09-28-2015, 03:22 PM | #169 | |
Drives: '13 Whiteout FR-S M/T
Sent from my SAMSUNG-SM-G850A using Tapatalk |
The Following User Says Thank You to kthxbai For This Useful Post: | tracerit (09-28-2015) |
09-28-2015, 03:25 PM | #170 |
Drives: '13 SSM BRZ Limited 6MT
Yeah I plan on staying NA. I was going for more intake growl rather than gains, I already have a Perrin resonated 2.5" catback.
09-28-2015, 03:34 PM | #171 |
Drives: 2014 Subaru BRZ
The 3" intake will sound the same as the normal size PERRIN intake. I'd go for the 3" if you already have a way to get a tune, and are looking to make the most power.
10-14-2015, 07:35 PM | #172 |
@PERRIN_Chris
I'm almost done with the install however I'm having issues with the air diverted and tube (3" version) not fitting. It's really tight and if I follow the instructions, I'm sure after a while, the plastic air diverter is going to somehow Crack. Any ideas? I feel like the air diverter needs to be trimmed to allow the intake in. EDIT: Ended up just cutting two 1" slits on the air diverter where the intake would sit so it'd smush down a bit further. Fits perfectly now. Flashed an updated tune with Perrin's MAF scale and took a stroll, wow, this thing is loud at 4k open throttle and very modest while just cruising. Liking what I'm seeing so far! Last edited by tracerit; 10-14-2015 at 11:58 PM. |
10-15-2015, 12:48 PM | #173 |
Just to be sure, did you use the included 2 metal spacers to push back the plastic diverter? They should push it back so you won't have any issues fitting the filter.
Good to hear that you got it on! |
10-15-2015, 02:46 PM | #174 |
I did but that didnt lower the top of the diverter enough . seems like an isolated incident since no one else has reported any complications haha. The instructions provided were quite easy otherwise.
10-15-2015, 02:57 PM | #175 |
That's interesting, if you could send me some pictures sometime, I'd like to see it. I installed the big MAF intake on my car and I didn't have to do anything to the diverter. Thanks!
10-15-2015, 03:16 PM | #176 | |
I pretty much made slits at the yellow lines below (picture taken from OP's post) so it'll be flap like and bend down a bit. |
10-19-2015, 11:30 AM | #177 |
Drives: '13 Whiteout FR-S (M/T)
@PERRIN_Chris and anyone else who has installed...is there suppose to be some contact between the filter and the diverter? I find the foam is pressed against the diverter even with the spacers...particularly near the middle-passenger side, right where the counter sunk part switches to the protruding part. Is this normal?
Photo below of contact area, stolen from @tracerit Also, how are we suppose to do the washers / bolt to attach the intake tube to the support? Right now I have it as bolt > large washer > bracket > small washer > support --> is this correct?
10-19-2015, 05:36 PM | #178 | |
yeah, i think mine is touching as well. That's how I did the washer/bolt order as well, no issues so far. Are you using the bigMAF or the regular CAI? How was your fitment with the tube through the radiator support and air diverter? |
10-19-2015, 05:41 PM | #179 |
@tracerit fit fine with mine but I'm on the 2.75 inch. I'm just curious if I can squeeze out more clearance between diverter and filter... How much foam compression are you getting at the diverter? Maybe half a cm or so?
Sent from my SM-N920W8 using Tapatalk
10-19-2015, 05:48 PM | #180 | |
10-19-2015, 05:55 PM | #181 |
@tracerit Yeah... I'm debating if I want to crack it open to check if I can move it... Theoretically answer should be no since it's a fixed bolt position but I messaged Jeff at Perrin and he mentioned there should be some wiggle.. I dunno
10-19-2015, 06:07 PM | #182 | |
Similar Threads | ||||
PERRIN Silicone Intake Duct Review | JoeBoxer | Engine, Exhaust, Transmission | 287 | 01-24-2018 10:01 PM |
Perrin Catback Exhaust Installation and Review! | Sony | Engine, Exhaust, Transmission | 316 | 01-24-2016 01:01 PM |
cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 12:56 PM |
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
