Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 11-21-2019, 03:28 PM   #1
mcnvgget
mcnvgget's Avatar
Drives: 2018 Toyota 86
header bolts
these are the bolts connected from the header to the overpipe, do other cars come with these no bead bolts? seems odd to me
mcnvgget is offline   Reply With Quote
Old 11-21-2019, 03:57 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
Interesting.......
I don't remember mine looking like that (17 BRZ).
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 11-21-2019, 03:59 PM   #3
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I just want to say those bolts were such a pain in the ass when installing aftermarket headers for me. I sprayed some lube oil in it and it didn't work. Not enough room for my impact driver. My breaker bar barely fit and it didn't even move it.
So I used oil + torch. It was still a tough job. The nut was seized on there still so the whole stud came off.
Clueless
YamahaR86 is offline   Reply With Quote
Old 11-21-2019, 04:01 PM   #4
mcnvgget
mcnvgget's Avatar
Originally Posted by i8ur911 View Post
Interesting.......
mine is a 2018 toyota 86
Old 11-21-2019, 04:28 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
it's a common bolt. one end threads into the flange on one side and the other side is held via a nut.
Nissan has had this for their catalytic converters for the last 30+ years.
Old 11-21-2019, 05:16 PM   #6
mcnvgget
mcnvgget's Avatar
how the hell you take it out? i have the header out and itís in the holes still, iím hammering it out and lubed it but itís not budging
Old 11-21-2019, 05:52 PM   #7
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
The overpipe there that you posted? That's the one I had a hard time with.
One side came out easily, just undid it with a breaker bar. The other side was the one I was struggling with.
I ended up spraying a ton of penetrating lube on the bolt, wearing gloves I used one of those kitchen hand-held butane torches from my roommate and kept heating it.
I think the heat made the penetrating lube go deeper into the flange and the
heat loosen the stud a tiny bit. I used a breaker bar and kept pushing at it from underneath the car. In the end the Nut did not come off, I took the whole stud screw off with the nut still on.
Clueless
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-24-2019 05:58 PM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
what are these 2 bolts I got in my ace header box? Breadman DIY (Do-It-Yourself) Guides 6 05-21-2018 11:23 AM
Overpipe to Header Bolts/Nuts 808BRZ Engine, Exhaust, Transmission 2 07-25-2016 08:41 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
