Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-29-2017, 11:39 AM | #477 |
Super Saiyan
Drives: 9000 HP FRS
is upgrading the final drive in an automatic worth it or not?
09-30-2017, 11:34 AM | #478 |
Drives: FRS
More so in an auto than a manual, due to the higher gearing in an auto for highway cruising, which slows acceleration.
Another benefit is compensating for larger wider tires with larger diameters (that would affect gearing, making it taller). |
12-17-2017, 04:25 AM | #479 |
Drives: GT86
Are the gears 1 and 2 still driveable with FD 4.56 or is there only wheel spin with 225" summer tires?
12-17-2017, 03:34 PM | #480 |
Drives: Toyota GT86
They are still driveable.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
01-15-2018, 08:18 PM | #481 |
Drives: Subaru BRZ
is there a big difference between 4.556 and 4.875? im interested in the latter, since stock is 4.1, whereas 5.125 will be overkill.
is the cusco fd compatible with the oem lsd? im also checking out their rs lsd, but not quite sure yet. anybody has experience using both? |
01-15-2018, 08:20 PM | #482 | |
Drives: frs
01-15-2018, 09:09 PM | #483 |
Drives: Subaru BRZ
is there a toyota part# for the cusco 4.875 fd?
The Following User Says Thank You to n0thing For This Useful Post: | Kronos (03-24-2018) |
03-24-2018, 06:09 PM | #484 |
Drives: 2013 Scion FR-S - White
Weir made a 5.29 for my 2013 AT, and it is WONDERFUL He was great to deal with.
Yes, it's a lot of gear, so expect a little whine, which I was fully prepared for, and both Weir and PTuning warned me it would increase. It is quite tolerable, and heard more outside the car than inside the car, and is actually much quieter than I expected. I would do this again on the AT, without even a hesitation. He can hook you up with an entire kit, with everything you need, including an assortment of shims, to have your local speed shop put it in, in one go. I had mine done in a single afternoon @ PTuning. Depending on timing, there can be lead time from Toyota on the shims. Mine took 5 weeks. But since I had a full kit, my car was only down the single day for install. Note, you will start getting some wheel hop, so plan to change the rear subframe bushings and diff carrier bushings at the least. I haven't done that on mine (it is on my April mod list), and you can really feel how bad the factory bushings comply and Wind up/twist once you have the additional mechanical advantage of the FD upgrade. HTH someone!!! |
The Following 2 Users Say Thank You to ChristineAlexa For This Useful Post: | Impureclient (03-25-2018), Teseo (03-24-2018) |
05-12-2018, 02:22 PM | #485 |
Drives: Moped
Bump to hear impressions from others who have swapped gears...
05-12-2018, 05:27 PM | #486 |
Drives: 2017 toyota 86
I got a 4.5 going in to my AT in 2 weeks. Will have to break it in. Maybe in another month I’ll have a good review.
05-12-2018, 06:13 PM | #487 |
Drives: Toyota GT86
I have the 4.556 for more then a year. My mpg has gone up and combined with a header and the OFT v4 tune, the car drives like a champ.
Verstuurd vanaf mijn Xperia L met Tapatalk
The Following 3 Users Say Thank You to elBarto For This Useful Post: |
05-12-2018, 06:26 PM | #488 |
Drives: 2015 Limited
Running a 6MT, had Gruppe-S headers and a tune done by Drift Office running approx 190HP. Added Weir 4.56 gears about a year ago, and though not a huge difference, it definitely drives better (higher into the power bands) so it has a better response and quicker off the line. Tires tend to break loose a little easier. It's been a fun and welcome improvement. I doubt their is a huge difference between the 4.56 and 4.875, If I had to do it again I'd give the 4.875 a closer look.
05-13-2018, 08:42 AM | #489 |
Drives: 13 mt fr-s
06-17-2018, 12:14 AM | #490 |
I basically posted this in the 1/4mile thread, but figure it may help win your FD swap question. This is using the gps device dragy, I have compared it to video runs and it seems to be consistently .1-.2 seconds slower (delayed). All in all seems pretty accurate.
57 degrees, 92octane, no weight reduction 1/3rd tank gas, with a 2500rpm launch with an auto. First 1/8th was flat, second 1/8th was slight incline. ET on 1/8th 74.98 and ET 1/4th 92.89, 60ft 2.35seconds (I’ve heard/seen dragy is really accurate but not for 60ft times) Grimmspeed intake, BPB, ace 250, header back, 4th e-tune revision, 4.556 fd swap. auto shifts to 3rd at about 54, and 4th at about 83, so not “optimized” for 0-60 / 1/4mile. But still at least .3 sec faster in both vs 4.1 fd which didn’t require that extra shift. Purely on feel it pulls harder, and before in the auto it still pulled hard to top of 3rd about 92mph, then shift to 4th and fall on its face. Now it pulls hard all the way in forth to 114, before falling on its face in 5th. |
Tags |
cusco final drive |
Similar Threads | ||||
PST Carbon Fiber Drive Shaft Installed | msile | Engine, Exhaust, Transmission | 155 | 08-28-2018 07:53 PM |
Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 12:17 PM |
Is my Cusco catch can correctly installed? | wbradley | Engine, Exhaust, Transmission | 9 | 02-24-2014 09:49 PM |
Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 06:54 PM |
