Old 01-23-2014, 02:08 AM   #29
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by Jeff Lange View Post
I looked at the back side of the pedal and it was hard to tell with it in the car, but it looks like other common Toyota wider pedals should fit the rod, the only issue is that the Zx6 has what looks like a pedal stopper built into the pedal that would not be there if using the 78101-20150 pedal. The 2010 Camry SE had this pedal with a stopper on the back of it, but the pedal is only available as an assembly (78110-33060). Still it seems like coming up with some sort of stopper wouldn't be too hard.
Still, I had no real trouble heel-toeing in the car with the smaller pedal.
Jeff
I got the part number 78101-20150, as your pictured. But for the life of me, I can't seem to remove the pin that holds the original pedal in place... Does anybody have a tip, an advice on how to proceed to swap the out the original pedal and install this one?
Guillaume is offline   Reply With Quote
Old 01-23-2014, 03:01 PM   #30
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
This is the easiest car to heel/toe that I have ever had! Just sayin'...
Jond63 is offline   Reply With Quote
Old 01-23-2014, 03:12 PM   #31
DMDominator
Drives: Genesis 3.8 Track, Firestorm FR-S
2 Fast 2 Furious, yo.
DMDominator is offline   Reply With Quote
Old 01-23-2014, 03:20 PM   #32
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Yeah, it's pretty good. I bought the cusco pedal plate but I haven't installed it yet as I don't want it to be a crutch so I'm forcing myself to learn without it first.
So far so good but the problem I see is that you can't really use your "toe" it's more your midsole or ball of your feet as the gas pedal is short to get your heel square on it. However, I'm assuming with the cusco plate, which is longer, I should be able to use more of the front of my foot as opposed to the middle and hit my heel at the bottom of the extended plate.
1Cor10:23 is offline   Reply With Quote
Old 01-23-2014, 03:23 PM   #33
CrazyWookiee
Drives: Whiteout FR-S
I have the Cusco Accelerator Pedal Plate as well.
Video I made:
[ame="https://www.youtube.com/watch?v=q4cfX1aocTo"]Cusco Sports Accelerator Pedal FR-S/BRZ/86 Install & Review - YouTube[/ame]
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following User Says Thank You to CrazyWookiee For This Useful Post:
SoCal909 (01-23-2014)
Old 01-23-2014, 03:30 PM   #34
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The problem is not wether I can heel-n-toe the BRZ (thanks for your concern though, I am doing ok: [ame="http://www.youtube.com/watch?v=QHSp1W1GSnU"]Subaru BRZ @ Mettet - YouTube[/ame] ).
Just looking for someone who fitted this (OEM, need I say) part.
Old 01-23-2014, 09:51 PM   #35
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Coincidence that I just installed mine today and then came across this thread, lol. I used a punch and a hammer to remove the pin. Just be careful. If the pin gets misshapen in any way, it will be a PITA to remove.
Dustin is offline   Reply With Quote
The Following 3 Users Say Thank You to Dustin For This Useful Post:
Guillaume (01-24-2014), Jeff Lange (01-25-2014), Rampage (01-24-2014)
Old 01-24-2014, 11:02 AM   #36
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The moral of this story: with proper tools everything is easier
The Following 2 Users Say Thank You to Guillaume For This Useful Post:
Old 01-24-2014, 11:04 AM   #37
Luis_GT
the stock pedal is perfect for heel/toe, even with my size 10 feet...
Old 01-24-2014, 11:05 AM   #38
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The stock pedal was ok, I expect this to be an improvement over something not bad to begin with. (Haven't driven it yet.)
Old 01-24-2014, 02:23 PM   #39
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Heres the cusco pedal :
http://ft86speedfactory.com/cusco-sp...640b599400b1f5
sweetfrs is offline   Reply With Quote
Old 01-24-2014, 09:16 PM   #40
schmearcampain
Drives: 2014 Argento FRS 6MT
Cusco pedal works great. Easy install too.
schmearcampain is offline   Reply With Quote
Old 01-24-2014, 09:32 PM   #41
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
+1 Cusco pedal.
Old 01-25-2014, 12:30 AM   #42
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Originally Posted by Guillaume View Post
The stock peal was ok, I expect this to be an improvement over something not bad to begin with. (Haven't driven it yet.)
What was your solution to the pedal stopper issue that @Jeff Lange mentioned? Or is it a non-issue?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 12:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) -- General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
