Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-09-2019, 06:46 PM | #1 |
Drift noob
Drives: 2015 BRZ Sport-Tech CWP 6MT
Rear vibrations for days
Hello gurus,
Over 60mph i get insane vibrations. The rear windshield, drear deck area seems to be where the vibrations are the worst. I recently had a 4.88 final gear swap, DS Shop aluminum driveshaft, and Cusco motor mounts installed and the issue came immediately. The vibes are so bad that i feel like bolts may come loose. Under 60mph the car has slight vibrations that is 100 percent tolerable. Other mods i have on the car (pre-vibrations) are: Cusco rear pillar brace, Beatrush rear subframe collars, Beatrush diff mount support brace, Beatrush subframe brace, Beatrush rear strut bar. These mods alone did not cause any harsh NVH. First thing i did the following morning was swap in the OEM motor mounts. I also removed the rear pillar bar. The vibrations are still pretty bad over 60mph but marginally better. Im open to reverting any of the said mods with the exception of the DS and final gear (labor is $$$ and not something i can do myself). Please give me some input as to what you believe the culprit may be. This is not my daily but it is a street car. Thanks in advance! KL
FT86Z
藤原とうふ店 |
04-09-2019, 06:51 PM | #2 |
Rust bucket enthusiast
Have you tried unbolting the driveshaft, rotating it, and bolting it back on? Some people report the need to do this with the aluminum shafts.
04-09-2019, 07:03 PM | #3 |
Drift noob
That's great info. I will research to see if that's something i can attempt myself. Thanks.
FT86Z
藤原とうふ店 |
04-09-2019, 07:43 PM | #4 |
LMGTFY
Drives: 13 FRS, 91 Miata
Does it do it at high rev?
Or just at speed independent of RPM? |
04-09-2019, 08:02 PM | #5 |
Drift noob
It does it the entire rev range after 60mph.
FT86Z
藤原とうふ店 |
04-09-2019, 10:45 PM | #6 |
Weight Weenie
Drives: 15 FR-S
Remove a single component at a time until you find the problem. Start with the easiest.
This is why it's best to change one thing at a time. |
The Following User Says Thank You to new2subaru For This Useful Post: | BirdTRD (04-10-2019) |
04-09-2019, 11:10 PM | #7 |
Seņor Member
Sounds like a driveshaft imbalance. Was it new or secondhand?
1974 TA22 Celica
2013 86 GT |
04-10-2019, 08:43 AM | #8 |
Drift noob
It was brand new and it was installed by a reputable shop. Perhaps it came bent or maybe it wasnt installed properly?
FT86Z
藤原とうふ店 |
04-10-2019, 09:24 AM | #9 |
Someone already said it, but it's very likely just needing to be unbolted and rotated. Not uncommon.
The Following 3 Users Say Thank You to wparsons For This Useful Post: |
04-11-2019, 02:12 AM | #10 |
Seņor Member
Try the unbolt and rotate as mentioned previously. It is possible, although unlikely, that the shaft got to you with a bad balance. Another possibility is with a 4.88 diff your driveshaft is spinning faster than stock for any given road speed, it could be its now spinning faster than the RPM range it was balanced for?
1974 TA22 Celica
2013 86 GT |
04-11-2019, 05:29 PM | #11 | |
Drift noob
FT86Z
藤原とうふ店 |
Similar Threads | ||||
Highway vibrations??? | Fred Flintstone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-09-2018 10:33 AM |
Transmission Vibrations | Scavanger | Engine, Exhaust, Transmission | 2 | 09-22-2014 02:09 PM |
Anyone having problems with vibrations? | ShibaYuki | CANADA | 22 | 01-21-2014 09:06 PM |
Rattles & Vibrations | brian_c_m | AFRICA | 65 | 03-22-2013 03:07 PM |
New 86.. 5 days of ownership, From Monday to Friday, 5 days of mods :D [pics!] | WTF | Member's Car Journals | 53 | 07-16-2012 03:18 PM |
