08-27-2013, 04:31 PM | #1737 | |
Drives: '13 BRZ Ltd WRB
08-27-2013, 04:38 PM | #1738 | |
Drives: Rx7
Front: running 245/35/18 tires -- less than 3mm clearance. We ran 5mm spacer. So +42mm should work if go down to 245/35 tires. Rear: no problem with 255/35 tires. Apex N1 coil over, not slam, fender not roll. -2.8 cambers Mark. RavSpec |
08-27-2013, 05:36 PM | #1739 |
Drives: 2013 swp brz
So should I go for a 41 or 40mm offset if I want to run a 255? Would that give me enough clearance?
08-27-2013, 10:16 PM | #1740 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
ok stock tires were bald and ready to blow, so i slapped on a set of 245/45/17 on the back. they fit and they look nice, very grippy.
my question is...... will this tire size fit the front with no rubbing or camber adjustment? it fits the back just fine but im worried about the front rubbing. |
08-29-2013, 09:29 AM | #1741 |
Drives: Toyota GTS 86 Pearl White
18 x 9.5 + 38 all round with 225/40/18 and 1.5inch drop.. Will this cause any issues?
would i need camber at the front ? if so how much and what should be using Any help much appreciated! Thanks! George |
08-29-2013, 12:12 PM | #1742 |
Drives: Rx7
08-29-2013, 12:13 PM | #1743 | |
Drives: Rx7
225/40/18 are too stretch, you have enough room. I'll advice at least a spring drop. |
08-29-2013, 12:35 PM | #1744 | |
I am planning to drop them 1.5inches on eibach sportlines. So i would not need to adjust the front camber for my setup ? Thanks! |
08-30-2013, 08:20 PM | #1745 |
Enthusiast
Drives: Crystal Black BRZ Limited
Can someone help me out.. I'm just about ready to order my wheels but want to make sure im doing this correctly..
I was going to go with a staggered setup and 1" larger in diameter in the rear, but decided to go square instead. I'm looking at picking up a set of XXR 527's in the following---> 17x8.25 5x100 +35 I plan on dropping about 1-1.5".. Will this be a fairly flush set up? I've seen 17x8 on the table chart with a +35 and a 1" drop and it looks good but the extra ".25" has me a bit confused. If I'm correct.. that means an extra 6.35mm.. does that affect the outcome of where the wheels will sit? I'm losing my hair over here and just want to order these dang things already but don't want to get stuck with something I wont be happy with.. please and thanks to anyone who might be able to help me out here... also, I plan on reusing the original tires just to wear them out, but plan on using a set of bridgestone potenzas from my moms last car, which are 245/45/17, will these fit as well?
Instagram: Neekowahhhh
Mishimoto Air Induction Hose;K&N High Flow Air Filter;Berk Tech Catless Front Pipe;Invidia N1 Catback Exhaust TT;Matte Bronze XXR 527 17x8.25 ET 25 Last edited by Neekowahhhh; 08-30-2013 at 08:21 PM. Reason: spelling |
08-31-2013, 02:48 AM | #1746 | |
Drives: SWP BRZ Limited
08-31-2013, 09:09 AM | #1747 | |
Drives: FR-S Firestorm 6MT
Your stock tires will fit well enough on this rim, so I would reuse those as you suggest. But the 245/45R17's will be too tall. They will fit on the wheel and not rub anywhere, but the taller diameter will give you slower acceleration, which is not a great thing on our cars. |
08-31-2013, 09:15 AM | #1748 | |
You should be able to fit up to a 245/35R18 tire without rubbing. |
08-31-2013, 10:40 AM | #1749 |
Drives: BRZ soon
Avant Garde M310 - 18x8 +30 - 235/40/18 with 1" drop. Looking for something flush. Don't want any poke but don't want them too much in the fender. Would that be a nice flush looking setup? Thanks!
08-31-2013, 05:24 PM | #1750 | |
I would also consider running either a 225/40R18 or a 245/35R18 to get you closer to OEM diameter, as the 235/40 is a bit tall (3% taller than stock). Doesn't seem much but it can make a difference. |
The Following User Says Thank You to Slick For This Useful Post: | 5TLTH (09-01-2013) |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
