Software Tuning Discuss all software tuning topics. |
04-26-2019, 07:34 PM | #15 | |
Drives: 2022 GR86, 2013 BRZ (sold)
Sorry, I misspoke earlier about the continuity check between the steering angle sensor and ESP unit. I forgot the SAS is connected to the Electronic Power Steering ECU, which then broadcasts this info over CAN-BUS. So SAS and ESP aren’t connected directly. However, I still think it’s worth investigating if the SAS is faulty - I’d try reinstalling the original ESP and try replacing the SAS if possible. @steve99 is right - the ESP ECUs on these cars aren’t paired to a specific vehicle or VIN. It should be plug and play assuming the replacement is also from a similar vehicle variant (same transmission, etc). Since this fault is present with both, I’d do your troubleshooting with the original unit. Good luck, let us know if you figure it out. Last edited by Bolobao; 04-26-2019 at 08:00 PM. |
10-29-2019, 09:24 AM | #17 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
11-04-2019, 10:58 AM | #18 | |
was just a tune thing, nothing mechanical. all fixed now
2014 Subaru BRZ
11-04-2019, 04:36 PM | #19 |
Drives: FT86
11-05-2019, 10:45 AM | #20 |
was racerom issue. mike squared it right away
2014 Subaru BRZ
The Following User Says Thank You to Soloside For This Useful Post: | steve99 (11-05-2019) |
Tags |
abs, module, tsc, vsc |
Similar Threads | ||||
EcuTek programming kit | h@zmat | Engine, Exhaust, Bolt-Ons | 4 | 03-09-2017 08:15 PM |
Key FOB programming | milkesfrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 10-21-2015 03:56 PM |
Key fob programming | sambrz | BRZ First-Gen (2012+) -- General Topics | 4 | 10-08-2015 10:08 AM |
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module | Danklvr | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-04-2014 05:57 PM |
