DIY (Do-It-Yourself) Guides For all DIYs. |
08-28-2013, 01:53 AM | #15 |
Drives: Scion FR-S 10 #853
I recently drove on some dusty dirt roads behind some other vehicles (for a long time), so I wanted to pull out my air filter to be sure it wasn't caked in dirt. It was surprisingly clean and so I wanted to make sure I put it back in right. Does anyone else see the white original filter along the edges? It looks to be sealed tight and the filter does have a pretty big edge around it that appears to be intended to squish in there to seal it up. I can't see how better to get it on honestly. (it's not upside down either) If I need to tear it out again I'll do it.
Top Bottom Sides Here's a picture of the stock one for those that haven't seen it yet. Note the thick border around it. |
The Following User Says Thank You to oldpueblo For This Useful Post: | chanomatik (03-18-2014) |
08-28-2013, 08:28 AM | #16 |
Drives: Asphalt FR-S
I'd try reseating it again if you're not 100% comfortable with it. There looks like a lot of bowing at the top. Worst case take it to the dealer and plead ignorance.
08-28-2013, 02:46 PM | #17 |
So I went back this time and took the entire thing out per the DYI above. That is basically as good as it gets, it's not designed to enclose and seal completely around the air filter perfectly, the edges of the air filter seem to be incorporated as part of the full seal or are at least too thick to fit in properly (hence the bowing).
10-03-2013, 11:23 PM | #18 | |
Drives: 2013 Raven FR-S
I'm assuming this is normal? My clamps fit really easy without any effort but I'm still kinda freaked because I can see part of the polyurethane peeking out... |
10-04-2013, 02:05 PM | #20 |
I've since switched to the Apexi drop-in and even it shows at the bottom on each side if I recall correctly. That's what made me realize ultimately that the borders are part of the seal design. Here I am with the Apexi, notice it's sealed the same all around (it has a black border, not white like the stock filter).
10-04-2013, 03:02 PM | #21 | |
How has your apexie been running for you btw, any problems with it |
10-04-2013, 04:43 PM | #22 | |
[ame="http://www.youtube.com/watch?v=Tzvx3ISlKus"]2013 Scion FR-S Intake: APEXi Dyno Test - YouTube[/ame] |
The Following User Says Thank You to oldpueblo For This Useful Post: | BeRZed (06-18-2015) |
10-05-2013, 04:23 PM | #23 |
Drives: Firestorm 86
Very nice write up
I took a look before I install my Perrin filter When I install the filter I notice there's a few mm sticking out on all sides but I can easily push it in. Makes me wonder if other people using the Perrin filter have the same extra border. I end up take out the whole box as precaution to make sure it seal properly before I reinstall so from the looks of it it was indeed seal properly then I just reinstall it and took it out for a spin. For the initial 3 miles test drive on the empty highway it does feel like it pull better from 5.5k - 7.2k on all gears. Thanks for a great write up |
10-05-2013, 10:26 PM | #24 | |
10-06-2013, 12:08 AM | #25 |
Drives: Raven FRS MT
It's like the made doing an oil change super easy but an air filter change a little harder to just to balance it out...
The Following User Says Thank You to jarviz For This Useful Post: | frsgal (04-02-2014) |
10-06-2013, 12:59 AM | #26 |
10-06-2013, 01:25 AM | #27 |
10-06-2013, 01:36 AM | #28 |
The way I see it no air goes through that border, it is part of the seal. So if you trim it allowing the plastic box to come closer together, hard plastic edges won't seal against each other. So I'm thinking that would make it have less of a seal.
Similar Threads | ||||
DIY Cabin Air Filter Inspection/Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 137 | 08-12-2023 06:32 PM |
Trd drop in filter | Vino | Engine, Exhaust, Bolt-Ons | 3 | 04-14-2013 11:08 AM |
FS: K&N Drop-in Filter | DookDookDGM | Engine, Exhaust, Bolt-Ons | 4 | 01-19-2013 01:45 AM |
Best drop-in replacement speakers | RYU | Electronics | Audio | NAV | Infotainment | 4 | 10-10-2012 02:15 AM |
Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
