05-23-2015, 12:09 AM | #85 |
Manny
Drives: 13 WRB Brz
It also looks like you have some grime or rust built up in there.
05-23-2015, 12:17 AM | #86 |
Drives: 2014 Subaru BRZ
I have the allen wrench being held as well with no luck. I'll use the WD and see what happens. I even tried an impact wrench and didnt do a think. lol
The Following User Says Thank You to adrixe For This Useful Post: | brz408 (05-23-2015) |
05-23-2015, 06:32 AM | #87 |
Drives: 2014 BRZ Premium - SWP
Shouldn't be that hard to break loose. Are you turning the correct way? Put a breaker pipe/bar on the socket wrench to get more leverage and have someone else hold the allen key. Rust shouldnt get in there if the dust cover is on... should take some force, but nothing close to loosening lug nutz per say.
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
05-23-2015, 06:40 AM | #88 |
Yeah i thought it's going to be easy to loosen the nut. I'll put some wd40 to see if it helps. No rust in the bolt.. yeah I'm turning the correct way. Counterclockwise.
05-23-2015, 07:00 PM | #89 |
Drives: 2017 Cayman S
Have you tried to remove the rear nuts yet? Just wondering if you experience the same thing there. There was no lactate on mine. As the other guy said, not much force is needed at all. WD-40 might work (blue can), but if it does not get a "true" penetrating spray. WD-40 does make a penetrating spray that comes in a silver can.
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
05-23-2015, 09:56 PM | #90 |
Thanks guys! Wd40 worked for me! Took me 7 hrs to finish installing my prokits. Those abs sensors drove me nuts!! Thanks again for the advices.
05-24-2015, 11:10 AM | #91 | |
Took me about 4.5 hours if i remember correctly. I was able to swap out the front springs without removing the strut from the wheel hub. I was able to lean the assembly outward and mount the spring per some other posted recommendations.
06-06-2015, 11:22 AM | #92 |
Drives: WRB Subaru BRZ Limited MT
What would happen if you spun the strut? would that cause damage for sure? of just a small risk of leak?
07-10-2015, 01:34 PM | #93 | |
Drives: 2013 Scion FR-S - Argento
If you use a jack under the LCA, it would compress the springs and let you get the bolts through the LCA easier. I did this, except I didn't have a second jack and my existing one was holding the car up. My "jack" was my own arms and chest pushing like an SOB on the LCA until I could get the bolts through. But I'm not sure I understand how you could not compress them anyway even if it is just by letting the car back down onto the ground. As long as the shaft pokes through the right hole to get the nut back on, there's nothing that can go differently that I can tell. I have noticed recently my right front will sometimes make a single clunk noise at very low speeds such as parking. I'm going to mess around with it a little when I get a moment. |
07-11-2015, 12:10 PM | #94 | ||
Drives: 13' AVO Whiteout
To preload you would need to use a coilover compressor (different from a spring compressor.. But you can reverse the tangs to make a spring compressor work) on the springs, install the shocks onto the lca then the top nut, then remove the compressors.. OR Use another jack under the lca when installing to ensure you are taking all and any rebound out of the shock so you have a fully seated top nut. |
07-12-2015, 11:51 AM | #95 |
Drives: 2013 BRZ DGM
That's awesome, I've wanted to do this, ever since I say it being done for rally service. It's good to know we can do it with our rides and just to echo to OPs warning, it is very vehicle specific!
07-12-2015, 09:18 PM | #96 | |
08-06-2015, 10:12 AM | #97 |
Drives: Scion FRS
Brother you are a saint, thanks for this write up
Just here to learn.......and laugh
08-13-2015, 05:51 AM | #98 |
Still 17!
Drives: 2014 Silver BRZ Limited
Thanks for this! Very helpful.
EDIT: After reading this thread late last night....and thinking about how I'm fifty and this may not be possible too much longer! Ha ha!! (No really!..not kidding..) I changed my stock top hats to Whitelines today by myself in a parking lot with the car jack, some wood pieces and some hand tools! Since I was only changing the top hat, all I had to undo was the top hat nuts, top strut nut, sway bar nut and wheel. Couldn't have done it without you guys! PAX Last edited by MGPAX; 08-14-2015 at 12:38 AM. |
Similar Threads | ||||
Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
Exhaust MP/FP (flange/spring bolts) install help! | rbizzle004 | Engine, Exhaust, Transmission | 9 | 03-04-2013 11:34 AM |
East bay shops for spring install? | WillBRZ | Northern California | 9 | 02-21-2013 02:03 AM |
Selling stock strut/spring assembly | SleekMachine | Brakes, Suspension, Chassis | 16 | 12-13-2012 08:03 PM |
vibration after spring install? | sajonf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-30-2012 02:30 PM |
