Software Tuning Discuss all software tuning topics. |
07-21-2017, 11:19 PM | #29 | |
Drives: FT86
The Tables are under Timing compensation in romraider called Idle Target error range A and B Last edited by steve99; 07-23-2017 at 08:39 PM. |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | Strife26 (01-14-2018), Yoshoobaroo (07-22-2017) |
07-22-2017, 04:22 AM | #30 |
Drives: UK GT86
You've changed those? Any idea what that does? I thought you meant the actual large idle stability tables....
.: Stealth 86 :.
07-22-2017, 06:08 AM | #31 |
Drives: FT86
07-22-2017, 11:59 PM | #32 | ||
The Dictater
Drives: '13 Red Scion FRS
Disclaimer: I have not messed with this yet as I do not have any idle problems. The following suggestion is based on theory, but I cannot vouch for safety or functionality of the resulting tune. I haven't been doing this as long as some of the other folks on here. My guess is the OP is going to want to very gently increase the entries around the center top of the table. This should begin correcting the drop in RPMs more aggressively at a higher rpm. While I am here... Why are there so many 'idle speed target [letter]' tables? I have 9 of them and they are all different. |
07-23-2017, 07:08 PM | #33 | |
Drives: FT86
I think you have the wrong tables mate :-) They are under Ignition timing Compensation, not under the logical place you look, Idle control but both lots of tables will likely effect idle stability/compensation Theirs just so much going on at idle, so many compensations, and they are just the ones the ecu reverse engineers have found Last edited by steve99; 07-23-2017 at 07:19 PM. |
The Following User Says Thank You to steve99 For This Useful Post: | Spuds (07-23-2017) |
07-24-2017, 02:58 AM | #34 |
Drives: UK GT86
I use the ones @Spuds posted and not the ones you suggested as they're more logical IMO
.: Stealth 86 :.
07-24-2017, 07:54 PM | #35 |
Drives: FT86
The Following 3 Users Say Thank You to steve99 For This Useful Post: |
07-25-2017, 10:24 AM | #36 |
BRZ Wannabee
Drives: 2013 Limited BRZ
For me it's gotten better. It'll dip to 500 RPM sometimes but no longer to the point where the lights dim...either some of the tune changes I made worked, or the engine learned but either way it's no manageable. Your posts have all been very informative and it's interesting to see how many other people have had similar issues.
07-27-2017, 08:05 PM | #37 |
Drives: UK GT86
So I decided to have a play, I changed:
Idle stability (from MY17) Idle ignition timing (increased a little) Idle MAF Targets (increased a little) Ensured idle fuel was slightly rich (negative trims) Overrun tables (increase throttle at lower RPM to get close to Idle MAF Targets) Best idle yet....
.: Stealth 86 :.
07-28-2017, 02:26 PM | #38 |
BRZ Wannabee
I think the overrun tables might make the most difference for me, but it's gotten so much better now that it's barely noticeable any more haha
07-30-2017, 11:40 PM | #39 |
Drives: Toyota 86
Hi Steve,
Your idle stability tables are good for fixing stall issue just after flashing. Thx.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
01-11-2018, 11:24 PM | #40 |
BRZ Wannabee
Hey guys... I've been getting the dreaded p000b code recently. We had a cold spell down into the negatives recently, and I found that when I had to stop abruptly in traffic, the engine would start shuddering really hard. Either turning the car off then on, or giving it gas fixed the problem. Now when I get these ugly shudders at stop lights, a couple minutes later I get the p000b code and the car goes into limp mode. I reflashed the OFT Stage 2 tune today for the first time in many months, so maybe this helps? My factory warranty just ended yesterday
I'm probably going to have to put the stock header back on, reflash to stock, and drive it several hours back the dealership I bought it from. I called them up today and they seemed willing to work with me on it. This sucks so much a$$... |
01-11-2018, 11:26 PM | #41 |
BRZ Wannabee
Also I feel like if I could fix the idle issue when it dips low and starts shuddering, maybe I could tune out this problem? I don't have the idle overrun or the larger idle stability tables in my tune file. How can I put these in?
01-14-2018, 05:59 AM | #42 |
Drives: 2015 Subaru BRZ Series.blue
i have Gruppe-S UEL headers, and see this happen sometimes. It doesn't bug me as my car doesn't fully stall, and my car hasn't broke, but I do have the same issue and it is usually when I neutral stop in the neighborhood I'm in.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
Tags |
jdl, oft, romraider, rpms, stage 2 |
Similar Threads | ||||
Minimum 51% Ethanol | smg1138 | Software Tuning | 13 | 03-15-2016 04:44 PM |
Minimum HPDE Brake Pad Thickness | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 11 | 10-28-2014 10:26 PM |
Set a minimum post count to sell in Classified? | mav1178 | Site Announcements / Questions / Issues | 9 | 08-26-2013 07:25 PM |
The bare minimum? | Scaldy | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-11-2012 09:58 AM |
Minimum requirements... | Blokatos | Scion FR-S / Toyota 86 GT86 General Forum | 528 | 11-15-2011 04:04 PM |
