Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-20-2015, 05:38 PM | #43 |
Because compromise ®
Drives: Red Herring
06-21-2015, 08:32 AM | #44 | |
Drives: 2015 frs
01-06-2016, 04:39 PM | #45 | |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Stock: 6kg WRX: 5.4kg Hard to believe they're actually lighter than stock but they are...
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
09-03-2016, 04:00 AM | #46 |
Drives: GT86 GTS
Can anyone tell me how this setup feels and braking performance?
11-20-2017, 06:59 PM | #47 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
These look like a solid choice for those who want to retain low offset 17x9's.
I have 17x9 +35 RPF1's and just upgraded my rotors to DBA T3 3000's. I wouldn't mind a more solid pedal feel though and a bit of bling so I'll definitely look into these. Are the Subaru lettering a sticker or painted on? |
11-21-2017, 01:28 AM | #48 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
The Following User Says Thank You to finch1750 For This Useful Post: | Wise (11-21-2017) |
11-21-2017, 02:01 AM | #49 | |
95RON SAV Tuned |
The Following 2 Users Say Thank You to sav For This Useful Post: | Racecomp Engineering (11-21-2017), Wise (11-21-2017) |
11-21-2017, 02:08 PM | #50 | |
Drives: Legacy GT
However, a company (kns brakes), does make a bracket to use them along with a larger 316x30mm legacy gt/ 15" wrx rotor. |
11-21-2017, 05:10 PM | #51 | |
I knew the adapted was needed with the Z32 calipers. Thought they were needed with the Subaru versions as well for some reason (been a while since this thread was bumped lol). Probably makes the price a little more in line with each other. But with the Z32 version there is less bias change and more thermal capacity with the bigger rotors. |
11-21-2017, 07:08 PM | #52 |
Drives: Legacy GT
In the front, all subaru calipers bolt on to any other subaru. In the rear there are three different mounting setups so yeah to put the rear 2-pots on you do need an adapter.
I was thinking about the nissan + LGT rotor setup but it won't work with my winter wheels and I don't really need the bigger and heavier rotors. |
The Following User Says Thank You to jamal For This Useful Post: | finch1750 (11-21-2017) |
12-06-2017, 08:28 PM | #53 |
Circle Work Clerk
Just bought a set of 06 WRX 4 pots off Ebay for $210 bucks.
Plan to refurbish and repaint them and found this link on another forum which I'll definitely follow and repeat the process. https://www.i-club.com/forums/suspen...d-pics-236053/ |
The Following 2 Users Say Thank You to Wise For This Useful Post: | Kenny_LongWrench (12-08-2017), Racecomp Engineering (12-06-2017) |
05-15-2022, 04:38 PM | #54 |
Drives: 2013 Fr-s
Thread revival apologies, I was going to go with ATS brakes and decided to go with 06-07 Subaru 4pots. Currently on the Stoptech Sport Kit (lines,rotors and pads) amazing upgrade. Question is if I swap out the front calipers will I have to pick up WRX pads and anything else? Thanks
The Following User Says Thank You to Uncle86 For This Useful Post: | sav (05-15-2022) |
Similar Threads | ||||
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
How long will my brakes last? | pinoyplaya | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-24-2012 11:21 PM |
OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 10:26 PM |
GT brakes | jello | AUSTRALIA | 2 | 06-10-2012 09:10 AM |
