86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine Swaps
Old 04-10-2019, 11:44 AM   #1121
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Back to thinking about fuel cells and side exit exhaust:
Spare tire well is ~7" tall. Which doesn't leave a ton of wiggle room. Though not having to deal with an exhaust helps.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
zeal86 (04-10-2019), Zer0 (04-10-2019)
Old 04-12-2019, 09:48 AM   #1122
DustinS
DustinS's Avatar
Pulled a rod cap. Going to grab some plastigage and check clearances on the rod bearing and a main bearing tonight.
Old 04-12-2019, 10:26 AM   #1123
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: 2014 Wrb limited
UGH, I hate to admit it but a finished side exit would look pretty cool. Top it off with a functional rear diffuser for the missing exhaust....
Old 04-12-2019, 10:41 AM   #1124
DustinS
DustinS's Avatar
That was the plan.
Depending on what the rest of the bearing look like. I may be re-evaluating the directing of the car. I have a 2j and a K20 in the garage. Leaning towards K20 as the 2J is a heavy iron block and I am missing just about everything for it.
Nothing with the LS3 has been right since the beginning and it's really starting to get to me. Constantly putting money into a car that I originally put way too much money into so I wouldn't have these issues is getting extremely stressful.
GrabTheWheel (04-12-2019), Summerwolf (04-12-2019)
Old 04-12-2019, 10:51 AM   #1125
Summerwolf
Panda Trueno
Summerwolf's Avatar
That was the plan.
Yeah, but.... spintech makes a 90 degree outlet muffler that would work well with side exit and those sound alright with a cammed ls.....
The Following User Says Thank You to Summerwolf For This Useful Post:
DustinS (04-12-2019)
Old 04-15-2019, 10:30 AM   #1126
DustinS
DustinS's Avatar
Double checked clearances with some plastigage and found they were all within spec. So I torqued everything back up and I am just going to run it.
Took the crank pulley off and instantly noticed I had an issue. New Fluidampr was significantly longer. I soon realized my mistake - Ordering a pulley for an LS3 instead of a CTS-V. Already started the exchange process with Summit, hopefully get that back soon.
Started taking off the front cover to replace the oil pump only to run into an issue with the garbage stainless hardware TSP uses. Stripped out without any major pressure. So trying to figure the best way to extract a stainless button head bolt. Will replace with ARP hardware.
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (04-15-2019)
Old 04-15-2019, 01:57 PM   #1127
Zer0
Drives: 2015 frs
If the head stripped Craftsman made a set of socket type extractors that were made to cut into the head, and grab the fastener. If you end up having to drill the bolt low speed high pressure otherwise stainless likes to burn up bits, and anything else trying to cut into it. Heat doesn't travel well in stainless so it stays concentrated where your working and builds up.
Zer0 is offline   Reply With Quote
Old 04-16-2019, 12:49 AM   #1128
DustinS
DustinS's Avatar
I ended up cutting a slot in the heads with an angle grinder, heating it up with a torch, and hitting it with an impact driver and it came out. Replacing with some ARP bolts with anti seize.
Got the crank scraper/windage tray and oil filter relocation kit in today.
*Filter Mount Picture coming soon*
Once the front cover was off I noticed something weird...
Seems the woodruff key moved while I was installing the front pulley and split, Embedding itself into the lower timing sprocket/Crank Pulley. I am surprised it didn't cause any other damage. Will be replacing the woodruff key.
Without key:
I also made a decent change. Switched from the Fluidampr to the ATI. Talking to a local builder and they think it is a worth while change.
The Following 4 Users Say Thank You to DustinS For This Useful Post:
GrabTheWheel (04-16-2019), ILLSMOQ (04-17-2019), zeal86 (04-16-2019), Zer0 (04-16-2019)
Old 04-16-2019, 01:02 AM   #1129
Zer0
Drives: 2015 frs
Nice progress, glad you got that bolt out.
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (04-16-2019)
Old 04-17-2019, 09:45 AM   #1130
DustinS
DustinS's Avatar
Got a decent amount done last night. Crank Scraper and windage tray (which needed a bit of work to fit with the Sikky Pan.
Got the oil pump installed properly by taking the cover off and aligning the gears/casing to the crank with feeler gauges. Also got a new woodruff key.
Oil Pickup Brace installed along with a new O-Ring
Got the oil pan on. Hardest part is a low clearance area next to the oil fitting. I think this button head (slathered in anti-seize) should do well here. Just waiting on clutch and crank pulley and can start installing it.
ILLSMOQ (04-17-2019), Sportsguy83 (04-17-2019)
Old 04-22-2019, 09:29 AM   #1131
DustinS
DustinS's Avatar
Got the shipping notification for the crank pulley. That will be here tomorrow.
Got to work on the car for a bit and knocked out the radiator mounting.
I have a feeling it will need to move upwards on the brackets once the engine is in, but that is simple enough. I was going to use rivnuts, but having a hard time getting them set because I can't get my tool in completely. I also only have m6 rivnuts. I think I am going to weld an m8 nut on the back side of the brackets once I have the location finalized.
The Following 3 Users Say Thank You to DustinS For This Useful Post:
GrabTheWheel (04-22-2019), Sportsguy83 (04-23-2019), zeal86 (04-22-2019)
Old 04-24-2019, 02:22 PM   #1132
DustinS
DustinS's Avatar
Nice updates today. ATI Balancer came in yesterday. Only issue being it requires a Torx Plus bit to assemble, which is quite difficult to get ahold of apparently. Ordered one on amazon and will be here Friday along with some ARP assembly lube. Local Oreillys stocks a full (expensive) set at the warehouse so I was able to get it today. Got all the fluids while I was there.
Clutch came back and they definitely had to make some changes. Hopefully they were correct.
Old 04-24-2019, 03:47 PM   #1133
Axis2011KR
Drives: 2015 FR-S, 2015 F250 on 40's
What was the reasoning behind swapping radiators were you still dealing with heat issues? You were on the FBM and 1328cfm's before right? Or did you just feel like running a VMount style setup for other reasons?
Axis2011KR is offline   Reply With Quote
Old 04-24-2019, 03:51 PM   #1134
DustinS
DustinS's Avatar
Full Blown Radiator was leaking. I was using factory fans and had 0 cooling issues with the setup. I just wanted a slightly shorter radiator.
Axis2011KR (04-25-2019)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 Subaru BRZ General Forum 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess Subaru BRZ General Forum 8 06-12-2012 07:32 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
