Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-22-2018, 08:56 PM | #1 |
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit?
correct me if i'm wrong, getting a flex fuel tune with the actual kit i have to drain the tank all the way down before switching fuel types, whereas with the kit i don't have to worry about that. is this correct? so is a flex fuel kit an must have if to get a flex fuel tune? if so, who sells them? i know delicious tune does, who else?
03-22-2018, 09:09 PM | #2 |
Flex fuel tunes require a flex fuel kit so that there is a sensor emitting the ethanol percentage of the fuel. The purpose is to allow you to run gasoline or E85 or any mixture of the two. If you want to run straight E85, you only need an E85 tune. You cannot mix gasoline and E85 with an E85 only tune.
03-22-2018, 09:11 PM | #3 | |
Drives: 2015 Steel FR-S
Sent from my SM-G925T using Tapatalk |
03-23-2018, 02:01 AM | #4 |
03-23-2018, 02:51 AM | #5 |
Drives: FT86
Sure will need flexxhardware and tune see here for morecinfo
http://www.ft86club.com/forums/showthread.php?t=120397 |
Similar Threads | ||||
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON | Enalband24 | Member's Car Journals | 78 | 02-04-2020 01:55 PM |
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Engine, Exhaust, Bolt-Ons | 9 | 01-15-2017 09:40 PM |
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune | tomaszjanczak | Engine, Exhaust, Transmission | 15 | 09-25-2016 11:06 PM |
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Audio/Visual, Electronics, Infotainment, NAV | 4 | 07-16-2016 06:43 PM |
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
