02-16-2015, 09:10 PM | #29 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
too good not to sub. subbed!
02-16-2015, 09:33 PM | #30 |
Drives: '13 Ultramarine FR-S M/T
My stupid, uneducated guess is that the problem is the stock heads. I've see the intake runners and the look like they could use a lot of improvement.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
02-16-2015, 09:44 PM | #31 |
Member of the year - 2016
Drives: Scion FRS
This i like...
02-16-2015, 11:25 PM | #32 | |
Drives: 93 MR2 Turbo; 2014 BRZ
Great response. It's difficult to know. |
The Following 2 Users Say Thank You to eric6 For This Useful Post: | Calum (02-17-2015), djliquidsteele (02-18-2015) |
02-16-2015, 11:43 PM | #33 |
Drives: waiting on a 2021...
I would have to think that the large runners that connect the two plenums would do more to balance it out than the small hose at the bottom. Just guessing by looking at the design, on a NA build this intake would kill what little low end these motors have due to the extremely short runner length between the plenums and the cylinders, with those rather large plenums above them that will slow down the air. Should be a great forced induction setup though. I could be totally wrong though...
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
The Following User Says Thank You to zooki For This Useful Post: | cdrazic93 (02-17-2015) |
02-16-2015, 11:59 PM | #34 |
Because compromise ®
Drives: Red Herring
Fixed.
The Following User Says Thank You to Captain Snooze For This Useful Post: | Calum (02-17-2015) |
02-17-2015, 12:03 AM | #35 |
Drives: Red Herring
*protest*
I think the low end torque is quite adequate. Between approximately 2500-3300 rpm is very close to max torque on a standard engine.
The Following 5 Users Say Thank You to Captain Snooze For This Useful Post: | Calum (02-17-2015), CatDaddysBBQ (04-03-2015), MAPerformance (02-17-2015), Turdinator (02-17-2015), WhiteRose (03-30-2016) |
02-17-2015, 03:00 AM | #36 | |
Drives: Red Herring
I would have thought that with forced induction imperfections in the manifold design would be hidden. That is, air is forced in (and out) so it hides poor design. (I am not suggesting the FA20 is poorly designed.) I would have thought that the biggest gain, percentage wise, would have been for normally aspirated and even then, given the standard rev limit, it would not be a huge gain. Significant but not huge.
02-17-2015, 06:36 PM | #37 | ||
02-17-2015, 08:43 PM | #38 | |
Drives: '23 BRZ Limited
On some big power BMWs just a little port work/cams is netting ~15% HP/tq on boosted applications at lower psi, since the engine is flowing more air. |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Captain Snooze (02-17-2015) |
02-18-2015, 12:56 PM | #39 |
86-er
Drives: BRZ tS
I think imo its a pretty good design.
Extended runners will have similar results as crawford, but more top end cause of the 2 long tube design inlet. Shouldn't see any decrease in torque or decrease in hp. That tube design to balance pressure is thumbs up. This piece paired with a bigger tb and flywheel, ahhh this is going to keep me NA. I like it a lot
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
02-18-2015, 04:39 PM | #40 | |
Drives: 2015 BRZ Series.Blue
The Following User Says Thank You to s30series For This Useful Post: | mad_sb (02-25-2015) |
02-18-2015, 05:04 PM | #41 | ||
If nothing else, we created the most divided theory manifold to date . |
02-18-2015, 06:24 PM | #42 |
Señor Member
@eric6 any thoughts about including the ability to install the port injectors above the trumpets for people doing hardcore NA builds?
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 236 | 06-20-2019 01:42 PM |
Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
Intake manifold | viking | Engine, Exhaust, Transmission | 6 | 09-23-2014 11:08 PM |
Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-12-2014 11:40 PM |
WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
