go_a_way1
Old 02-09-2020, 11:20 PM   #5293
ML
ML's Avatar
Drives: 13 White MT FR-S
has anymore used this A/C delete kit? https://www.ft86speedfactory.com/sub...l#.XkDXnGhKirw
I know some people have ran the Raceseng one successfully. Just not sure if the Subaru one uses the same size pulley as the ac?
Old 02-10-2020, 08:17 AM   #5294
peaches
Drives: '14 BRZ Limited
Originally Posted by steved View Post
The dual rad doesn't have enough cooling capacity for track work from my experience. I'm in the process of replacing it with a standalone oil cooler atm. But if you're really set on it, you can buy my dual
Second, if I don't run with the heater on full blast it'll overheat. Got a code a few weeks ago at Sebring... low voltage for the coolant sensor. So far I'm ok, but not taking that risk again. Need to get the dedicated cooler.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
wheelhaus (02-12-2020)
Old 02-18-2020, 10:17 AM   #5295
AndreC
Drives: Fast track beast
Was just going to ask about opinions on Ac delete kit as well. Car is being retired from street duty so need to pull the AC. It stopped working anyways, now it's just a heavy pulley holder.
AndreC is offline   Reply With Quote
Old 02-18-2020, 12:51 PM   #5296
ML
ML's Avatar
I ended up doing this because its free: https://www.ft86club.com/forums/show...&postcount=333
The Following User Says Thank You to ML For This Useful Post:
CSG Mike (02-18-2020)
Old 02-25-2020, 10:29 AM   #5297
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Hey everyone. I've piddled around the interwebs in search of answers and I seem to be finding mixed opinions. Question: what size fuel pump/injectors are IDEAL for running with the high boost pulley+e85? I see a lot of 700cc injectors being used, with some saying that's not enough. While I think 1000cc+ might be a bit overkill. Split the difference @900ish?
I currently have a 340/lph fuel pump on hand, I think that'll be sufficient, just looking for a confirmation on that.
Lastly, my tuner is 2 hours away, what would you do?: A) install it all at home and get a limp-to-tuner-tune, or B)drive to tuner, install everything there, tune.
(I should mention all parts to install: HBP, pump, injectors, FFkit)
Thanks in advance for your insights and recommendations!
ShawnP19 is offline   Reply With Quote
Old 02-25-2020, 11:19 AM   #5298
peaches
Install it at home, I'd hate to waste the tuner's time if something goes wrong with the install unless he is doing that for you. The pump is fine, injectors you won't find a definite answer. Some people swear they made 400s work and have no issues. Can they work? Yes, it's up to you to decide if you feel comfortable with that.
My tuner told me he had done 700s on a similar setup and they were maxed out, but that doesn't mean it won't work. Considering the price difference between 900 and 1200, I paid an extra $50 and got 1200s. Overkill? Yes, but I'm damn sure I won't run out of fuel.
ShawnP19 (02-25-2020)
Old 02-25-2020, 03:39 PM   #5299
I have two default choices.
DW700cc on a budget
ID1050X for a superior spray pattern.
PM me to order either
B. drive to tuner, install everything there.
mrg666 (02-29-2020), ShawnP19 (02-25-2020)
Old 02-25-2020, 04:31 PM   #5300
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
770’s are likely enough. You could look at people’s data logs to check their PI time, but I think if you do you will find the duration is good. I think Id1000 will be fine too. 1500+ and the duration is too short and the spray pattern is too much for off boost operation, according to some. Even with the DIs helping to manage everything, some seem to have idle and low speed issues. That is just what I have read.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 03-03-2020, 08:58 PM   #5301
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
I just reinstalled my jrsc after having the recall done and now it squeals under throttle. will this go away or should i just get a new belt?
Bones36 is offline   Reply With Quote
Old 03-04-2020, 06:10 PM   #5302
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Check your idlers to make sure the bearings are in good condition and check your belt. The belt will go 30-50k miles depending on environment and use, so it may be that time.
Jackson Racing is offline   Reply With Quote
The Following User Says Thank You to Jackson Racing For This Useful Post:
CSG Mike (03-05-2020)
Old 03-04-2020, 06:17 PM   #5303
Jackson Racing
Drives: JR FR-S,
We recommend our Track Oil Cooler Kit for track/race level oil cooling needs. The Dual Radiator/Oil Cooler is designed for street NA/FI and track NA applications.
Old 03-04-2020, 08:42 PM   #5304
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Interesting. I've running my Edelbrock + JRDR for awhile both track and drift and it keeps my temps under 240F for 20-30min sessions. Maybe I'm not fast enough lol.
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Old 03-05-2020, 09:48 AM   #5305
peaches
Once some funds free up I'll contact you to modify my setup.
Old 03-05-2020, 05:03 PM   #5306
Different system with different airflow requirements to stay cool, but Jackson Racing DROC is a very common recommendation I make for folks with an E-force that need/want more cooling.
Elliotw (03-05-2020)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
