Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-02-2011, 11:03 PM | #1 |
Drives: gti, nsx, integra type r,porsche911
towing capacity?
Was thinking about this alot.
I like to have a Tiny trailer to hold a set of track wheels/tires and tools (big enough to hold 8 wheels/tires, and perhaps a motorcycle as this same trailer will be used for motorcycle track days too even if FRS won't be towing it on those days). Was wondering if anybody would think this car could make it. Yes I know we dont' know about this vehicles towing capacity. But i was curious if there are examples of low power/sports cars that tow their own trailers ...rather than use a truck/suv. |
09-02-2011, 11:16 PM | #2 | |
Drives: 4 Wheels Auto
http://www.mainstreet-data.com/trailer/index.htm So even if by spec Miata was not suppose to tow anything, there are people who are doing that. They probably did it with class 1 or less trailer hitch. I think this was embedded in the great debate of trunk or hatch. |
09-02-2011, 11:27 PM | #3 |
Thanks for the info.
It just doesn't make sense to buy a whole other TRUCK/SUV which I'll have to pay insurance/gas on only to be used for towing. I found this picture...its a good size trailer...for a bike and I can see myself strapping on tires on it for the FRS. Still searching for something smaller than that trailer though in the picture. s14 spec similar to frs? |
09-02-2011, 11:47 PM | #4 |
its not just a power game. you need to spring strength or travel to bear the load. a spec miata might be able go get a little more than a stock miata because the springrate is 4x higher and not designed to ride on the bumpstops under normal conditions
09-03-2011, 04:19 AM | #5 |
Drives: Subaru Legacy
Trailer hitch would be handy...
I would only use a trailer, Twice or 3 times a year if that? I dont want another vehicle just for a trailer hitch.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
09-03-2011, 04:25 AM | #6 |
Drives: 2008 XRunner
You probably wouldn't be able to tow more than 500-750 pounds including the trailer. Then there's mounting it, and clearance issues.
I did see a 370Z with a damn hitch molded into the middle of the bumper. Very odd.
“From the beginning, the concept was to put the driver back in the driver’s seat, and to eliminate computers as much as possible today. Powerful sports cars use a lot of computer technology so that anyone can drive and handle them. We decided not to go down that road.” - Tetsuya Tada
The Following User Says Thank You to ToyotaObsession For This Useful Post: | strat61caster (08-20-2013) |
09-03-2011, 09:50 AM | #7 |
Site Moderator
Drives: Stuff
A hitch will be made I'm sure and I'll install one just like on my other cars for hauling tires, mountain bikes, etc
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
09-03-2011, 11:14 AM | #8 |
Drives: N/A
The Standard tow ratings that I see for cars is 1000lbs max.
09-03-2011, 11:59 AM | #9 |
Drives: FR-S, Exige S, Miata
One of the reason I want to buy this car is because I can put the race tires in the back and I don't need a trailer. Otherwise I'll just get a Miata for track.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
09-03-2011, 06:47 PM | #10 |
I think 1000lb towing is good enough for 8 rims+ tires
Probably going to be 17lb rims x8 = 138lbs 138lbs + (weight of 8 tires) + plus the trailer hitch= ? When I want to tow the motorcycle and tires, I'll be using the Subaru instead. Now...to find a trailer that meets that need... I only found trailex.com I'm looking at the Utility Trailers. |
The Following User Says Thank You to CyberFormula For This Useful Post: | JMon85 (05-11-2017) |
09-05-2011, 04:16 AM | #12 | |
Drives: Lexus IS-F
09-07-2011, 09:57 AM | #13 |
Drives: 2005 Hyundai Accent
The Impreza/Legacy platform is great for towing, so if the FRS is in fact based on that platform then towing some tires or a bike should be fine. It will be the weight of the trailer that you'll have to watch out for. If you plan on towing often, you might want to install a temp gauge for your transmission oil, or a full oil cooler system. And you can usually tow more weight if your trailer has built in brakes.
Also, I LOVE that Forrester towing the 86. |
09-07-2011, 10:27 AM | #14 |
Opinionated
Drives: Something Red
While that might look cool...the Forester towing an AE86 is really cutting it close for being not-so-smart...2400lb towing capacity; 1800lb car + 1200lb trailer.
. That said, towing a small trailer with tires and wheels on it will be no problem for the FR-S.
Most of the cars I drive have nets for windows.
