Old 04-02-2019, 11:44 AM   #2395
Vital
Drives: 2015 BRZ
Originally Posted by jslack View Post
Allright group. I ended up buying coilovers to fit the wheels on the car. I'm looking to do 255/35/18 up front and 265/35/18 in back. I was just wondering how that affects my speedometer when driving. Or will it be negligible. Also running right now with no spacers and still seem to have room, but would the 265 be an issue on the rears?? Thanks.
Here is a tire size calculator. Plug in the stock tire specs and plug in the tires you are going to upgrade to and it will give you all the information you are looking for. https://www.discounttiredirect.com/l...ize-calculator
Vital is offline   Reply With Quote
Old 04-02-2019, 11:56 AM   #2396
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
It won't make any reasonable different and there is ZERO reason to stagger tire sizes on the 86. ZERO. Run 255 or 265 square.
Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-03-2019, 03:07 AM   #2397
drapejuice329
Drives: 2014 BRZ Limited
what lugs are you using those look dope
drapejuice329 is offline   Reply With Quote
Old 04-03-2019, 03:09 AM   #2398
drapejuice329
Originally Posted by PRORICAN View Post
Enkei NT03+M 265/35-18 all around!
what lugs are these they look dope
Old 04-03-2019, 07:29 AM   #2399
jslack
Drives: 2017 Red subaru BRZ Limited
Thanks for the information. I wanted 265 around but I have a friend that said the 265 up front started to rub as the wheel fully turned. I'm just running the coil overs and no other mods in the wheel area, would I still be ok with the 265 up front?
jslack is offline   Reply With Quote
Old 04-10-2019, 12:44 AM   #2400
sixthree
Drives: 14BRZ
Looking to join the 18 inch club. Currently on a 17x9 +35 245/40/17 setup with coils, no lca or camber bolts in the front.
Can I get away with 18x9.5 245/40/18 without camber adjustments? Just stock parts? Do I need to roll my fenders to fit 18inches or will I be okay with the 245 tires?
sixthree is offline   Reply With Quote
Old 05-28-2019, 12:47 PM   #2401
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Originally Posted by Jive Turkey View Post
4) rolling and slightly pulling your fenders will give you more clearance than you think, you will always rub on the rear bumper tab unless you trim it first.
-Ivan
So am I understanding this correctly: I am attempting to get tien flex A coils from CSG, and will put 18x9.5 +40 with 265/40 on my car. Will this cause any rubbing? If its a yes, would dropping down to 255/40 remove rubbing? Just trying to wrap my head around this.
as a sidenote: for daily driving and maybe some spirited canyoning, what should a good camber be on F/R?
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 05-28-2019, 01:52 PM   #2402
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You will rub on the rear bumper tab with 265/35. A 255/40 is much bigger (26" diameter vs. 24.6" OEM). To go smaller, you would want 255/35/18. (25" Diameter)
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Daedex (05-28-2019), Jordanwolf (05-28-2019)
Old 05-28-2019, 02:57 PM   #2403
Jordanwolf
Rice King
Jordanwolf's Avatar
People seem to be ignoring diameter.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 05-28-2019, 03:36 PM   #2404
JD001
JD001's Avatar
Drives: Subaru BRZ
WTF!! Diameter is everything ...
Old 05-28-2019, 03:40 PM   #2405
Roadcone
StreetKart
people are stupid and dont understand how tire sizes work because all they do is see something on a facebook group and get trolled and then wonder why shit doesnt fit.
Old 05-28-2019, 03:47 PM   #2406
Daedex
That One Guy
Daedex's Avatar
Thanks for the response. Is there a how-to for fixing this? I've been googling brz rear bumper tab fix, but am not finding anything.
Not sure what to do to not make it rub.
Old 05-28-2019, 04:40 PM   #2407
Leonardo
Country Boy 4 Life
Leonardo's Avatar
265/35/18 tires rub on the bumper tab. They will rub on the tab till they wear off the area that touches or till you cut it off your car. That's how its done. Or use 245/35/18 for stock diameter spec. Or 255/35/18 , which is generally the largest size tire to fit without modification of the car. (car, not suspension- you will need coilovers to fit the wheels and tires you want)
I LIKE TIRES!
Old 05-28-2019, 08:48 PM   #2408
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i don't want to be rude, but this has been beaten to fucking death in here. the entire first post is incredibly detailed for a reason, yet we get non-stop reposts of the same questions.
the rear bumper tab is the little corner of the bumper on the inside of the wheel well where it meets the quarter. if you don't do it it will simply trim itself, not a problem you'll just hear rubbing noises at times under compression....which is also a big difference. if you have shit BC suspension you have no suspension travel you won't rub.
You see my setup, the ONLY times i rubbed are full lock, and even then it was a maybe.
if you stick to a 40 offset and a 265/35 you'll be fine if not slammed.
an all you people in here worried about rubbing, think to yourself, how often do you go full lock, I hardly ever did/do.
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
cactus (05-06-2021), Daedex (05-28-2019)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
