Software Tuning Discuss all software tuning topics. |
08-31-2021, 10:52 AM | #15 |
08-31-2021, 11:07 AM | #16 |
Drives: 2016 GT86 N/A
08-31-2021, 01:17 PM | #17 |
Drives: Subaru BRZ 2016
Thanks. I purchased a Wayne tune too, but I feel I could get a bit more out of the JDL 4-2-1 in the 3500-4500 rpm range.
The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (10-07-2021) |
10-07-2021, 08:32 AM | #18 |
Hey, did you also tried the stock oft stg 2+ tunes and can you compare? I also feel like there is a bit more to get out of the tune, but I wonder if the wayne tune (I guess Stg2 ACE) would do the job
10-07-2021, 11:14 AM | #19 |
Drives: brz 2017 hksv2
email wayno to check your tune and try to squeeze more out of it
The Following User Says Thank You to tomm.brz For This Useful Post: | J95 (10-10-2021) |
10-08-2021, 02:21 PM | #20 | |
edit: I looked back at my logs and what I ran was a hybrid of V4 Stage 2 and Stage 2+, with the exhaust VVT being the average of the two. Overlaying all my data I would say that the Wayne EL maps appear to produce a VE that is a bit higher from 4400 rpm and onwards. Last edited by NicFromTheNorth; 10-12-2021 at 12:18 AM. Reason: revised answer |
The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (10-10-2021) |
10-10-2021, 07:08 PM | #21 |
that s why you should stop wasying time with VVt and just scale well the maf sensor, lean out a bit the afr and put more timing until it knocks
10-12-2021, 10:59 AM | #22 | |
I´m using JDL EL 4-2-1, uncatted |
10-13-2021, 03:31 PM | #23 |
@J95, I would suggest spending the 60$ for the Wayne tune and perhaps follow his procedure for adjusting the MAF scaling. Then you could log engine knock and reduce ignition timing if necessary. Otherwise, as tomm.brz suggested, adjusting the variable timing maps can lead you to a path of many ECU reflashes...
10-13-2021, 07:49 PM | #24 |
Drives: 2020 Toyota GT86
Is there much benefit to a Wayne tune for a car with a basic catted UEL (FT-86 SpeedFactory)?
I keep debating it, but don't really have an understanding of what the positives are. I have no issue with the cost, just want to understand what Id be getting for the money!
This post sent using 100% recycled electrons.
Similar Threads | ||||
Header/Tune Decision | Jakinit | Engine, Exhaust, Transmission | 50 | 01-15-2019 09:50 PM |
UEL HEADER W/o tune | turtlefeeder | Engine, Exhaust, Transmission | 10 | 11-29-2016 03:46 AM |
Header without a tune | eddiev116 | Engine, Exhaust, Transmission | 73 | 02-07-2015 06:01 PM |
Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
FI or Tune and Header? | RSH | Engine, Exhaust, Transmission | 30 | 10-23-2013 05:09 PM |
