01-08-2014, 12:32 PM | #505 | ||
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
01-08-2014, 12:36 PM | #506 |
Drives: BRZ/1J Supra
I couldn't find that in the rule book where did you find it. I thin I will take the SCCA Solo Technical Manager and your word for it since he is a reliable source.
By the way what is the best front sway bars that you guys are running? I want adjustable since this is a street car but I want to hear everybody's input |
01-08-2014, 12:50 PM | #507 | |
Drives: BRZ(sold), STI
01-08-2014, 01:06 PM | #508 | |
Drives: Some kind of Subaru
As for sway bars, I installed the Sam Strano bar. |
01-08-2014, 01:21 PM | #509 |
Dodging cones
Strano bar here as well. Most aftermarket bars for this car are too stiff. Strano's the weakest increase over stock on the market, as it needed some front bar but not crazy amount.
01-08-2014, 01:39 PM | #510 |
Think the Cusco 20mm is actually closest to stock. It needs more.
I run a lot of toe to keep it in line, and it's still too loose. |
01-08-2014, 01:51 PM | #511 |
Dodging cones
Oh really? I know it's smaller than Strano's but is the stiffness lower? What is the percentage? Strano's is 85% over stock.
01-08-2014, 01:55 PM | #512 | |
Dodging cones
Edit2: Googling it showed 74% so I guess it is softer than Sam's 85%. I stand corrected.
01-08-2014, 02:06 PM | #513 |
Pawn in game of life
Drives: 19 STX BRZzz
Des is driving the FR-S, which will likely need more bar than the BRZ due to the spring rates. I plan to start the year on the stock bar and hope to leave it that way. I've already got the catback, Koni's, camber bolts, RPF-1's, and 235 Z2's. Can't wait to get started learning to push it
John
Autocross nut
01-08-2014, 02:20 PM | #514 |
Drives: Yes
Perrin 19mm *should* be softer than Strano as well, depending on the setting. I had the massive Hotchkis last year, still deciding what I want this year.
01-08-2014, 02:24 PM | #515 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
I am running the 20mm Whiteline on the softest setting on an FR-S and I wish it a bit softer. I wanted to reduce rotation and it reduced it a bit more than I would have liked.
01-08-2014, 04:04 PM | #516 |
Drives: Firestorm FR-S
You want to run in STX against me, that's what you want!
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
01-08-2014, 04:19 PM | #517 |
Thanks guys
01-08-2014, 04:31 PM | #518 |
Drives: 2013 Subaru BRZ
Keep in mind that the tire you choose may require a completely different setup (bar, alignment, shock settings) than that of someone running a different tire. When jdrxb9 and I tested ZII's vs. RS-3's on his car without changing setup the balance was significantly different. Obviously BRZ vs. FR-S is also a factor.
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
Similar Threads | ||||
Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
