Forced Induction Turbo, Supercharger, Methanol, Nitrous |
02-23-2021, 08:27 AM | #29 |
Only happy when it rains.
Drives: series.blue
I totally disagree. They are nowhere near as bad as they used to be. It takes some adjusting to get used to it but it isn't anything like the old school ones that made cars almost undriveable.
The Following User Says Thank You to why? For This Useful Post: | Tcoat (02-23-2021) |
02-23-2021, 08:48 AM | #30 | |
What can be different about them that removes the issues?
02-23-2021, 10:19 AM | #31 |
Drives: 17 Asphalt 86
For a street use I wouldn't want the lightest option which for many seems to be around the 10 pound mark. Stock is 20 pound range from sources on here.
If stock is 20 pounds, knocking off 5-7 would be reasonable to keep some drivability. Avo flywheel is 15 pounds and comp clutches is 12.6. 15 seems about perfect to me and 12.6 seem like next best for a street setup. I've ran a 7 pound fidanza flywheel on my integra and it was a bit much for daily. Compared to stock Weight of 18 pounds. |
02-23-2021, 11:22 AM | #32 |
12 lbs is fine for daily driving. I've got the Exedy 12.7 lbs one right now. Just don't pair it with an aggressive clutch and it works great.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | RToyo86 (02-23-2021) |
02-23-2021, 11:43 AM | #33 | |
Drives: 2016 Toyota 86
I am looking at getting the Exedy lightweight flywheel later this year. Did you need to get your tune adjusted for the flywheel? |
The Following User Says Thank You to Mike_ZN6 For This Useful Post: | ermax (02-23-2021) |
02-23-2021, 12:48 PM | #34 |
Drives: series.blue
Two things. The first is the flywheels are not anywhere near as light as they used to be. I remember seeing 5 and 6 pound flywheels back then. Even the lightest now is about 12 pounds. The second thing is the clutch is so much better. You can get an aftermarket clutch the drives just like stock and can handle an extra 100 pound feet of torque. No more clutches that feel like you are driving a dump truck.
02-23-2021, 01:08 PM | #35 |
No changes needed with my OFT 4.03 e85 tune. I haven’t tried it with stock tune.
02-23-2021, 01:18 PM | #36 | |
I’ve never had negative impacts from FWs down to 12. I’ve never had any lighter that that but I’d imagine negative impacts to casual driving would start there. The only negative thing I can think of is no more tail waging shifts to 2nd which really isn’t a negative thing in my eyes. |
02-23-2021, 01:47 PM | #37 | |
Drives: 18 BRZ tS, 27 GRMN 86
https://www.counterspacegarage.com/c...ch-system-fa20 Any chatter or judder @ idle, 2000rpm or other rpm? Is the clutch heavier? How do you like it as daily driving vehicle in traffic? Thanks! |
02-23-2021, 03:10 PM | #38 | |
Drives: Scion FR-S 10 Series
The pedal pressure is a bit heavier but there is much more feel so I find it easier to use. I also have the mtech clutch spring which I highly recommend! There is no noise or shudder at all when the clutch is out, when the clutch is in it make the iconic Os Giken ringing noise from the floating pressure plate. I would imagine the one from CSG would be even better for a daily then the one I have, I wish you lived closer as I would let you try it. Just for perspective my 62 year old mother has no complaints driving my car! |
02-24-2021, 04:26 PM | #39 | |
Also, I bet the CSG version didn't exist at the time you purchased, as the CSG single is a very new release, and specced out to try to fit as wide a range of "typical modification" 86's as possible, whereas the CSG twin disc was specifically made for high hp applications and track specific applications that didn't have any highly specialized clutch options at the time. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Jdmjunkie (02-24-2021) |
02-24-2021, 06:03 PM | #40 | |
The Following User Says Thank You to Jdmjunkie For This Useful Post: | CSG Mike (02-24-2021) |
02-24-2021, 07:51 PM | #41 | |
By the time I purchase the clutch, I want to order the CSG Spec 1.5Way OS Giken Diff (if available) as well. |
The Following User Says Thank You to botbs For This Useful Post: | CSG Mike (02-24-2021) |
02-24-2021, 09:25 PM | #42 | |
In this instance, a CSG spec doesn't make sense, since it wouldn't work for everyone, or even a wide range of users. OS Giken LSDs are currently backordered, but the next batch on order by CSG arrive at the end of March. At that time, each unit is opened up and configured as needed before shipping. |
The Following User Says Thank You to CSG Mike For This Useful Post: | botbs (02-25-2021) |
Similar Threads | ||||
FS: OEM Clutch & Flywheel | pleong | Transmission and Driveline | 2 | 10-14-2014 01:00 PM |
Fs: act flywheel and clutch | Guildjs | Transmission and Driveline | 9 | 05-18-2014 03:26 PM |
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? | OICU812 | Engine, Exhaust, Transmission | 2 | 05-17-2014 01:56 AM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 10:01 AM |
