44 PM | #4623 |
Hail Magnet
The Following 2 Users Say Thank You to HunterGreene For This Useful Post: | srizzors25 (04-29-2015), Tcoat (03-30-2015) |
03-30-2015, 03:08 PM | #4624 |
Drives: 2013 Subaru BRZ Limited in WRB
Apparently crickets are popping up on the new Lexus RC-F ...that should attract some attention from Toyota
http://www.clublexus.com/forums/rc-f...ing-noise.html
03-30-2015, 03:21 PM | #4625 | |
Junior Senior with Cheese
Drives: 15 BRZ
The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post: |
03-30-2015, 03:23 PM | #4626 | |
Hail Magnet
EDIT: I just read through the genesis of their thread. Its like taking a stroll down memory lane. They even have some people already confusing the fuel tank pump (low pressure) with the HPFP. |
03-31-2015, 02:09 PM | #4627 |
Daedalus Moto
I had another big fix I think this will make history
The Following User Says Thank You to srizzors25 For This Useful Post: | Tcoat (03-31-2015) |
03-31-2015, 02:16 PM | #4628 |
What works for me I guess (only had them 3 days one time)
The Following User Says Thank You to Tcoat For This Useful Post: | srizzors25 (03-31-2015) |
04-21-2015, 09:20 AM | #4629 |
Drives: raven black
I drive a FR-S 15 i use to put gas in 76 and shell but i stop and only pumping in shell v power after 3 or 4 tanks of v power i guess it flush the mixture of gasoline..and chirps went away...this weekend had to pump 76 and chirping sound came back so it figueres that shell v power is doing the trick for my..i always pump same gas station and same pump hope it helps...
04-21-2015, 09:27 AM | #4630 | |
Hail Magnet
The Following User Says Thank You to HunterGreene For This Useful Post: | Frishkorn (04-30-2015) |
04-25-2015, 07:25 PM | #4631 |
Drives: SWP BRZ Limited Manual. 2014
10,000 Miles, light squeak around the ABS/Drives side (USDM spec car).
So, should I worry about it? It sounds like a super common problem, read around some are saying it's the Direct Fuel Injector also?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
04-29-2015, 11:01 AM | #4632 |
Drives: 15frs 89volvo765&780
1800 miles and just noticed the crickets this morning. damn
The Following User Says Thank You to rucfj159 For This Useful Post: | Frishkorn (04-30-2015) |
04-29-2015, 11:02 AM | #4633 |
Hail Magnet
Welcome to the club. You'll get used to them.
04-29-2015, 11:04 AM | #4634 |
Drives: Asphalt FR-S MT
I got them after 300 miles. The only time I've not had them is when I'm running e85. 22k miles at the moment and still chirps on 91/93. I'm on my third HPFP replacement. I gave up a while ago on replacing them
Similar Threads | ||||
Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 10:37 AM |
Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 03:45 PM |
Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
