10-03-2018, 03:19 AM | #71 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
5w-30 huhhh, hmmmm . I may make that switch.
**Use Redline Water Wetter (in your coolant) , that is suppose to reduce coolant temperatures, only costs about $10-13 !!! Problem solved!
Math is like Love, simple idea at first that quickly gets complicated
10-03-2018, 09:56 AM | #72 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post: | Ultramaroon (10-03-2018) |
10-03-2018, 09:59 AM | #73 | |
I think WaterWetter does the opposite, actually....it facilitates the transfer of heat better because it's a surfactant, so the engine transfers MORE of it's heat to the coolant and to the radiator, ultimately keeping the motor cooler.
The Following 3 Users Say Thank You to venturaII For This Useful Post: |
10-03-2018, 04:56 PM | #74 | |
The Dictater
Drives: '13 Red Scion FRS
10-03-2018, 04:58 PM | #75 |
The Dictater
It might also transfer more heat out the radiator, thus keeping the coolant cooler upon measurement.
10-03-2018, 08:52 PM | #76 |
Sorry, I thought that was the goal of this thread. Not over heating the engine/ coolent, and running as cool as.possible ( coolent temp not under 180 F, but something in between 190-205 F, and if engine oil is bound to be hotter....say 220-250 F , but as engine temp increase oil can break down, so on and so fourth.). So if engine oil is 250 F, what good/ bad is that? Run hot, but not too hot. Track Oct.- April, but not during summer time....how about that?
10-05-2018, 03:07 PM | #77 | |
Drives: Nevermorange FRS
Did anyone catch this in the original post?
Our positive displacement oil pumps are essentially constant flow machines. Increasing viscosity of a fluid in a fixed system with a positive displacement pump, increases system resistance (pressure) but does not decrease flow unless there is unanticipated system leakage or in the case of our engines (and most), a pressure relief valve. Assuming the oiling system is operating at pressures below the point that fluid escapes past the PRV, then a change in viscosity will change pressure but not flow. With multi-viscosity oils you can also run a thicker oil without sacrificing startup wear. In short, a 0w-40 should produce the same protection at startup as a 0w-20 (because 0W) but at operating temp it will produce more pressure (because 40) and if the PRV isn't part of the equation, the flow will be more or less the same.
SCCA T4 - FRS
10-11-2018, 02:48 AM | #78 |
Thanks for pointing that out. I'm still putting together all the puzzle pieces, doing my best to make sense of it all.
So 0w-20 oil is the recommendation by Toyota. I see that definitely being good Fall thru Winter. So possibly a 0w-30 ( or 5w-30) in Spring thru Summer ? The two kickers of having a oil cooler for your engine: 1. initially watching for leaks, take care of them asap. 2. upon doing an oil change , making sure all the old oil is out of the system thru gravity . If the engine takes about 7.5 quarts of oil, not sure how much extra ( 1-2 quarts ? ) the oil cooler will hold upon doing a oil change. Its extra oil for the system, just making sure to drain it all is important. On the oil cooler situation, can anyone recommend a good system to go with ? I'm not up on brands and models, of what's what. Thanks in advance
10-11-2018, 02:54 AM | #79 | ||
6/22/12-2/6/24
And California temperature doesn't change enough to really consider changing oil weights.
The Following 2 Users Say Thank You to Bonburner For This Useful Post: | rice_classic (10-11-2018), Ultramaroon (10-11-2018) |
10-11-2018, 10:29 AM | #80 | |
Seriously?? I didn't look at the data sheets when making the change; I just assumed Mobil wasn't using some sort of marketing trickery in their ratings...crap. I might move away from Mobil1 entirely then...
The Following User Says Thank You to venturaII For This Useful Post: | Ultramaroon (10-11-2018) |
10-11-2018, 01:49 PM | #81 | |
Where I live, in winter it can get as cold as upper teens, to low 20's F. In the summer July-Sept, it can get as hot as 100-110 F ambient temps.
10-11-2018, 01:56 PM | #82 | ||
6/22/12-2/6/24
https://parts.subaru.com/p/Subaru_20...1311AA180.html https://parts.subaru.com/p/Subaru_20...1317AA070.html Pipes & clamps at your local hardware store. Do note that the coolant ports under the throttle body have slightly different sizes (one being a bit smaller) which is why I suggest grabbing clamps.
The Following User Says Thank You to Bonburner For This Useful Post: | atomicalex (06-10-2019) |
10-11-2018, 02:07 PM | #83 | |
The Following User Says Thank You to venturaII For This Useful Post: | Ultramaroon (10-12-2018) |
10-11-2018, 02:18 PM | #84 | |
Drives: Track preped NA FRS
Similar Threads | ||||
Head unit depth | bluenoserforever | Electronics | Audio | NAV | Infotainment | 0 | 07-25-2013 09:50 PM |
Depth Behind Radio Opening? | kmbkk | Electronics | Audio | NAV | Infotainment | 0 | 10-07-2012 11:21 PM |
Detailed In-Depth Tour of the BRZ | Subaruwrxfan | BRZ Photos, Videos, Wallpapers, Gallery Forum | 49 | 06-22-2012 05:38 PM |
Depth of speed | DIG1992 | Other Vehicles & General Automotive Discussions | 6 | 05-22-2012 01:13 PM |
AE86: An In-Depth Look at A Legend | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 01-26-2010 10:44 PM |
