Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-17-2018, 02:43 PM | #1 |
Drives: 2015 Aquamarine Scion FRS (Auto)
AT - 1st gear gets stuck and hits high RPM's before shifting
Hello Everyone. Long time lurker that finally registered. I have an Automatic 2015 Scion FR-S. I searched the forum and didn't come across this topic (or maybe my search skills suck).
There are times I'm driving and the car is in 1st gear and it doesn't shift into 2nd gear until I either a) release the accelerator a second or two then hit it again or b) it stays in first then shifts after a bit of time. While it's in 1st gear, the RPM's will be higher than normal. Just checking in to see if anyone else has/had this issue, how to fix it and if there is a TSB for it. Last edited by undone14; 05-17-2018 at 03:38 PM. |
05-18-2018, 11:05 PM | #2 |
Drives: 2022' GR86 Premium 6MT
The autos have always been a big interesting. Mind posting up a video showing more in detail? I know driving the car in just plan out "D" is weird. If i do recall the natural shifting patterns of the car made absolutely no sense lol. I just use paddles every time i drive to save a headache.
I'll do my best to pitch my $0.02 with a video. If I had any recommendations just mess around with your accelerator placement. See if it still does it when you lock the pedal at the same spot without moving it forcing the computer to decide the shift rather than letting on harder or softer.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
05-19-2018, 01:06 AM | #3 |
Drives: 2017 toyota 86
So you are bouncing off rev limiter or hitting fuel cut at 7400rpm in normal D and not in sport mode?
05-19-2018, 01:41 AM | #4 |
Drives: 2019 BMW ///M4
How high of an RPM are you hitting?
Sometimes my car stays in first gear until about 3500-4000 and then it shifts. This is in "D" mode, no aggressive driving. I have a 2013 FR-S and that's the only thing I experience regarding a gear getting "stuck". Never thought this was an issue?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
The Following User Says Thank You to N1rve For This Useful Post: | VoltsFRS2013 (05-21-2018) |
05-25-2018, 06:32 PM | #5 | |
Drives: BRZ Limited; GR86
05-26-2018, 02:32 PM | #6 | |
I had my TCM software updated and even had a famous post trying to help others get their stuff updated. When you changed TCMs did it just plug and play? Normally there's a relearn procedure
05-26-2018, 08:16 PM | #7 |
Since I had a 2013 the dealer kept on telling me that there was no update for my car. From reading the forums, i was unsure if the new update would cause issues with my tcm or if it was even compatible. I decided to buy an extra one with the same last 4 digits (b010). It was plug and play and very simple to do
05-27-2018, 11:23 PM | #8 | |
Similar Threads | ||||
Down shifting into 2nd gear when cold | Flame9020 | Issues | Warranty | Recalls / TSB | 27 | 12-22-2016 04:24 PM |
Gear shifting | TexasFRS | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 05-11-2016 10:29 PM |
Shifting at high RPM - Grinding | Magzter | Issues | Warranty | Recalls / TSB | 16 | 12-05-2014 01:24 PM |
Shifting from 1st-2nd gear... | FRSpappa | Engine, Exhaust, Transmission | 13 | 05-24-2014 10:06 PM |
High RPM Shifting Issue? | Rinzler | Issues | Warranty | Recalls / TSB | 5 | 05-17-2013 12:30 AM |
