Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-06-2012, 12:10 PM | #1 |
Drives: Mr2
Fr-s with subaru turbo?
So as rumors circulate there is talk that subaru is going to make a turbo for the brz while trd is in works for makeing a supercharger. My question is if subaru makes a turbo for the brz would it be a direct bolt on to the FA20 fr-s motor? I want forced induction but would rather have a turbo than a supercharger
05-06-2012, 12:12 PM | #2 |
Reverse Burnouts
Drives: 2013 Argento FRS
yup, probably....
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
05-06-2012, 12:27 PM | #3 |
Now w/ over 400 womprats!
Drives: BRZ LZR
If they have the exact same engine, why wouldn't the same part fit on both?
- The Ancient BRZ Sacrament by Zaku |
05-06-2012, 12:48 PM | #4 |
Drives: Mr2
Thats what i thought. The ECU and everything is made by subaru isnt it? So it should be easy to put it everything in the fr-s
05-06-2012, 01:02 PM | #5 |
Drives: BRZ LZR
As easy as it will be for the BRZ...
05-07-2012, 04:44 AM | #6 |
Drives: 2005 Subaru STI
It all depends how far they go on their turbo. If they release it as a aftermarket kit then yes. But most likely it will be a engine from a wrx.
Understand that impreza na has totally different internals than the wrx or sti. Its not just a turbo, its literaly Everything! There is no way you can directly bolt this on. Probably be easier with engine swap. Supercharger might be a different story.
05-07-2012, 11:56 AM | #7 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
If Subaru comes out with a Turbo BRZ, it's likely the engine won't be left as it is now. The engine would have lower compression pistons most likely, as well as other tweks like bgger injectors.
If you're thinking of bolting a turbo to your N/A FR-S, you'll have problems. Swapping the whole engine, on the other hand, would work. |
05-07-2012, 01:15 PM | #8 |
Kuruma Otaku
Any news on what Subaru is doing with the DI 1.6T they showed off beside the FA20 a while ago?
Impreza? BRZ STI? New car? Base WRX, and the WRX STI gets a 2.0T?
Because titanium. |
05-07-2012, 08:13 PM | #9 |
Future Owner
Drives: Honda Accord Coupe
I read a pretty interesting article in Motor Trend about this. They were implying that, amongst other things, Subie execs were actually leaning toward a supercharged setup sourced from TRD because the car is so light and RWD. Now this was a little blurb in an article talking about marketing the car from both companies(IIRC) but it did raise the question about whether a turbo would be the best option if you wanted a smoother powerband. Now me, I know little about turbo setups muself but I'd assume you could accomplish that somehow.
"You know you are a true car nut when you look forward to something breaking as an excuse to upgrade" - Ed Loh
04 Accord Coupe V6 6m |
05-07-2012, 09:06 PM | #10 |
Drives: 2002 Acura TL
even though were talking about the brz here the next WRX is rumored to get a electronic turbo so we might see that in the brz
05-07-2012, 11:50 PM | #11 |
Site Moderator
Drives: ichi 86 Project
If they go w turbo... They have hellova stuff they need to figure out other than internal parts. Intake & exhaust relocation, TMIC or FMIC figuration, if it's FMIC redesign radiator, if it's TMIC they need to move the engine forward, & list just goes on & on
05-08-2012, 01:19 AM | #12 |
Drives: '06 AM V8V Coupe
Yea, this is why I think they'll stick with NA until not only have next generation forced induction and electronics have matured, but also when they are absolutely required to hit fuel efficiency goals. A very advanced electric turbo system would come with a whole host of power electronics, and to increase fuel efficiency I think they'd first be looking at hybrid systems before turning to downsizing+complex FI.
05-08-2012, 02:34 AM | #13 |
Drives: 92 NSX, 08 Accord
Yeah, I'm not understanding how they could release a bolt-on supercharger (or turbo) that would work well with the current high-compression engine. Unless it only had 2 lbs of boost or required thick head gasket spacers.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ) 2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold) 2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue |
05-08-2012, 11:12 AM | #14 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Direct injection helps prevent knock. It allows for a higher knock threshold than port injected engines.
Similar Threads | ||||
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 118 | 11-16-2017 02:19 PM |
Report: Subaru Coupe STI Model Possible, But Without Turbo | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 168 | 07-28-2011 10:03 PM |
Assumption: Subaru=Turbo / Scion=NA | ftw-86 | Scion FR-S / Toyota 86 GT86 General Forum | 159 | 06-20-2011 03:28 PM |
Subaru BRZ Coupe STI turbo charged pictures (renders) | brandon | BRZ Photos, Videos, Wallpapers, Gallery Forum | 48 | 06-13-2011 04:15 PM |
