Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-01-2020, 07:12 PM | #1 |
Drives: brz
Snap oversteer???
hi guys,
So i have had this issue with my car at the track. Around sept of last year my set up was Custom coilovers Hankook td Alignment -3 front -2.6rear This setup felt great. No issues. I went to the same track same config this past feb before covid And my car felt like it was on glass. No other cars were have this issue. My car on every corner exit would snap oversteer like crazy. I thought it was my garbo driving, but i had a buddy drive my car and he said something is definitely off. In between track days, i hit this HUGE pothole on the 10 freeway....like this pothole was so big i honestly felt my wheel cracked. My gf thought we crashed. Oddly enough i got an alignment, my guy says the alignment was spot on. All suspension arms and bushings looked great. What could cause my car to behave so radically in corners? Any opinions would be much appreciated. I hope it isnt frame damage. I would literally be okay with any other damage lol Track was streets of willow cw. Thanks for you help in advance everyone |
07-01-2020, 07:30 PM | #2 |
Too soft? Causing too much weight transfer? I'm the wrong to guy to ask though thinking back to my go kart days as a kid.
Sent from my SM-G975U using Tapatalk |
07-01-2020, 07:58 PM | #3 | |
Drives: brz
Not sure but all i know is my set up was exactly the same both times i went. Only difference is me hitting the pothole |
07-01-2020, 08:51 PM | #4 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Did the pothole cause internal damage to the damper?
Did you get the alignment before or after the car felt wonky? Could have left a bolt loose, or maybe you cracked a cam bolt or something and no one could tell because they didn't remove anything. Weirder things have happened. |
07-01-2020, 10:01 PM | #5 |
ProCrastinationConsultant
what custom valving do you have? i would first talk to your shock guy.
07-01-2020, 10:21 PM | #6 |
How were your tires? The same ones, more wear, tire pressures?
The Following 2 Users Say Thank You to Ernest72 For This Useful Post: | Icecreamtruk (07-21-2020), strat61caster (07-02-2020) |
07-02-2020, 03:34 AM | #7 |
Drives: '13 FRS - STX
+1 tires get old, grip less
Some tires get noticably worse sitting in the garage during the "winter" months |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Icecreamtruk (07-21-2020), wparsons (07-03-2020) |
07-02-2020, 05:01 AM | #8 |
Drives: brz
Soundman98
I trust my shock guy. I dont think its the problem. He drove my car too and he said they felt fine. Strat61caster I did have my tires sit in my garage over the winter. I live in socal so its not that bad. But maybe letting the tires sit ruined them?. Never thought of that. Ernest72 Tire pretty i was running were the same as my first mentiined track day. They still had life left. They are my second set of wheels. So they just sit in the garage not used unt track days. Same tire pressure. Slightly more worn, but not nearly enough to make the rear feel like its on glass. BlueWhalen I got an alignment before and after. everything seemed fastened down. Thanks everyone for your opinions. Really helps. Also i got an alignment and new dd tires. I used tk daily federal rsr. But switched tk their higher TW tire. Their new ST-1 evoluzions. If i turn the wheel back and forth at highway speeds, the rear feels super floaty. Maybe i have been blessed tk drive on higher grip tires. But my friends cars who has way crappier tires dont feel like the rear is floating and trailing behind when i make inputs with the steering wheel. Not sure if this problem ks related to my oversteer issue. But my alignment guy as i mentioned before says everyhing "looks" fine. |
07-02-2020, 07:16 AM | #9 |
Drives: 2014 GT86
Ar all suspension bushings/connections/linkages really fine? Wheel bearings? Are all bolts checked from both sides? (had once head of upper camberbolt snapped, somehow noticed it only when changing winter wheels to summer ones. "it drove fine!")
Do you have by chance alignment printout? Imho more often then not misset toe may cause handling artifacts then camber that you mentioned. Though that's more along the lines "check everything". By Murphy's laws it will probably be something obvious that noone thought to check or checked last , just like i checked everything in suspension multiple times in search for noise source, and it turned up loose bracket connection of braided brakeline :/ |
07-02-2020, 07:20 AM | #10 |
Sounds like maybe the gas leaked out of one of your struts/coilover/shock absorber whatever you got in there.
07-02-2020, 10:14 AM | #11 |
Drives: 2017 Series Yellow BRZ
Do you have any additional tire noise while driving? You could have broken belts in the tire causing your sidewalls to crush more than normal in a high g turn. Had this happen to me and drivers side rear sidewall was flexing huge. Car behind me caught it on camera.
Toyo R888R's Same thing, large pothole on way to the track. 2 laps and my track day was over the car was so bad. |
07-02-2020, 10:22 AM | #12 |
Drives: 2014 GT86
Azzudien: and let me guess - on stationary car tire still looked normal, as damage was inside?
07-02-2020, 01:23 PM | #13 |
Drives: brz
Thanks for all the ideas.
I really hope my struts arent leaking. XD As for arms/ linkage, i am totally fine with bent or broken arms /bushings sonce those are replacable. Im just hoping no one says its frame damage. I am thinking of going into a shop to inspect as well. |
07-02-2020, 01:40 PM | #14 | |
Never heard of it before it happened to me. And frankly I didn't believe the guy at the track that told me this until the tire tech pulled the tire off and explained it all. Apparently not that uncommon in the northeast with our crappy roads |
Similar Threads | ||||
Snap Oversteer's Varis Arising II Seat Time Build | Wangaroo | Member's Car Journals | 3 | 04-17-2019 05:22 AM |
Not understeer, not oversteer... something else? | Mazikowski | Tracking / Autocross / HPDE / Drifting | 15 | 07-25-2016 09:24 PM |
Oversteer during overtaking | Roarke | BRZ First-Gen (2012+) -- General Topics | 20 | 10-08-2014 06:20 AM |
Controlling Oversteer? | Neokolzia | BRZ First-Gen (2012+) -- General Topics | 29 | 09-22-2014 10:58 PM |
frs oversteer in brz mechanical? | swpbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-18-2014 09:48 PM |
