Old 01-10-2018, 04:35 PM   #8079
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by NIKOLA View Post
...my tuner at the time suggested against it saying the sensor would be too sensitive and would pick up the fluctuations of the valves opening and closing. Does that sound right?
That is correct, this system doesn't like anything other than the OEM sensor.
Also, should I think about getting new injectors like 700cc? I ask because with the 69mm pulley and on e85 I hope to be at or near 300 whp and I'm not sure if I really need bigger injectors or not for more flow. I don't recall if Mike at Moto-East where I got the supercharger ever indicated to me whether or not I would need new injectors, but he did say my stock fuel pump would be fine if I remember correctly. Input on this? AJ already responded in the previous post regarding injectors, but I'd like to get a few more opinions on this.
You'll be on the limit of the OEM injector setup on the 69mm and E85. I can't comment on the fuel pump. Does a Google search on this site pull up any info?
What about fuel rails? would larger volume fuel rails help in any way or are they simply more on the decorative side of things like changing black radiator hoses to red or blue?
Not needed.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
NIKOLA (01-10-2018)
Old 01-10-2018, 08:12 PM   #8080
CARBON10
CARBON10's Avatar
Drives: 13 FR-S 10 series #0783
Hey guys.....
Just out of curiosity I wanted to ask if any of you changed out your MAP sensor to a 3 or 4 bar variant or are you running the OEM sensor as I am? I realize that tuning with the OEM sensor doesn't give you correct readings on the "Torque" app for boost PSI, but my tuner at the time suggested against it saying the sensor would be too sensitive and would pick up the fluctuations of the valves opening and closing. Does that sound right?
Quite the opposite here. My tuner wouldn’t tune it without a different MAP... as it maxed out the stock and he couldn’t make clear adjustments. He provided a 4 bar and tuned accordingly.
As a separate post... I’ve done 100+ pages of reading in this thread and couldn’t find an exact solution. I’m running a 210 non intercooled kit that I purchased new and self installed a couple of months ago. With this said it’s an 80 mm pulley... and I’ve developed quite a belt squeak. I originally thought pulleys... ruled out idlers, replaced the tensioner, tried a new original length belt... same noise, upgraded to a gates RPM belt... noise got WORSE.
If I spray water or lubricant on the flat side of the belt the noise goes away for a moment, then comes right back.
Any ideas?
CARBON10 is offline   Reply With Quote
Old 01-11-2018, 02:01 PM   #8081
Kodename47
Kodename47's Avatar
Drives: UK GT86
You lose power by running a larger MAP sensor
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-11-2018, 09:19 PM   #8082
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Any ideas?
I got mine installed back in May/June time. No squeaks whatsoever and I'm using the Gates belt that Sprintex provided. It must be one of the pulley's I guess, but which one?
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 01-12-2018, 03:02 AM   #8083
sw20kosh
Drives: 2013 Black FR-S
This is going to confuse people. LOL
Old 01-13-2018, 10:19 AM   #8084
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yup, but it's true. It's the reason that Sprintex stopped shipping with a MAP sensor and instead advised to use OEM. It affects both the 210 and 335 as well. You don't need a larger MAP sensor to tune the car anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-15-2018, 02:08 PM   #8085
sw20kosh
Until you reach the limit of the MAF.
Old 01-15-2018, 06:31 PM   #8086
Kodename47
Kodename47's Avatar
Drives: UK GT86
Which you won't on this compressor. Plus SD would be a pain with the MAP resonance that the sensor picks up.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-15-2018, 07:01 PM   #8087
CARBON10
CARBON10's Avatar
It ended up being the belt. I grabbed a MOPAR belt number that I found at work that was just a few mm shorter, and actual fabric on the back and sound went away immediately. The shorter gates number that was in this thread would not fit with the larger pulley of the 210.
Drove it all day with it today and no sounds. 🤷🏻*♂️
On another note.... I was just sharing my experience with the MAP. The car was tuned on Ecutek by James at HRI, who has tuned 100’s of various 86 setups. I trust his input and car runs flawlessly at both high and low RPMs
Old 01-16-2018, 05:16 AM   #8088
Kodename47
Kodename47's Avatar
Drives: UK GT86
While I also trust James from his time on here, I also trust the tuner who I work with who's the UK importer of the Sprintex and had these on the dyno many times. Logs look reasonably fine but the 335 stopped making power at higher RPM. Stock MAP sensor back on, problem went away and instantly made 15-20hp more. The same thing kept happening on the 210, it just robs you of less power. You don't lose anything by running the OEM sensor, to run a larger range sensor is not required.
In laymans terms, the stock sensor doesn't see the pressure fluctuations that the compressor causes at higher boost/RPM. You just tune the MAP compensation up until positive pressure, the MAF does the rest. If you have a sensor that measures the turbulence it causes the fuel and timing to run less than optimum and there's nothing you can do. I've personally seen the logs when this happens and it doesn't show up as an issue, you can only pick up on it with a dyno where the tailpipe AFR reading really aid diagnosis.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-16-2018, 11:04 PM   #8089
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Just ordered my kit if anyone in the area would like to help with the installation I would be 12 pack thankful.
Joeyb860 is offline   Reply With Quote
Old 01-25-2018, 09:40 PM   #8090
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I'm going on the dyno this weekend to get my tune dialed in. Is the tune file locked from Moto-East?
Chad86 is offline   Reply With Quote
Old 01-26-2018, 03:02 AM   #8091
Kodename47
Kodename47's Avatar
Drives: UK GT86
I would imagine so, yes. Have you got an EcuTek dongle, the software and tune file? If so when you open it up you'll only be able to see the logging parameters.
.: Stealth 86 :.
Kodename 47 DJ:
Chad86 (01-26-2018)
Old 01-26-2018, 10:25 AM   #8092
xjohnx
Grip>Slip
xjohnx's Avatar
Yes. You're gonna have a hard time finding a tuner that will sell you an unlocked tune.
The Following User Says Thank You to xjohnx For This Useful Post:
Chad86 (01-26-2018)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
