Old 02-07-2017, 05:13 PM   #7771
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Appreciate the offer man. Hows the 335 going? What kinda clutch you end up ordering?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 02-07-2017, 07:53 PM   #7772
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
335 is good, only driven the car twice now though haha. Commuting too, so not even "fun".
Trying to NOT drive the car though since I'll be tempted to beat on it haha. I've got a clutch from McLeod coming in-I'll have a full review/write up on it since no one else seems to have one or have heard of them.
I probably won't have the clutch in for another 2 weeks maybe? I still didn't even get the video edited together that I shot during install lol.
Old 02-07-2017, 10:45 PM   #7773
riboyster
riboyster's Avatar
Probably not even worth dumping it without the clutch. I'm excited man. Wishing I'd started with the 335, but back then I only knew it as a rod snapper that only built dudes ran.
Wish I'd known that it was a higher displacement/cooler boost monster capable of running on stock internals.
Old 02-08-2017, 02:19 AM   #7774
riboyster
riboyster's Avatar
IAM at 0.94, but car feels and sounds great.
(obviously I expect it to drop on warmer days, although I don't plan on boosting without W/M on said days)
Any thoughts from you peeps?
Old 02-08-2017, 02:38 AM   #7775
choi0706
Drives: t
I'm selling a full lightly used 335 kit if anyone is interested in buying it. I went turbo.
choi0706 is offline   Reply With Quote
Old 02-11-2017, 07:07 PM   #7776
riboyster
riboyster's Avatar
Anyone here running on an open source tune that they'd like to share? Getting tired of waiting on my tuner to either unlock it or adjust timing.
Old 02-14-2017, 08:07 AM   #7777
xjohnx
Grip>Slip
xjohnx's Avatar
My bypass valve has separated from the back plate and i'm having a heck of a time getting in touch with @SprintexUSA to purchase a new one. Does anyone know how I can make it so the bypass valve remains open (to prevent building boost) until I can resolve this?
Old 02-14-2017, 11:49 AM   #7778
riboyster
riboyster's Avatar
If you've got a tapped MAP plate, you could use a wastegate. Not too sure otherwise.
The Following User Says Thank You to riboyster For This Useful Post:
xjohnx (02-14-2017)
Old 02-14-2017, 01:40 PM   #7779
xjohnx
Grip>Slip
xjohnx's Avatar
I do have a tapped MAP plate, but that seems like more trouble than it's worth. i was hoping i could disconnect the arm from the bypass actuator to the valve or something like that. I think it would probably work, but i just got off the phone with sprintex and will have a new one here by tomorrow morning at 10:30 AM. If you need support, I highly recommend calling them vs email.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
MINOCIN (02-18-2017), riboyster (02-14-2017)
Old 02-14-2017, 01:44 PM   #7780
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
If you didn't try calling here's the # (855) 591-2778. There's only one guy that works there so there's a chance he isn't at work because of the flu or something.
On the valve there is a nut or bolt that holds it on if I remember correctly which you can adjust so that the lever stays open or closed, not being able to rotate instead of being able to open and close like it should. I had to replace mine because the bracket that the plastic attaches to the metal was coming off because of the stupid platic rivet-ish design.
stockysnail is offline   Reply With Quote
Old 02-14-2017, 02:06 PM   #7781
xjohnx
Grip>Slip
xjohnx's Avatar
Exact same thing happened to mine. I gave them a call and have a new one that should be here by tomorrow morning.
The Following User Says Thank You to xjohnx For This Useful Post:
Old 02-14-2017, 09:40 PM   #7782
xjohnx
Grip>Slip
xjohnx's Avatar
Do you have instructions for replacing the valve, by chance? or is it pretty self explanatory?
Old 02-15-2017, 11:33 AM   #7783
stockysnail
Just the tip
Very simple. The tricky part is positioning it properly to get the valve to open and close properly. I just threw it on and the level stayed open. Look at the valve lever before removal to see where it should be starting at. Once on there move it by hand to make sure it opens and closes. Start the car and move it or have someone else push the gas pedal so you can watch the level move open to close. If it's not opening and closing like it used to before swapping then you'll need to adjust the position a little.
The Following User Says Thank You to stockysnail For This Useful Post:
Old 02-15-2017, 11:47 AM   #7784
riboyster
riboyster's Avatar
How did you guys know something was wrong? Did you just notice it while looking? Or did the car act weird?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
