05-05-2016, 02:29 PM | #15 |
Drives: 2013 satin white brz limited
Reason your wrx used oil is completely different. Not to mention what makes you think that subaru/toyota did not test this thing for hours under temps well over what you guys are talking about. I mean give these companies some credit they pay these engineers for something...
05-05-2016, 02:48 PM | #16 |
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
well in minnesota your climate is much more temperate. 0-w20 makes sense for cold starting etc. Arizona most definitely qualifies as an extreme climate. In the end just do what works or you're comfortable with. Using rotella also simplifies my life because I can use it in both my cars as the rex is still around, I am not giving up my EJ207 anytime soon.
05-05-2016, 02:50 PM | #17 |
Drives: 15 BRZ LTD, 05 FXT
Your bugeye also spec'd 5-30. 0-20 is much thinner, you're making a really big step going from 0-20 to 5-40. You may want to try 5-30 first.
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | jasonojordan (05-05-2016) |
05-05-2016, 02:50 PM | #18 |
Im aware that our climate is much different. What Im saying is don't you think they took all these things into account when they decided that 0-20 was the best oil to run in that motor? that 5w-40 is going to be awfully thick oil for a motor with already fairly high compression.
05-05-2016, 02:51 PM | #19 |
A lot of the track twins run 60 weight oil, I'm going to the track fairly regularly so the change also makes sense given my application .
Sent from my SAMSUNG-SM-N910A using Tapatalk |
05-05-2016, 02:54 PM | #20 | |
Drives: 2013 Asphalt FR-S
Sent from my SM-G920V using Tapatalk |
The Following User Says Thank You to Whats that smell? For This Useful Post: | klear (05-05-2016) |
05-05-2016, 02:55 PM | #21 |
The Following User Says Thank You to klear For This Useful Post: | Whats that smell? (05-05-2016) |
05-05-2016, 02:57 PM | #22 |
At this point we are all just speculating so we will leave it with what was already states as all of this just our opinions lol
05-05-2016, 04:12 PM | #23 |
Anti stance.
I've switched to Mobil 1 0w-40, euro formula. It still uses PAO base stocks.
Government mandates for fuel efficiency are the primary reason for the light weight oil. It certainly wasn't for engine longevity. If I was to still run 0w-20, it would likely be Eneos Sustina. |
05-05-2016, 04:14 PM | #24 |
The Fail Boat
Drives: CWP S.B.
if you look into oil section of the forum you can see a hell lot of good info.
just google this guy--> @viscositosis.rex 's post. LOL If you don't like how oem oil thin out give motul a try? That oil felt so thick in my engine... thou weight is the same 0w-20. |
05-06-2016, 01:14 PM | #25 |
Drives: 2013 FRS
I also stick with the Mobil 1 0w-40, euro formula.
Setup for tracking w/ FI
A zen master once told me "Do the opposite of everything I say", so I didn't.
Similar Threads | ||||
Wheel Weights | FUN BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-24-2014 10:10 AM |
What do you put in the trunk for Weights? | cocoy_labuyo | CANADA | 33 | 11-16-2013 09:23 AM |
Wheel weights | BAE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-09-2012 09:16 AM |
does anyone know why GT86 weights so much? | wu_dot_com | Scion FR-S / Toyota 86 GT86 General Forum | 85 | 03-19-2012 04:24 PM |
What are the Actual Curb Weights? | DanPO | BRZ First-Gen (2012+) -- General Topics | 9 | 12-22-2011 12:01 PM |
