06-02-2016, 12:04 PM | #799 | |
06-02-2016, 12:23 PM | #800 | |
No they are not "lazy". The market analysis and millions of dollars spent on it showed that this is the car that the majority were looking for. The high HP speed machine niche is full already.
The Following 9 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (06-02-2016), El Guapo (06-03-2016), Elleteeh (06-02-2016), FLYFISHR (06-02-2016), HunterGreene (06-02-2016), krayzie (06-03-2016), Lynxis (06-02-2016), Mim (06-02-2016), NemesisPrime909 (06-02-2016) |
06-02-2016, 12:29 PM | #801 | |
Drives: 2013 WRB BRZ 6MT
The Following 3 Users Say Thank You to Lynxis For This Useful Post: |
06-02-2016, 12:40 PM | #802 | |
Drives: '12 C63 P31, '23 GRC
I'd be all for a BRZ Club Sport model. Something really stripped down weighing in around 100-150 lb less. Would be pretty nice!
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
The Following User Says Thank You to WolfpackS2k For This Useful Post: | Lynxis (06-02-2016) |
06-02-2016, 12:50 PM | #803 | |
Then there is the fact that you cannot compare running a BBK with high end track pads to anything that you can do with the OEM braking system. |
The Following User Says Thank You to Lynxis For This Useful Post: | LOLS2K (06-02-2016) |
06-02-2016, 12:55 PM | #804 |
I wasn't aware that the Brembo brake option for the BRZ qualifies as a BBK? I didn't think the rotors, aka, heat sink, was much larger.
Def nod in agreement that pad life and pedal feel are superior with a fixed caliper design.
06-02-2016, 01:00 PM | #805 |
Oh, it definitely qualifies, the whole kit is definitely bigger than my RR Racing Sport Performance 4 pot BBK.
06-02-2016, 01:08 PM | #806 |
-Proud of Brzerhood-
Drives: '17 BRZ CWP LMT.
hehe, I'm trying to see if my S2000 would be fixed in time, so I can make that 200 some mile journey to CT from DC. Actually might be even longer than 280 some miles.
"The BRZ Section's fine wine" -Zgrinch |
06-02-2016, 01:14 PM | #807 | |
That being said, does anyone have the exact specifications of these new brakes? More or less, rotor diameter and thickness.
06-02-2016, 01:19 PM | #808 |
Off Topic
It's called a BRZ RA Racing. Only available in Japan, naturally. Comes with an oil cooler, brake ducts, 6-pt cage, and 4-pt harnesses.
The Following User Says Thank You to gramicci101 For This Useful Post: | WolfpackS2k (06-02-2016) |
06-02-2016, 01:28 PM | #809 | |
06-02-2016, 01:28 PM | #810 |
Drives: Datsun 510
Planet Subaru has a pic with specs that lists the following...
Front - 11.6 in ventilated disc, dual-piston calipers -12.8 in BREMBO ventilated disc, four-piston calipers Rear - 11.4 in ventilated disc, single piston calipers - 12.4 in BREMBO ventilated disc, dual-piston calipers Link also includes the information regarding the new ratios, if all is correct. Expand the "Take a deep dive into the 2017 BRZ:" --> "CLICK TO OPEN" Last edited by DatsunDimer; 06-02-2016 at 01:52 PM. Reason: Additional information |
The Following 5 Users Say Thank You to DatsunDimer For This Useful Post: | Axel (06-02-2016), KalbiCool88 (06-02-2016), raven1231 (06-02-2016), Sport-Tech (06-02-2016), WolfpackS2k (06-02-2016) |
06-02-2016, 01:33 PM | #811 |
Pretty impressive hardware. Considerably larger diameter rotors than my 987S.
06-02-2016, 02:43 PM | #812 | |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Tags |
-20hp heavy body kit, 10/10 do want, 2017, better than the 86, facelift, more drag same hp, update, would bang (gears), zaku goes to ct |
Similar Threads | ||||
2017 FRS Official Facelift Pics | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-17-2016 05:06 PM |
When will we see the facelift revealed? | airjonny | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 03-17-2016 04:04 PM |
2017 Toyota 86 facelift | TMXSTAR | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-17-2016 11:06 AM |
Were they not going to debut the 2017 facelift end October??? | gt8613 | BRZ First-Gen (2012+) -- General Topics | 10 | 11-16-2015 09:21 AM |
FR-S/86 Facelift render | JW89225 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 11-04-2015 06:43 PM |
