Old 12-06-2019, 06:56 PM   #8765
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by jflogerzi View Post
Is the connector for the Perrin cold intake to the stock plastic intake where the sensor sits custom or can you still buy it?
The maf housing is part of the perrin intake and connects using the rubber coupling sprintex kit already uses to connect to stock intake nothing special or extra you need. Direct easy bolt on.
Old 12-07-2019, 01:16 PM   #8766
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by 86TOYO2k17 View Post
I read with ecutek same as you, I'm at or below ambient whenever i go wot. Never had car feel “heat soaked” or down on power, even after fully warming car up then doing 10 back to back 20-80mph pulls as quickly as possible in 85F weather. Obviously not a autox or track scenario. But good enough to know it will never have issues in any daily driving or spirited driving conditions.
That intake temp has little to do with charge temps though. I monitor charge temps in the manifold, and there is a reasonable difference (+20-30C - more if you're on it constantly) once you get on it. You need to move the IAT sensor though.
I am never at or below ambient... Where do you have your IC mounted? I wonder if my pump is not functioning correctly... Are you also still using the stock snorkel in the bumper?
The IAT sensor, unless you've added a new IAT sensor in the manifold, just takes the air temp at the start of the system as it's part of the MAF. So pre-compression, which adds a fair bit of heat before the IC, which is inside the intake manifold, takes some of it back out.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-07-2019, 02:37 PM   #8767
86TOYO2k17
I thought it was apart of the MAF but find it weird that it drops substantially when i spray WMI post MAF, and that my IAT are also a lot lower then jflogerzi. Also doing extensive testing in attempts to heat soak my system (given not as extensively as a track Would be) logging all temps, knock, and acceleration times i saw no real difference from pull 1 vs pull 10, aside from fluid temps increasing a little. But no increased knock counts, pulled timing or decreased acceleration the main signs/symptoms of heat soak.
Old 12-12-2019, 12:43 AM   #8768
jflogerzi
jflogerzi's Avatar
Did Jon bond make something to do this? I am guess if you get more accurate temps the ECU is less likely to pull timing etc..
2013 Series 10 FRS #553
Old 12-14-2019, 11:59 AM   #8769
jhalagian
Drives: 2015 brz
I have a general question in regards to cooling mods. Heat soak is obviously well documented with this kit but I was curious to know in order what would be the most effective to least effective mods to combat the heat soak. FYI this would be for a DD build. Much appreciated.
jhalagian is offline   Reply With Quote
Old 12-14-2019, 12:42 PM   #8770
ls1ac
ls1ac's Avatar
Just my experience, DD especially in Canada it will be hard to heat soak. Even if it happens you will only loose a little power. On a track where time is critical, this would be important.
Just drive it and if your style changes, address the problem. I have one of the first in this country and have tracked it regularly with no problems.
The Following User Says Thank You to ls1ac For This Useful Post:
jhalagian (12-14-2019)
Old 12-14-2019, 01:10 PM   #8771
jflogerzi
jflogerzi's Avatar
If you have the IC kit and e85 you will be fine for a DD. If not 93+WMI will be almost just as good
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 12-14-2019, 01:24 PM   #8772
86TOYO2k17
WMI has better cooling properties then E85 but worse high octane/knock resistance benefits.
E85 and methanol are alcohols with similar octane and they burn and combust at lower temps compared to normal gas. decreased combustion temps will slow and reduce heat soak which will reduce IAT more indirectly. Obviously with WMI you are spraying in addition to 91-93 gas so the octane and combustion temperature benefits are diminished. But with WMI you are spraying water directly into the intake/manifold and this dramatically reduces the temp of the air going into the manifold, supercharger compressor, combustion chamber and eliminate hot spots so you have colder IAT and a colder starting cylinder temp, but then a higher combustion temp. They are both effective at reducing heat soak, IAT, and overall temps but generally WMI is better at cooling because of the water and E85 is better at making power because higher effective octane.
Full bolt ons +69mm pulley you can expect roughly
300whp E85
265-275whp 91-93 w/ wmi
260whp on 93
255whp on 92
250whp on 91
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
jhalagian (12-14-2019), LOJOKO (01-06-2020)
Old 12-14-2019, 02:43 PM   #8773
86TOYO2k17
Thats somewhat difficult to say just because we don’t have an accurate way of knowing for sure what IAT truly are post IC unless you tap a sensor into the manifold, which idk anyone that has.
But WMI and/or E85 will be the most effective by far as well as the intercooler kit. And should be more then enough for a DD.
Hood vents, hood scoop, gold reflective heat wrap, as well as keeping oil/coolant temps down as everything can/will eventually effect each other through thermal dynamics. CAI might help but we have one from factory so hard to say if an aftermarket one helps IATs or not.
Old 12-14-2019, 08:22 PM   #8774
kev0
Drives: '14
Anyone find the Sprintex technical support take a while to respond? I emailed them about a replacement bypass actuator and they have replied to my initial email, but I asked them another question and it's taking them 10+ days to respond. Still nothing from them yet..
kev0 is offline   Reply With Quote
Old 12-14-2019, 08:46 PM   #8775
jflogerzi
jflogerzi's Avatar
Call them directly
Old 12-15-2019, 09:46 AM   #8776
sam69
Drives: GT 86
I tapped into the manifold post intercooler and the temps were High hence whey I made the water jacket .
Will try and find the notes I took but seem to remember somewhere in the 80 to 85 degrees C on a 40 C day
sam69 is offline   Reply With Quote
Old 12-15-2019, 11:55 AM   #8777
86TOYO2k17
You are probably one of few people who have.
What was temps after jacket install?
How long did it take your temps to get that high?
Old 12-18-2019, 04:17 AM   #8778
tzbang
Drives: 2013 GT86
Hey guys. I finished my install tonight and flashed the computer with Xero-Limit tune. I've feel I've been fairly meticulous doing the install to do things properly. But the car won't start.. it cranks, fires once and then dies immediately.
• Car is still jacked up at the front but that shouldn't matter.
• I moved the intercooler reservoir but that shouldn't matter.
• I installed my own closed catch-can setup on the PVC side only. That shouldn't matter.
• Got a B14A1 error code - Open in Solar Sensor Circuit for AC unit which appears to be a common non-issue
Any idea what might be the problem?
tzbang is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
