Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-06-2018, 03:17 PM | #15 |
Drives: BRZ 2017 Pure Red, MT
The 2017 MY are supposedly harder to close because they made the gas shocks harder to better support the wieght of the aluminium wing. But I think they made them a bit too hard.
11-06-2018, 03:45 PM | #16 |
Drives: 2017 BRZ
My '17 takes a lot more effort than my '14 did. Stupid amounts more. Not to get it to shut, but to actually latch successfully.
If you have the wing, doing this will cause it to dent the trunk in the middle.
11-06-2018, 04:25 PM | #17 | |
Just the tip
Drives: 2017 DGM BRZ
I'm guessing the middle of my trunk is pretty dented by now |
11-06-2018, 04:27 PM | #18 |
Drives: 2017 BRZ
Yeah, I noticed mine is dented. I'm not the only one that has closed the trunk, so who knows when it happened. Stupid design.
11-06-2018, 05:15 PM | #19 | |
Drives: 2017 BRZ PP WR Blue
I will check and see if the trunk is dented under the spoiler bumper. If I push down from either side instead of from the middle, it won't latch. I took the latch apart once but it did not seem like there was any adjustability unless I start modifying things... |
11-06-2018, 06:42 PM | #20 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I just went out to my car... and the rubber piece is starting to split yet again.
11-06-2018, 06:50 PM | #21 |
Country Boy 4 Life
With junk in my trunk that didn't allow it to close nicely, I slammed it shut and cracked my tail light. Stupid. I would suggest not doing this...
I LIKE TIRES! |
11-06-2018, 07:35 PM | #22 |
The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (11-06-2018) |
11-06-2018, 08:19 PM | #23 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I should also clarify, I said mine was hard relative to the doors, but it's still not terribly hard, from wide open I just put one finger in the cowboy hat and shut it in one motion. The only times I've had it fail to latch is when I tried to give it a swing and let it go, the struts just completely slow it down. (Edited for autocomplete shenanigans) Last edited by RZNT4R; 11-07-2018 at 05:37 AM. |
11-06-2018, 09:15 PM | #24 |
11-06-2018, 09:23 PM | #25 |
btr.life
Drives: 2022 GR86
My '17 BRZ did the same thing when I first got it. Never had the issue with my '13 FRS but I did buy that one used.
It seems like eventually things "break in" with the latch mechanism and now the trunk lid shuts nice and smooth. I seriously thought my trunk was broken or defective it was so hard to shut when I first bought it.
11-07-2018, 03:04 AM | #26 | ||
But yeah, first night I had the car I left the trunk 'open' overnight because I thought I closed it, only to find out in the morning it hadn't latched.
Instagram: @spike.brz
11-07-2018, 11:48 PM | #27 |
26 posts commenting on shutting the trunk lid on a car. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | spike021 (11-08-2018) |
12-22-2018, 10:42 AM | #28 | |
Drives: Silver 2017 Limited with PP
If you look at the rubber bumper notice how the arm where it seats pivots up higher than one would expect and the rubber is contacted at an angle, almost at a 45 degree. I would think that moving the arm down a bit, maybe by putting a little rubber on the arm stop to prevent it from going up as high. in any case the striking of the rubber is not an a ideal angle, this explains the rubber not lasting, and the effort required. I will take a closer look soon by removing the plastic. |
Similar Threads | ||||
2017 Toyota 86 Trunk Lid | GrayFox_27 | Want-To-Buy Requests | 0 | 06-23-2018 01:48 PM |
Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 06:09 PM |
TRADE: 2017 BRZ trunk and wing for wingless trunk?? | Moto | CANADA | 0 | 05-19-2018 04:21 PM |
WTT 2016 limited trunk for 2017 trunk | Ignore Your Doctor | Southeast | 0 | 08-27-2016 10:32 AM |
