Old 11-25-2015, 03:30 PM   #127
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by liquidsky44 View Post
Thanx but now I gotta add spacers. The wheel does not flush with the fenders with the cambers I'm running.
Well that is another problem and that is more due to the offset of the wheels than the BBK
Old 11-28-2015, 12:04 AM   #128
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
Sparco Terra
16x7 +50: http://www.ft86club.com/forums/showthread.php?t=57975
Essex/AP Sprint Front
Looks like it will fit! Clearance is about 2 or 3mm to the spokes and a good 6-10mm to the wheel weights (sorry, I didn't measure).*
*The template's hub looks like it was designed for a slightly larger bore, so this may be off by a millimeter or two. The right side bent a little more than the left, so the true measurement should shift outward, giving a little more room to the spokes and a little less to the wheel weights. If anybody can confirm this, it would be appreciated.
Essex/AP Endurance Front
Will not fit. The barrel is too narrow.
(Both pictures feature the Sprint template.)
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 11-29-2015, 03:52 PM   #129
ThatBlueBRZ
ThatBlueBRZ's Avatar
Drives: 2015 Subaru BRZ
I've got front and rear Stoptechs BBK. Front is 328x28mm and rears are 345x28mm. I'm sure the fronts with 328x28mm will fit over a 17" wheel diameter without any rubbing from the callipers to the inner wheel well of the rims. I am just worried about the rears with 345x28mm. Has anyone tried the rears over a 17" wheel? Thanks in advance!
ThatBlueBRZ is offline   Reply With Quote
Old 05-10-2016, 10:53 AM   #130
Race
Race's Avatar
Drives: 2015 BRZ Limited 6MT
I can confirm that the StopTech 328x28 ST40 front brakes clears the following two rims without spacer.
O.Z. Leggera HLT 17x7.5 ET35
http://www.tirerack.com/wheels/Wheel...ight+Race+Grey
Enkei Fujin 17x7.5 ET40
http://www.tirerack.com/wheels/Wheel...=Black+Painted
I didn't take pictures but there are adequate rim clearance and lots of spoke clearance for both wheels.
Race is offline   Reply With Quote
Old 06-04-2016, 01:22 PM   #131
asnatlas
Drives: 2013 - BRZ - SWP
Post
Originally Posted by F1point4 View Post
OEM Wheel
17x7 ET48: http://www.ft86club.com/forums/showp...39&postcount=3
Stoptech Front 328x28 ST40M Kit
20121012-86OEMWheelBBKTemplates-4 by VictorN07, on Flickr
Would 5mm spacers work or would I need 10mm (or larger)? Also would I just need need spacers on the front or should I do all 4 corners with the same spacer size ?
asnatlas is offline   Reply With Quote
Old 06-07-2016, 10:36 AM   #132
asnatlas
Anyone know the minimum spacer size needed for the Stoptech Front 328x28 ST40M kit with OEM wheels ?
Old 08-06-2016, 03:22 AM   #133
Eazy-V
Anyone running BBK on 17x9.5 +40 TE-37RT?
Eazy-V is offline   Reply With Quote
Old 11-07-2016, 11:31 AM   #134
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
anybody here has the Project Mu brake kit (FS44-F103B)? or anybody knows how they make those templates? need to find out how is fitment with the RPF1 18x8 +35 since i just placed an order on the PMU.. need to know if i should order another set of wheels if there will be fitment issues
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 11-07-2016, 11:37 AM   #135
byun
byun's Avatar
Drives: 2015 BRZ CWP
I test fitted the those on my Stoptech 355 BBK Front and it clears with a few mm of clearance, would definitely have to be careful where you place the wheel weights.
byun is offline   Reply With Quote
Old 02-22-2017, 08:28 PM   #136
eromsdal
ERO
eromsdal's Avatar
Drives: '16 Subaru BRZ Series Hyperblue T
I'm not sure if I missed it or not, I'm still getting used to using the forums on my iPhone but has anyone confirmed fitment of the STI Brembo BBK with enkei rpf1's 18"x9.5" +38? Thank you
eromsdal is offline   Reply With Quote
Old 04-03-2017, 08:09 AM   #137
akatosh
Drives: Toyota 86/2017 & Volvo S60 T6
AP sprint kit with 2017 OEM wheel (17x7 +48). Would fit with > 15mm spacer.
akatosh is offline   Reply With Quote
The Following User Says Thank You to akatosh For This Useful Post:
funwheeldrive (06-26-2017)
Old 06-26-2017, 12:24 PM   #138
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Rpf1 17x9 +45 do fit the AP Sprint kit with 10mm spacers. On extended lugs of course.
3mm clearance
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
The Following User Says Thank You to jbailey8748 For This Useful Post:
Old 06-26-2017, 01:42 PM   #139
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
AP Racing 4-Pot Factory BBK clears both the 18x9+40 FF15 (HRE), and the 17x9+40 6UL (949 Racing) with room to spare. It also clears the stock wheels, as designed.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-19-2017, 03:25 PM   #140
SpartaEvolution
SpartaEvolution's Avatar
Drives: NSX, G35, E36 328i racecar
Thank you for making this thread! I'd like to add our fitment templates to the list:
Front:
4 piston 330mm
86 Front 4P 330mm Fitment Template.pdf
6 piston 355mm
86 Front 6p 355mm Firtment Template.PDF
Rear:
4 piston 355mm
86 Rear 4p 355mm Fitment Template.PDF
SpartaEvolution is offline   Reply With Quote
big brake kit, brembo, essex, stoptech, template
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 10:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) -- General Topics 727 03-17-2013 07:29 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) -- General Topics 13 03-01-2012 12:56 PM
