Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
02-16-2020, 05:28 PM | #1 |
Drives: 2013 Scion FRS
2nd gear grind
Just bought a 2013 frs, for the first week it was shift smooth then after that I started getting the infamous 2nd gear notch and grind. I have changed my trans and diff oil to motul gear 300 seems a little better but is there any way to eliminate this issue for good?
The Following User Says Thank You to mramones For This Useful Post: | humfrz (02-17-2020) |
02-16-2020, 09:05 PM | #2 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Not really. You can try a motul/redline cocktail or the like, but it seems nothing's really been proven to eliminate the 2nd gear clunk....aside from just slowing down your shifts.
The Following User Says Thank You to BlueWhelan For This Useful Post: | why? (02-17-2020) |
02-17-2020, 08:51 AM | #3 |
If you bring the revs up just a bit between the 1-2 shift it will slide in more easily. Syncros are great but don't work as well when everything is cold so a little mechanical assistance goes a long way.
The Following User Says Thank You to gravitylover For This Useful Post: | soundman98 (02-17-2020) |
02-17-2020, 12:27 PM | #4 |
Drives: 2013 FRS
You can also double de-clutch it. That’s how ppl drive some of the earlier super cars where their synchros are weak. Think of it as a feature from super cars of that era.
2013 FRS - JRSC CARB
"Use all of the track" they say |
The Following User Says Thank You to milanojess For This Useful Post: | Ultramaroon (02-17-2020) |
02-17-2020, 12:46 PM | #5 |
Rust bucket enthusiast
Is this your first standard car? I'm not trying to pick on you, but be sure that now you're getting used to driving stick, you're not becoming lazy. Be sure that your gear changes are quick, do not slowly lean into second gear. When you put the clutch pedal down, pull quickly from 1st into second and see if this helps.
Some cars don't mind lazy gear changes; this car is wound pretty tight and will grind if you're shifting really slowly, especially from 1st to second. Also, be wary of referring to anything as "infamous" or " notorious"- these should not make you feel like you are not responsible for something wrong with your vehicle. Whether an issue is commonplace or not, are and will always be a minority of reported and statistics. People tend to complain about something than to praise it. I'm not trying to be snarky, I promise! I just want to prepare you for life on this forum, where people daily excuse themselves of a problem or stop trying to fix it because they think it's "infamous" Last edited by DarkPira7e; 02-17-2020 at 01:16 PM. |
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
02-17-2020, 01:03 PM | #6 |
Thanks guys, will try each of the things you've suggested.
Sent from my SM-G973U using Tapatalk |
02-17-2020, 01:07 PM | #7 | |
Only happy when it rains.
Drives: series.blue
This is true, but our 2nd gear just sucks. |
02-17-2020, 01:08 PM | #8 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
normal. people will say change the fluid, people will say change your technique, people will say let it warm up, people will say get an automatic, etc...1st/2nd will always have moments of being notchy and clunky, inescapable, just let the clunk into your life.
personally I just take it real easy shifting the first few miles, I make sure I'm totally off throttle, slowly press in the clutch, I bring the shifter to neutral and then to 2nd. Once it is warmed up, zero clunk.. |
The Following User Says Thank You to HKz For This Useful Post: | AJ32162 (02-17-2020) |
02-17-2020, 01:22 PM | #9 |
Hkz that's what I noticed, seems putting it in neutral then going to 2nd shifts smoothly all the time. Any of you guys ever heard of maybe switching up the clutch to something other than oem to resolving the issue?
02-17-2020, 01:29 PM | #10 | |
Reformed
02-17-2020, 06:09 PM | #11 | |||
初級成員
Drives: 2017 86, 2010 Corolla
02-17-2020, 08:40 PM | #12 |
ProCrastinationConsultant
with my sample size of 2, cold starts are sometimes stiff. once the trans gets above 100 degrees though, i rarely have issues beyond my own spastic hand/foot coordination when i accidentally try shifting at exactly the same moment i let the clutch out.
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (02-17-2020) |
02-17-2020, 11:49 PM | #13 | |
There ain't nothing really wrong with you or your car's transmission. It just takes some getten used to. I have found that when I grind going from 1st to 2nd I'm not payen attention and am lazy legging it. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Apoc (02-19-2020) |
02-18-2020, 03:39 AM | #14 |
Drives: 2013 FRS
[*]Double clutch into 2nd gear at all times. 1st gear too while we're at it of course. In fact, 1st gear needs this much more if you ask me.
Indeed, I get a lot of commute hr jams, and downshifting to first gear while car is moving can only be done with double clutching... at least with my 2013.
The Following User Says Thank You to milanojess For This Useful Post: | humfrz (02-18-2020) |
Similar Threads | ||||
2nd Gear Grind | Stonewall | CANADA | 12 | 04-06-2018 01:36 PM |
5th gear grind | Hugo | Issues | Warranty | Recalls / TSB | 7 | 06-08-2016 08:33 AM |
4th gear grind | aaguirre123 | Engine, Exhaust, Transmission | 8 | 08-03-2015 04:58 PM |
2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 04:02 PM |
4th gear grind | Moetivegt86 | Issues | Warranty | Recalls / TSB | 10 | 03-07-2014 11:50 AM |
