08-22-2014, 10:17 PM | #99 |
Drives: 2013 SWP BRZ
The Following 2 Users Say Thank You to Assunta For This Useful Post: | humanshield (08-23-2014), jng (08-28-2014) |
11-12-2014, 08:53 AM | #100 |
Drives: 08 STI|15 BRZ|95 L Coupe
I'm curious, would the 18x8.5 +42 fit the stock suspension in the front? If so you could run a staggered set up with the 18x9.5 in the rear without having to go RB! That would be a great option for guys like me who don't need ridiculously wide rims because we don't plan to push over 275 whp...
11-15-2014, 06:15 PM | #101 | |
11-20-2014, 12:17 AM | #102 |
Oh ok, but do the 18x 8.5 +42 have the same issue? or is it just the 9.5?
11-22-2014, 11:08 PM | #103 |
Engineering Student
Drives: Scion FR-S 2015
Is there any clearance with stock suspensions or do I have to upgrade to coilovers? What if I get 8.5 front and 9.5 back width... will this cause issues with stock suspension?
12-08-2014, 04:40 PM | #104 |
Drives: Evolution IX, 13' FR-S White Out
Wheel Directory: Enkei RS05RR 18x9.5 +43
Just purchased these wheels for my wife. She has TRD lowering springs. Do I need a camber kit and what's the MAX width tire I can run without hitting the perch?
01-06-2015, 08:58 PM | #105 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Does anyone have these wheels with an STI Brembo brake swap, and if so, do they clear with no issues?
Top Tier Imports - Check out my build journal HERE
01-16-2015, 01:45 PM | #106 | |
Ive had a set of 18x9.5 +43 sparkle silver n order for a month for my personal car! Super stoked for them to get here in the next two weeks! Although mine will be going on my WRX these wheels look great on BRZ/FRS. And agreed to everyone saying that 9.5 should have more concave! if only! -Anthony Oakos Automotive |
01-16-2015, 01:47 PM | #107 | |
Thanks for the info 5mm would be sufficient in your opinion?
01-21-2015, 12:21 PM | #108 |
Contact at ENKEI says 10mm spacer.
Which stinks cause Im coming off of Rays 57dr in 17x9 and they have no issues clearing my brembos lol.. -Anthony Last edited by OAKOS Automotive; 01-21-2015 at 12:39 PM. |
01-22-2015, 10:49 AM | #109 | |
I guess I'll get some 10mm's and extended studs
01-22-2015, 12:12 PM | #110 |
Just tested fitted with 5mm spacer with 245/40/18 v12 Evo tires up front. These work with stock suspension. It's close with the perch but does not hit. I may end up with 10mm in the rear to even it all out
07-12-2015, 11:57 PM | #111 |
Drives: it like he stole it!!
so with aftermarket coils, spacers are not necessary?
07-13-2015, 04:56 PM | #112 |
Similar Threads | ||||
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
Wheel Directory: Enkei RS05RR 18x8.5 +42 | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 206 | 03-02-2018 05:23 AM |
Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 | THMotorsports.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-19-2013 04:33 PM |
