Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-14-2015, 09:50 PM | #71 | |
Most cars we set up are 9/11, 10/12, or 12/14. ALL of these cars are street driven, except one. |
The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (12-03-2015) |
02-14-2015, 10:06 PM | #72 | |
Because compromise ®
Drives: Red Herring
[2] Crikey!
02-14-2015, 11:11 PM | #73 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
The Following User Says Thank You to BatStig For This Useful Post: | wparsons (12-03-2015) |
02-15-2015, 12:37 AM | #74 | |
02-24-2015, 11:55 PM | #75 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
rubber end links?
A question for @Captain Snooze. I hadn't realized how much swaybar crosstalk is screwing up my ride until I read this thread. The question is, "What do you think of replacing the heim-joint swaybar end links with end links that have metal-sleeved rubber donuts on each end? (see picture)
The rubber end links will have some flex for small bumps and vibrations, but still provide some sway prevention. The struts won't have to work so hard to control the extra spring pressure of the 21MM OEM front swaybar. I could use the rubber end links for the street, and the heim-joint end links for the track. |
03-29-2015, 04:23 PM | #76 |
Well @captain_snooze, I tried my end links and they didn't help much. Yesterday I removed my front sway bar and installed my Bilstein HD's. They have BRZ front springs, (27 N/mm (153 lbs/in)), and FR-S rear springs, (37 N/mm (211 lbs/in)27.75(158.45 lbs/in)). The ride is better without a front sway bar. The last time I had these struts on my car, I found them to be intolerably stiff. Since they aren't adjustable, they make the perfect test struts for testing the effect of sway bar removal. Later today I'll remove the rear sway bar and try that out as well. I'm beginning to think that all a person needs to do to make these cars ride better on the street, is to just remove the sway bars. I'll know more after removing the rear sway bar as well. Thank you @captain_snooze for pointing me in the right direction.
12-03-2015, 05:19 AM | #77 | |
Drives: '14 GT86 project, '13 GT86 DD
It's not a job I'd want to do again!!
The Following User Says Thank You to Nigelr32 For This Useful Post: | wparsons (12-03-2015) |
12-17-2015, 05:06 AM | #78 |
Drives: GT86-ACE-JRZ-RPF1-Essex
Do you still like your AST ?
I just found they are in Nerderland, which put them on my list. That plus digressive valving and we have a JRZ RS Pro challenger. I was considering Nitron too. |
Similar Threads | ||||
Hood Dampers | AlexK | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-20-2015 05:08 PM |
2013 AT Ultramarine FRS ODO 5200 SJ/Oakland | peachsnow | Cars for Sale/Trade | 1 | 11-20-2014 06:38 PM |
For Those With MCA Dampers | Captain Snooze | AUSTRALIA | 0 | 08-14-2013 05:13 AM |
QA1 dampers? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-06-2013 10:00 PM |
Which Dampers to get? | djliquidsteele | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 08-27-2012 02:13 PM |
