Old 02-07-2017, 05:22 PM   #15
SubieRumble
RWD Snob
SubieRumble's Avatar
Drives: 2014 Ultramarine FRS MT
Probably the one that bothers me most is the idle or slow to acceleration, once I'm hard on the gas it's a tiny bit harder to notice.
Slow car fast. > Fast car slow.
SubieRumble is offline   Reply With Quote
The Following User Says Thank You to SubieRumble For This Useful Post:
Calum (02-08-2017)
Old 02-07-2017, 06:48 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
wait, the pedal dance will remove the delay?
I thought it was just an after effect of the stupid drive by wire.
Old 02-07-2017, 11:21 PM   #17
Ultramaroon
義理チョコ
Ultramaroon's Avatar
Nope. Prepare to be amazed. It acts like a regular throttle. Been preaching this for a couple years.
funwheeldrive (02-08-2017), SubieRumble (02-08-2017)
Old 02-08-2017, 12:09 PM   #18
continuecrushing
OMG. This just blew my mind.
Other than the clutch (which you can't feel at all) the throttle lag has been the only? (that I can think of right now lol) complaint about this car. Holy cow.
Old 02-08-2017, 12:48 PM   #19
Ultramaroon
義理チョコ
Did you try it? It's subtle but very real.
Now, for the clutch, have you seen my one and only mod thread? I'm not really excited about the SS braided line but what the hell.
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control
Old 02-08-2017, 01:26 PM   #20
continuecrushing
Yeah, I've swapped the slave and removed the spring. Still very unhappy with the clutch feel. It works, but most other cars I've owned/driven you could really feel when the clutch starts to engage. I feel like this car kills that some how. I've learned to live with it haha.
Old 02-08-2017, 01:44 PM   #21
SubieRumble
RWD Snob
Did you lower the engagement point as well? I hear that make a world of difference.
I have the Mtec clutch spring in order, gonna adjust when I do the install.
Old 02-08-2017, 01:45 PM   #22
JoeC
Drives: Subaru BRZ Limited
Have you removed the clutch helper spring from the pedal assembly. it makes a world of difference. There's a sticky somewhere with instructions. I think it took me all of 10 minutes.
JoeC is offline   Reply With Quote
Old 02-08-2017, 01:50 PM   #23
SubieRumble
RWD Snob
Umm...
Ultramaroon (02-08-2017)
Old 02-08-2017, 02:32 PM   #24
Ultramaroon
義理チョコ
Yeah, it's better but not wonderful. I understand that the clutch was specified for the torque limit of the transmission, which makes sense. I wonder if all other things being equal, just installing a stronger pressure plate would do the trick. Not anything radical, just one with a bit more spring constant.
Anyhow, to OP, apologies for the thread jack. This is about throttle response.
Old 02-08-2017, 02:34 PM   #25
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by jsimon7777 View Post
Time for a standalone ECU!
Well, that or buy one of these.
http://www.ft86speedfactory.com/mig-...ator-2007.html
Old 02-08-2017, 02:37 PM   #26
Calum
That Guy
Originally Posted by SubieRumble View Post
I have searched and searched, but there doesn't seem to be too much information on fixing the slight delay between pushing in the gas pedal and the engine revving. Occasionally I find myself yearning for my old 240's instant response.
I have a K&N filter, Gruppe-s UEL header and the Openflash Tablet with OTS stage 2. Is there anything I could do to eliminate or lessen throttle delay?
Thanks.
If you haven't done the clutch mods start with that. I know it sounds stupid, but even with a tune the gas pedal drove me nuts. I didn't notice it nearly as much when I took out the spring in the clutch pedal. I still haven't done the slave cylinder mod though, I actually like the clutch like this.
Old 02-08-2017, 02:42 PM   #27
Calum
That Guy
Pedal dance. Cut the vehicle stability system out of the circuit. It's my pet peeve so I'm the guy that does it even in stop&go traffic.
Are you running a tune or stock?
Delicious Tunings latest (to me, I haven't seen my car in a few months) tune seemed to fix the garbage low load throttle response. I'll take the occasional bucking of an undamped throttle over the stock feel any day.
The Following User Says Thank You to Calum For This Useful Post:
Old 02-08-2017, 02:49 PM   #28
Ultramaroon
義理チョコ
I'm bone stock. Been threatening to start tinkering for a long time. I'm leaning toward first learning how to swap ECUs so I know I can quickly get back to stock if I brick my beater one. I'm chicken.
Calum (02-08-2017)
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle delay after OpenFlash Kody Software Tuning 34 02-25-2020 03:44 PM
Throttle response delay jay07631 Engine, Exhaust, Transmission 12 07-09-2013 09:41 PM
