steve99
Old 07-21-2014, 11:27 AM   #211
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Grip Ronin View Post
wondering does this maf scaling technique work for a blow thru FI like the JR kit?
It's no different, they use it on Turbo Subarus and I've used it on my Sprintex'd car.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-21-2014, 02:02 PM   #212
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by solidONE View Post
Are these the tables that control the PI to DI ratios? Looks like it only goes up to 5200rpm.
Is anyone else having problems changing the port ratio values in romraider? It would allow me to change the values, but once I go to save the changes the saved file will have reverted back to the original values.
Old 07-21-2014, 03:21 PM   #213
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Make sure you are running the latest version of Romraider:
http://www.romraider.com/forum/viewt...p?f=14&t=10682
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (07-24-2014)
Old 07-21-2014, 04:20 PM   #214
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I'm having a strange issue using the port ratio tables in ecuflash. I'll have it set to 25 percent past 3600 rpm but it still reads 0 until 5200 in the logger.
D-VO is offline   Reply With Quote
Old 07-21-2014, 05:45 PM   #215
steve99
Drives: FT86
Try upping the user level to advanced or developer
if that fails try using ecuflash but just remember it wont alter lc or ffs parameters
Old 07-21-2014, 10:21 PM   #216
solidONE
solidONE's Avatar
Thanks! That did the trick.
Old 07-22-2014, 04:03 AM   #217
steve99
Drives: FT86
Originally Posted by jamesm View Post
I have a stupid romraider-related question, maybe this isn't the right place to post it but it seems like the knowledgeable guys are here, so...
i just bought one of those fancy 'QHD+' laptops, with the 3200x1800 display. Every app i use works great, everything scales as expected and looks decent. Not retina macbook pro type awesome, but good enough.
Romraider however is completely unusable. the text is not scaling at all and all of the buttons etc are teeny tiny. Is there any way to enable some sort of scaling so it'll work on this laptop?
Alternatively, i've been using TunerPro for the last few OFT e-tunes i have to finish up (won't be doing any more lol). I have what i believe to be the latest defs for TunerPro, but when editing australian roms none of the axes have any values on any of the tables. is this normal?
Can to rescale the display back to 1280 by 760 or some other horrible low resolution , does it work then ? (I just use an old clunker for tuning stuff.
Have not used tunepro for ages,not sure if the defs have been updated.
you could try Ecuflash it does not have the defs for Launch and flat foot shift but they are of dubious benefit.
Old 07-23-2014, 02:43 AM   #218
solidONE
solidONE's Avatar
Lowered the port injection ratio. Still knocking. A bit less to a certain extent over the stock 0.2xx but @ 0.000 it knocks more than 0.105. IAT at about 85f. :/
Old 07-23-2014, 04:27 AM   #219
s2d4
s2d4's Avatar
What are you trying to achieve?
Old 07-23-2014, 11:47 AM   #220
solidONE
solidONE's Avatar
Eliminate or at least reduce knock on 91 gas.
Old 07-23-2014, 12:11 PM   #221
s2d4
s2d4's Avatar
by running less PI?
Old 07-23-2014, 01:45 PM   #222
solidONE
solidONE's Avatar
by running less PI?
Yes. That was the idea. Reduce or eliminate knocking without pulling timing.
Whenever i change the port ratios i just change all 3 tables at once. I've found that always running the minimum amount of port ratio necessary for a given setup will allow for significant gains in terms of knock suppression on pump gas.
I essentially monitor Direct Injection Time Final and/or DI requested volume (the latter of which is only available in an unreleased RaceRom beta, so not much use to most folks). I'll then gradually bring down the PI ratio until i'm ~10-20% under what i consider to be a safe limit (1ml or 6.5ms depending on the param that i have access to).
I used this technique on an NA tune last night and was able to make considerable horsepower up top in the most knock-proned area of the curve. With stock port ratios knock up there was an issue @ ~15-17whp over stock (can't remember the actual timing or AFR values, i'd have to look), and by the time i brought down the port ratio and added a couple other tricks we were at 29whp over stock with no knock in sight.
something to consider trying if you're fighting knock above 6500rpm or so. On an NA car you'll never get close to any limitation, even with 0% port ratio across the board.
Old 07-23-2014, 02:00 PM   #223
s2d4
s2d4's Avatar
Cheers.
Old 07-23-2014, 05:02 PM   #224
solidONE
solidONE's Avatar
Cheers.
I have a feeling this will work better with the table rescaled with higher port ratio at the very upper end of the rev range and lower ratios right below it. If only @jamesm will throw us another bone as to how he achieved his reported results.
The Following User Says Thank You to solidONE For This Useful Post:
Kodename47 (07-23-2014)
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
