03-31-2015, 08:11 PM | #2689 |
Drives: 2014 BRZ
If anybody cares I did some testing today with HR 5mm spacers. I just wanted to confirm you need to install longer studs to run these spacer...and you do. On the stock setup I get about 10.5 rotations unill the lug is torqued. Add the 5mm spacer and I get 6.5 full rotations. The minimum recommended is 8 turns so proceed at yor own risk but I am going to install the longer studs that came with the spacers.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
03-31-2015, 08:38 PM | #2690 | |
Drives: In Perfect Control At All Times
With my Technocast wheels I get 9 turns... that's supposed to be enough, but I wish I bought ARP studs that are actually a useful length. The stud swap is pretty easy though. Someone advised me that I'd have to remove the hubs to get the studs in and out, but that certainly was not that case. |
03-31-2015, 08:40 PM | #2691 |
Drives: 2014 BRZ
Big money? It was 120 bucks for all 4. I didn't think that was bad. As long as I get 8 turns I'm happy.
03-31-2015, 08:52 PM | #2692 |
The Stig's German cousin
The ARP studs are worth it. I run an 8mm spacer right now and have room to go longer if I want. They also have a tapered section at the end with no threads that makes it extremely difficult to cross thread a lug - one of those things you don't realize how nice it is until you have it.
03-31-2015, 10:09 PM | #2693 |
I did the ARP studs this weekend as well. Nothing too difficult, but not exactly a fun install either. Impact wrench was a big help in using the washer method for installing the new ones, which I did with the front hubs on and rears off (rears are way easier to remove anyway). Great peace of mind knowing that these will stand up to tons of wheel swaps and accommodate whatever spacers I need to get max track width.
04-01-2015, 12:15 AM | #2694 |
I paid 180. There are generic 5mm spacers at my local shop for $40/4. Not a huge loss I agree, but I regret my choice and will be ordering ARP with my next set of wheels.
04-01-2015, 03:32 AM | #2695 | |
Drives: 2014 FR-S
12x1.25 stud would give you 10mm of engagement for 8 turns. You should ideally have 12mm or more for maximum strength. I've never measured stock studs, now you've got me curious. Mark |
04-01-2015, 09:12 AM | #2696 | |
I believe the stock studs with stock wheels get that 10 turns (12mm) |
04-01-2015, 11:49 AM | #2697 | |
i'm sorry, what?
Drives: Canada
thank you for this. so if no protests were made at your event, even though you made it known to your competitors, is this a precedent that you could use at future events? Is this a precedent I could use in Canada? when do you think the dust will settle on this issue, or is it going to be one big unknown for the next 2-3 months? our first regional in early May, so I have a month to decide if I want to start an arms race up here. Since our main series is essentially just one big PAX championship, a lot of people are going to be getting cheeky with me if I follow through.
04-01-2015, 12:23 PM | #2698 | ||
Drives: 2014 FR-S
Canadia? Quote:
-Mike
#24 CS/CSR |
04-01-2015, 12:29 PM | #2699 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
04-01-2015, 12:40 PM | #2700 |
Senior Citizen
Drives: Scion FR-S
The Following User Says Thank You to simpleisbest For This Useful Post: | Shark_Bait88 (04-01-2015) |
04-01-2015, 01:21 PM | #2701 | |
Drives: SSC #79
The SEB call is typically before the end of the previous month, then anything discussed is printed in the next Fastrack around the 20th of the month. So any decision would be based on what information they had before the end of March. Based on what I've seen, it would not surprise me that they announce the parts legal for the 2014s & 2015s only. Mike |
04-01-2015, 02:09 PM | #2702 | |
Edit: The springs are brand new, never installed. Guy bought them, got bigger wheels (which filled out the wheel gap enough for him) and is apparently in need of money; which is why he's selling the springs.
Similar Threads | ||||
Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
