04-06-2018, 09:43 AM | #127 | |
Drives: FRS
I'll definitely try to post a clip of revs and maybe drive-bys because I haven't read or seen anyone with this specific combination. |
04-06-2018, 10:28 AM | #128 |
Drives: 2014 Subaru Forester
Corsa designed the system with the rest of the exhaust left stock, so the no-drone tech is optimized for that specific setup. Since you are changing the head-back, I could see it being loud, even with the cats and resonator.
Different car and engine, but people with the Corsa system for the WRX report similar things. Everyone has different tolerances to noise. Hopefully it works out for you! |
04-06-2018, 10:37 AM | #129 | |
Wes
Instagram: @gt86ws
04-06-2018, 11:32 AM | #130 | |
Only users lose drugs.
Drives: All the time
Maybe because you, yourself, said it would be loud...?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
04-06-2018, 11:36 AM | #131 |
Drives: FRS
04-06-2018, 11:38 AM | #132 | |
Drives: 2014 Scion FRS (Red)
It is loud, but its not crazy loud. You will have drone for sure, but the car sounds raw. Its nice |
04-06-2018, 04:24 PM | #133 | |
I consider the Corsa to be decently loud even with the stock setup, but it's not unpleasant to me because the absence of drone/ most of the volume is not being pumped into the cabin. Do you have any videos of this setup? |
04-22-2018, 02:26 PM | #134 |
Drives: 2016 wr blue brz
I just did an 800 mile road trip from Portland to Astoria to crescent city back to Portland with an ft86 catted uel header, oft v3 stage 1 and corsa catback. It never gets obnoxious. Once you start cruising, the volume drops to a mild droan or no droan at all. Straight 8 hour days on highway 101 with stops at cool views. The only time volume comes in is on acceleration and never gets louder than the radio. It’s also a pleasant roar when accelerating. I will say that it can be brutally loud on cold starts when temps are i the 40s, but only for the 45secs it takes to cold start.
05-16-2018, 03:11 AM | #135 |
Drives: FRS
Quick update:
Finally got all the parts installed on my FRS. Have to fix a small exhaust leak but aside from that and a stripped bolt on the OEM over pipe the install went smoothly. Currently the car is nearly silent at idle and there is no drone at causing speeds. When you get on it it opens up and gets pretty loud. Subie rumble was really brought out by the UEL by JDL. After I fix the leak I'm going to tune it with the OFT 2.0 and try to get some video clips. |
The Following User Says Thank You to Alberto_HTX For This Useful Post: | tehShirt (05-16-2018) |
07-10-2018, 02:20 PM | #136 | |
Drives: 2017 BRZ LTD
07-10-2018, 08:10 PM | #137 |
Drives: 2017 Brz
might be a production error...mine just barely fit at that spot. there was about a 1mm hole to be seen at the slit of the joint, pushed it in really hard and it went just enough to not be able to see darkness in the slit...however that pulled back the muffler at an angle. also had to cut off about 1/4 in on passenger side muffler exit so the tip would actually fit in the exhaust cut out on the bumper.
The Following User Says Thank You to Aluma007 For This Useful Post: | andrewsbutt (07-11-2018) |
07-11-2018, 12:04 AM | #138 | |
07-11-2018, 02:42 PM | #139 |
Drives: 2017 Brz
yeah, i was a little disappointed for the money spent but its sound and looks make up for a little misalignment. all in all way better than invidia or others with single wall tips.
07-15-2018, 08:39 PM | #140 |
Drives: 2017 Brz
Anyone else get a nice BRAAAPPP on a 4k+ shift from 1st to 2nd?? It's quite addicting.
The Following User Says Thank You to Aluma007 For This Useful Post: | StraightOuttaCanadaEh (07-15-2018) |
Similar Threads | ||||
Corsa Exhaust-First released here @ JRP | Stav | Canada Classifieds | 85 | 01-24-2016 03:51 PM |
Corsa Cat-Back | ToyoburuBRZ | Engine, Exhaust, Transmission | 19 | 01-14-2014 09:58 PM |
We have the new Corsa FR-S/BRZ Exhaust Kits In Stock! - Hear them now! - Ships Free! | Anthony@RWHP | Engine, Exhaust, Bolt-Ons | 6 | 12-31-2013 08:56 AM |
CORSA 2.5" Catback Exhaust System 2013+ Scion FR-S & Subaru BRZ - FREE SHIPPING!! | YURparts | Engine, Exhaust, Bolt-Ons | 4 | 12-22-2013 05:58 PM |
FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
