86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Software Tuning
Old 07-18-2019, 07:22 AM   #29
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Subaru dont allow access, even the stock ecu is protected by seed\key access sequence, it had to be reverse engineered get access to stock ecu contents . Ecutek and brzedit just add theor own lock sequence on top of the standard ecu seed key sequence.
Their are tune systems that access toyota vw and lots of other cars, afaik all manufacturers have some kind of lock sequence you cannot just read it out without cracking some form of key sequence. Im sure subaru could make it more difficult if they wanted though as could all manufacturers.
https://www.alientech-tools.com/en/vehicles-list/
Most aftermarket tunes dont comply fully with emmissions in most countries but thats another issue
They also dont tell anyone about how the ecu works or tavle locarions or functions its all reverse engineered from the ecu code.
to
didn't know that, that's awesome. I wonder how expensive those things are.
why? is offline   Reply With Quote
Old 07-19-2019, 04:43 AM   #30
steve99
steve99's Avatar
Drives: FT86
Yah kess v2 genuone is expensive thousands of dollars depending on number of vehicles covered and you also need to purchase flash credits, kess v2 master even more expensive, bit it covers a lot of vehicles.
An oft is actually a alientech powergate 3 lcked down to a small vehicle list. The powergate 3 can acutally program almost same list as a kess v2 but only one vehicle at a time
Alientech male good equipmemt
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Tristor (07-19-2019), why? (07-19-2019)
Old 07-19-2019, 10:44 AM   #31
Breadman
Drives: 2017 BRZ w/PP
If you'd like to get tuned by Bill, you contact DT. If you'd like to be tuned by Zach, you contact CSG.
I believe the e-tunes from Feb 2019 on have all been done by Bill!
how does that work? wouldnt zach be unable to access the old CSG/DT tune since DT has the key?
The Following User Says Thank You to Breadman For This Useful Post:
JeremyR (07-19-2019)
Old 07-19-2019, 10:56 AM   #32
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Why would he need to be able to access the old tune? Zach makes his own tunes now.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
CSG Mike (07-19-2019)
Old 07-19-2019, 03:40 PM   #33
CSG Mike
CSG Mike's Avatar
If you want Zach to do your new tunes, you'd also be on newer base maps. And correct, Zach does not have access to any DT maps.
CSG has already developed a full library of base maps from scratch integrating brand new IP. Additional features and failsafes have been integrated that previously could not be integrated into DT's tunes due to the older implementation methodology. The knowledge we have now vastly exceeds what was known in 2015 when the [Ace] base maps were originally developed. CSG's rigorous testing regiment will only continue to evolve moving forward, and tunes will continue to be updated as we discover more.
Old 07-19-2019, 06:39 PM   #34
Breadman
id like to retrospectively retract my last post. i was hungover and couldnt comprehend english
Will the FR-S end up on the list of the "10 slowest sports cars of all time"? Davyator Scion FR-S / Toyota 86 GT86 General Forum 30 10-10-2014 07:59 AM
Toyota "T" Formed Aluminum Epoxy Steering Wheel Airbag Emblem Badge Interest List fooddude Cosmetic Modification (Interior/Exterior/Lighting) 22 06-18-2014 02:47 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Finally used the "ignore list" feature of vBulletin infinite012 Off-Topic Lounge 0 06-06-2013 08:20 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 03:53 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
