Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-31-2024, 09:47 AM | #1 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
What style and color are you using for numbers?
Our local region recently published the schedule for the upcoming autocross season and this got me thinking about anything I'll need. I'm in pretty good shape for everything but my numbers.
My current white, magnetic, numbers are the only ones I've ever owned and were a quick purchase when I got tired of using tape years ago. They're cracked from use in the cold and falling apart. Time for something new. I'm looking at options running from a single rectangular panel, numbers with an outline in various combinations, or simple numbers in a choice of colors. Besides a touch of vanity and go with something with a touch of style, I still want the numbers to be highly visible on my WRB car for course workers. I've worked the course quite a bit and hated cars with low visibility numbers. So...what are you all using? Thought this would be a interesting conversation for the cold gray days before the season starts up again. |
01-31-2024, 12:26 PM | #2 |
Pawn in game of life
Drives: 19 STX BRZzz
I recommend to follow the SCCA marking guidelines. Many of the panel vendors have no idea what's legal, so make sure to point them to the rules.
Excerpt of the rules: D. Numbers and class letters should be positioned next to each other. All letters and numbers must be on body panels, not on windows. All numbers and class letters must use the same typeface and the same color, and this color must provide adequate contrast to the background color (see pic). E. Numbers must be a minimum of 8” (20.5 cm) high with a 1¼” (3.25 cm) stroke. Class letters must be a minimum of 4” (10.25 cm) high with a ¾” (2 cm) stroke. In all cases, the height of the class letters must be between 25% and 75% of the height of the numbers. Stroke width must be at least 10% of the height (see pic)
Autocross nut
01-31-2024, 01:57 PM | #3 |
Drives: '15 red FR-S SSC
You can use a magnetic sign kit for white panels and eight inch number stencils from any office supply store. Stencil numbers on adhesive backed vinyl for your numbers and apply to white panels.
01-31-2024, 09:39 PM | #4 |
2013 Series 10 FRS #553
02-01-2024, 12:19 AM | #5 |
Drives: '13 FRS - STX
I bought a set from autocrossdigits for the ‘21 or ‘22 season, very happy with them, I still use the bubble wrap envelope they shipped in to store them flat. With small businesses like these you can usually get something custom with an email or phone call.
I like having separate numbers because for autox being able to share a car and quickly flip numbers around is half the fun. I also autox with 3-6 different clubs in a given year so number flexibility is very useful. |
02-01-2024, 09:00 AM | #6 |
Spelling Impaired
Thanks for the links to some of the other vendors I'll have to look them up. I typically shop locally from SPS ( https://soloperformance.com/ ) since they are local, sponsors of our SCCA chapter, and the owners are good folks.
Fully aware of the size regulations which drives me to individual Numbers/letters, SPS will do the panels or meatballs exactly to spec, but the ordering is a bit more difficult. I like the idea of a panel due to the ease of use since I don't share my car. But as someone has already mentioned, having the flexibility to change numbers if needed goes right out the window if someone grabs your number before your register for an event. I've never had that problem, but you never know... As was pointed out in the comments already, contrast is the other biggie. With a WRB car, This isn't easy like black or white. I'm pretty much limited to white, yellow, neon green, or silver. |
02-01-2024, 10:22 AM | #7 |
Your options are more open if you commit to a contrasting black border.
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post: | strat61caster (02-07-2024) |
02-01-2024, 04:30 PM | #8 | |
Spelling Impaired
I really shouldn't worry about aesthetics and just get something basic, but it would be nice to have something a little different that looks good. If nothing else, looking at all the options have been an interesting diversion. |
02-02-2024, 10:20 AM | #9 |
The black border makes a huge difference on many cars. Diminishing returns as they get darker, but the sharp contrast is notable on pretty much any color car. If the numbers are on a panel, the car color becomes pretty much unimportant.
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post: | Desertnate (02-05-2024) |
02-04-2024, 02:08 PM | #10 |
Drives: '23 BRZ
I've been using i-Zoom Graphics (www.izoomgraphics.com) for several years now. I get "reusable vinyl" and it's great, totally reusable multiple times (at least 8 events with some care). The "Autocross Numbers" option gets you numbers and class letters. Reasonable $$, decent font and color options. Two thumbs-up:
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
02-04-2024, 09:47 PM | #11 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | ZDan (02-05-2024) |
02-05-2024, 09:58 AM | #12 |
Spelling Impaired
I like the magnetic as well. I've never had them fly off, but I've never used them at track speed either and the car only wears them at the events.
I've used mine across 4 years of events and they've held up pretty good. The only problem is they get pretty stiff in the cold which led to cracks when trying to get them off the car. I'll probably stick to magnetic because they are so easy to work with. Last edited by Desertnate; 02-05-2024 at 10:13 AM. |
Similar Threads | ||||
FS: Cusco Style Front Stut Bar w/ MCB -- custom color | vc86 | Brakes, Suspension, Chassis | 1 | 03-02-2017 05:23 PM |
**JDM Tom's Style Shark Antenna available in all color** | nigel-jdmparts | Exterior Parts - The Rest | 149 | 04-27-2015 12:42 PM |
BRZ/FRS VIS Carbon Fiber oem style hood and AMS style trunk. BNIB. | js0uth | Exterior Parts (Aero, Lighting, Etc.) | 76 | 12-03-2014 04:37 PM |
Looking for a Subaru BRZ in WRB Color for color-match. Will Compensate Roof Spoiler | Beat-Sonic | Southern California | 19 | 03-09-2014 07:31 PM |
Asphalt Grey Wheel Color and Style Idea | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 07-25-2012 11:20 PM |
