Old 04-10-2020, 10:24 AM   #253
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Originally Posted by SuperTom View Post
Also made my own TRD "STYLE" trunk aero stabilizer. From a piece of fender rubber moulding left over from a project on my Pathfinder that tapers from low to high
Cost ~$10 compared to $200 for real TRD
Did gain a 1lb of weight though but should at least block all the grime from getting into the trunk lid area and stop air from going into the trunk area
It looks perfect! Need more info on what you used.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 04-10-2020, 10:39 AM   #254
JD001
JD001's Avatar
Drives: Subaru BRZ
Don't forget don't your dust pan, it's sitting on your parcel shelf...
Old 04-10-2020, 07:07 PM   #255
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
This is what I had ordered. you only need one roll if you can find it sold that way
https://www.aliexpress.com/item/3295...27424c4dHEw1Qh
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
ichitaka05 (04-16-2020), scottman (04-12-2020)
Old 04-14-2020, 01:10 PM   #256
ML
ML's Avatar
Drives: 13 White MT FR-S
Have you driven it with the under body panels? I was going to do the exact same thing but I thought the exhaust would melt it almost immediately.
Old 04-14-2020, 04:14 PM   #257
SuperTom
SuperTom's Avatar
Ive driven it in 2 half hour sessions Nothing has melted so far. I need a good hour long drive im expecting the areas right up against the exhaust piping to melt but not much more.
Last year I did a test piece with coroplast in the tunnel area. similar to the pieces Velox sells. Nothing melted
The Following User Says Thank You to SuperTom For This Useful Post:
ML (04-14-2020)
Old 04-16-2020, 09:52 AM   #258
SuperTom
SuperTom's Avatar
Just took some quick snaps yesterday. Ill admit to not being good at the whole picture taking thing but you get the idea
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
ML (04-16-2020), StraightOuttaCanadaEh (04-16-2020), WC-BRZ (04-16-2020)
Old 04-16-2020, 10:06 AM   #259
ML
ML's Avatar
have you seen Marsh Composites? http://www.marshcomposites.com/products
The Following User Says Thank You to ML For This Useful Post:
why? (04-16-2020)
Old 04-16-2020, 11:58 AM   #260
SuperTom
SuperTom's Avatar
Yes their roof will be the final piece. Finding someplace to come out and remove/reinstall both windsheilds is where im at with that. Im hoping Safelight or similar can do it for a reasonable fee
Old 04-16-2020, 02:39 PM   #261
Berserker
:O Fitment looks great on all the pieces. I'm all about a light car & I think you persuaded me on the doors
Berserker is offline   Reply With Quote
The Following User Says Thank You to Berserker For This Useful Post:
SuperTom (04-17-2020)
Old 04-16-2020, 03:59 PM   #262
WC-BRZ
Drives: Black BRZ
Awesome pics...
What would be really great with a weight loss build is some sort of performance data just to get an idea. Do you plan on doing 0-60 or any 1/4 mile runs with one of those Dragy GPS things?
I do understand that straight-line performance is not the purpose of the car or even this build, but just to get an idea. Before/after track times at a local circuit would be great, too.
Were you able to get any data before the build?
Awesome update
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Old 04-17-2020, 10:57 AM   #263
SuperTom
SuperTom's Avatar
Prior to the pics the day before I took off the fenders and readjusted everything to fit better. Glad you noticed!
Old 04-17-2020, 11:14 AM   #264
SuperTom
SuperTom's Avatar
Originally Posted by WC-BRZ View Post
Awesome pics...
Awesome update
Sorry no official numbers. Only time its been on a track was HPDE events. Plus I don't really want to hard launch the car to get good #'s and fk up the clutch. And I don't have a good backroad around here to set up/ repeat without other drivers getting in the way.
But I did get curious about the effects and went looking for a good weight @ HP calculator just for an idea. Obviously there is way more to #'s like gearing ect. But for a baseline idea of acceleration effects.
I used this calculator
https://robrobinette.com/et.htm
Putting in weight 2774/ FLywheel HP 205 you get 1/4 mile at 14.6. I think most stock verified times are closer to 14.8. https://www.caranddriver.com/reviews...tested-review/
Entering weight 2350/ Flywheel HP 205 you get 13.8 in the 1/4. A difference of .8 secs. I don't think it would be that much maybe closer to .4
Then I put in 2350lbs/Flywheel HP 225 (estimating my power mods) and got 13.4 in the 1/4.
Not saying my car would run that all but could be able to get into the high 13's.
Old 04-17-2020, 11:49 AM   #265
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Good read. I only read up to page 12 (new to old) and maybe missed it, but you have looked into Radium Engineer ECU bracket? It may shave few oz than stock steel bracket.
Max Orido's rear diffuser might be lil bit lighter than Verus Engineer and it's designed for kouki bumper, so sadly zenki owner like me can't use it... but you can
of course, 326Power ver looks small and prob lighter, but feels like not as functional as Max Orido one.
For interior, TRD JP finally released some cf good. Door cover weight 1.2kg each (2.6lbs)
...but spending $4,400 just for door covers is hard pill to swallow. There's alumium door cover from Spnywoosh. I've heard some of older ver doesn't fit well, but cost only $220 isn't bad and shave 4lbs-ish total.
Now... if someone can make a copy of 14R aero kit. Cuz front bumper & wider fender costing total of $15k! lol
Anyways, keep up the good work!
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
ML (04-17-2020), new2subaru (04-17-2020), StraightOuttaCanadaEh (04-18-2020), SuperTom (04-17-2020)
Old 04-17-2020, 02:02 PM   #266
ML
ML's Avatar
Light, looks good, inexpensive...pick two haha
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
