08-15-2014, 12:53 PM | #169 | |
Done
Drives: WRB BRZ
08-15-2014, 04:13 PM | #170 |
Drives: Car
08-15-2014, 04:35 PM | #171 | |
08-15-2014, 05:17 PM | #172 | |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
The Following User Says Thank You to jebuwh For This Useful Post: | wparsons (08-15-2014) |
08-15-2014, 06:58 PM | #173 |
Drives: BRZ Pearl White
Once more into the breach:
http://www.motortrend.com/roadtests/...?__federated=1 I don't expect anyone to quibble with this driver's expertise. The BRZ is quicker, same day same driver same track. The ONLY difference is the BRZ has softer rear springs. The suggestion that the dampers are different has been disproved by others posted to this BB I believe. The driver's comments as to how the two cars feel and why the BRZ is likely faster are interesting. Even more interesting would be testing the BRZ against itself with just a stiffer front bar. Should be even quicker because it will get its meagre power down a split second earlier. Note the lap time margin is around 0.8 seconds, twice the margin achieved by fitting a clutch type lsd. Tire pressures can be used to tweak handling, and the F1 boys do this also. In this case likely increasing the rear tire pressures is the way to go as tire pressure increases grip and does not affect roll stiffness. Ditto lowering which changes the load transfer effects and in theory at least keeps the inside tire working harder for longer. Ironically, lowering reduces the load transfer which some here seem to think would be bad for handling. Indeed, although I don't know the camber rise rates on these cars it seems very likely that front camber rise is at a lower rate than rear camber rise. If so then a quick and easy way to get better handling is to lower the car, assuming rear camber rise is at a higher rate but does not pass over the critical point. This would increase rear grip relative to the front and as long as you don't go crazy with spring rates you will improve front to rear balance in favour of understeer and go faster. Us old guys already have trouble getting up to street level from the driver's seat so lowering the cars is not going to work well for us. |
08-15-2014, 07:28 PM | #174 |
Off Topic
This thread is no longer about your wildly inaccurate suppositions; it's about actual suspension advice from knowledgeable people with documented backgrounds in the fields of suspension tuning and driving fast. And correcting @7thgear's grammar. Kindly shove off.
08-15-2014, 07:31 PM | #175 |
08-15-2014, 07:31 PM | #176 | |
i'm sorry, what?
Drives: Canada
my grammar may be off at times but you bitches can't touch my flair
08-15-2014, 07:33 PM | #177 | |
08-15-2014, 07:36 PM | #178 |
Yes, but what did you try first?...whatever.
If you lower these cars without doing anything else you move grip to the rear so you can then tolerate more rear roll stiffness. Add camber plates up front and you're back where you started. It is complicated if you are trying to change too much. I just cut half an inch out of the rear bump stops, nice and simple, really safe and it works. Cheap too, especially if you do it while changing the rear shocks. The bump stops are only CDN$15 each if you want to keep your old ones intact. |
08-15-2014, 07:37 PM | #179 | |
Changing roll bars can't change weight transfer quantum. |
08-15-2014, 07:39 PM | #180 | |
Weight transfer results from the CG height over the roll axis height (the lever arm) x lateral g. Roll bars have no effect on this number. Neither do springs. Only tire grip can increase lateral g, assuming you can get the power down. |
08-15-2014, 07:40 PM | #181 | |
Funny, you claimed stiffer damping made it less tail happy (which is false). Just give up already.
08-15-2014, 07:42 PM | #182 | |
Tags |
225 width perf snow tires, 7thgear haz flair, i'm afraid of the snow, lawyers can't drive, magical suspension expert, my first period, überstupid |
Similar Threads | ||||
How to do E85 correctly? | Anthony | Engine, Exhaust, Transmission | 95 | 12-11-2017 04:06 PM |
Perrin 3" CBE - did I install correctly? | 1Cor10:23 | Engine, Exhaust, Transmission | 14 | 12-08-2014 12:29 PM |
Boost gauge not reading correctly | Pneub | Forced Induction | 11 | 10-30-2013 12:39 PM |
Drive Away prices on Toyota Website. Make sure you are not getting Ripped Off! | Aventador87 | AUSTRALIA | 8 | 06-17-2012 07:35 AM |
Toyota 86 first drive review (Car Guide) | a6ela | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-14-2012 12:34 PM |
