Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 04-03-2019, 05:13 AM   #15
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Da funk is wrong with you boy?!!
Stop giving California people a bad rap.
Are you new to cars? Please tell me your not an "engineer".
I'm in my last semester as an engineering undergrad. Except my discipline is for aircraft and spacecraft instead of these voodoo fire machines we have.
Gonna be real honest here guys. I like how CAIs look in the engine bay and I like the noise and I'm aware that the most HP I'm gonna get is +2 or +3HP. Except I'll probably go Grimmspeed instead if it can clear my oil cooler.
Ryan GT86 is offline   Reply With Quote
Old 04-03-2019, 06:37 AM   #16
churchx
churchx's Avatar
Drives: 2014 orange GT86
Ryan GT86: btw, stock intake also is CAI. But if you must buy aftermarket intake, then good choice on Grimmspeed's, as it is one of few, that doesn't mess with much with MAF sensor readings to artificially lean AF, and also doesn't require removal of bumper for filter change .
churchx is online now   Reply With Quote
wparsons (04-04-2019)
Old 04-03-2019, 07:42 AM   #17
Ryan GT86
Ryan GT86's Avatar
I'm looking at the pics of the Grimmspeed and it looks like it'll be too tight. I'll probably go with the Perrin CAI and a quick release bumper kit.
Old 04-03-2019, 07:57 AM   #18
churchx
churchx's Avatar
If using Perrin's, then i guess MAF sensor will need recalibration in ECU tune. In your place i'd keep using stock intake/airbox, and install aftermarket drop-in airfilter. Most of gains, for minimal cost, less to loose when reverting to stock prior sale.
Old 04-03-2019, 07:59 AM   #19
Ryan GT86
Ryan GT86's Avatar
The version I'm planning on is the CARB certified CAI that doesn't need a tune. The version that needs a tune is discontinued according to FT86SF.
Old 04-03-2019, 08:54 AM   #20
cjd
cjd's Avatar
Drives: 2017 BRZ
The ECU compensates well enough... But the result is power loss.
Old 04-03-2019, 10:33 AM   #21
churchx
churchx's Avatar
As cjd wrote. One thing is CARB certification, which is about emissions and maybe legality in some states, another - about actual gains (and in some cases - safety). For later, aftermarket part should behave similar to stock in areas other parts depend on, or have differences taken into account in other parts (i.e. - in ecu tune). Which often negates "gains".
In many cases "gains" with aftermarket intakes by large portion were artificial in way of fooling MAF sensor readings, resulting in engine running leaner when regulated by stock ecu tune from those readings. Leaner, thus with more power, but more prone to knock, especially with worse fuel. Hence better consider using intakes, that don't sink to such means for artificial gains, and whose MAF readings won't differ much from stock intake. Usually i seen mentioned as such two of them - TRD's & Grimmspeed's. My own choice would be drop-in airfilter, but if going for full intake, i'd choose from those two.
Tcoat (04-03-2019), wparsons (04-04-2019)
Old 04-03-2019, 02:46 PM   #22
radroach
Drives: 13 BRZ
I don't think the CAI is in too low of a location for water damage.
Those telling him not to get a CAI probably haven't been in a tuned 86 with a Perrin CAI. They sound great.
Old 04-03-2019, 02:52 PM   #23
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Those telling him not to get a CAI probably havent driven in a tuned 86 with a Perrin CAI. They sound great.
The biggest issue IMO is if you are in a low speed fender-bender. A one-peice intake will probably smash up into your throttle body.
No danger of this, there's a squishy intake elbow between the Perrin CAI and throttle body.
I recently installed a Perrin CAI simply because it sounds rad!! gives higer rpm range a throaty sound.
VIP BRZ is offline   Reply With Quote
Old 04-03-2019, 08:25 PM   #24
radroach
Drives: 13 BRZ
@VIP BRZ yeah i had edited that out once I took another look and realized it was connected with a silicone inlet.
Disable high Rev cold start Raven604 Engine, Exhaust, Transmission 401 03-23-2018 02:39 PM
Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) Joesurf79 Engine, Exhaust, Bolt-Ons 13 07-29-2016 02:38 PM
Need help disabling high rev cold start with OFT MikeM7 Software Tuning 5 09-14-2015 04:12 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
TRD CAI and Hydrolocking Taro CANADA 3 09-27-2013 12:02 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
