Software Tuning Discuss all software tuning topics. |
02-11-2018, 07:24 PM | #29 |
Drives: 2015 RS 1.0(Totaled) 2017-BRZHaSNoW
I don't know what a definition file is?
D4FD = DRIVE 4 FUN DAILY
02-20-2018, 04:23 PM | #30 |
Drives: 2017 Toyota 86 860 Special Edition
02-20-2018, 04:26 PM | #31 |
I tried to share it with google drive. https://drive.google.com/file/d/1TdF...ew?usp=sharing
Let me know if you have trouble accessing it. Last edited by supercommode; 02-20-2018 at 04:43 PM. Reason: adding file to share |
The Following User Says Thank You to supercommode For This Useful Post: | mizzta21 (02-20-2018) |
02-21-2018, 01:36 PM | #32 |
Drives: DGM '17 PP BRZ
I'm running the Stage 2+ E85 v3.02 tune as of yesterday. My car is fully stock besides a catback. It is seeming to run pretty smoothly. Idle is a little strange; rpm will jump between 950-600rpm but besides that, it's stable. I also changed the Advanced Timing table B to make the car pop at engine load 0.15. So far so good!
02-27-2018, 04:05 PM | #33 | |
02-27-2018, 04:41 PM | #34 |
Drives: #337 2017 Toyota 86
You can safely run the Stage 2+ E85 tune with stock headers. I've done quite a bit of dyno testing with it as well.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
03-02-2018, 09:36 AM | #35 |
Update: Idle got better over time. Sometimes I'll get a CEL (P0171) for a lean idle when I let the car idle for a bit after a cold start, but once its warm its fine. So far no complaints. Only thing is I noticed that the MPG calculator is definitely off. I go through a tank in 4 days and it shows similar MPG to what i was getting on 93.
03-02-2018, 11:01 AM | #36 | |
Drives: FT86
If you have stock intake vand your ethsanol content is between 60-90% you should not be throwing lean codes. check your ltft and also commanded afr vs actual afr during acceleration to correct mpg readout see here Correcting In dash fuel economy readout when on E85 On OFT tunes the in dash fuel economy display will read 25-30% off on E85,to correct this adjust the Fuel_Multiplier_Display_Offset Table as per below (original values with 30% added) you may need to adjust this percentage slightly if you find the readout is still differs from actual Note in your Definition the "Fuel Multiplier Display Offset" Table may be under the "BRZ ALPHA" folder |
Similar Threads | ||||
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit | FullBlown | Forced Induction | 47 | 06-20-2018 02:38 AM |
Innovate Stage 1 Supercharger with stage 2 accessories | azynneo | Engine, Exhaust, Bolt-Ons | 3 | 08-30-2016 12:32 AM |
Exedy Stage 1 Failure: Advice + Stage 2 Questions | Pneub | Engine, Exhaust, Transmission | 4 | 07-18-2016 09:24 PM |
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! | FullBlown | Forced Induction | 119 | 03-24-2015 10:16 PM |
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 | Astroboy | Forced Induction | 4 | 03-01-2014 07:29 PM |
