Software Tuning Discuss all software tuning topics. |
06-19-2018, 10:46 PM | #15 | |
Drives: 17 Series Yellow BRZ
06-19-2018, 10:53 PM | #16 |
Drives: 2017 Halo 86
lol I'm just joking.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
06-19-2018, 11:15 PM | #17 |
Ok. A properly scaled MAF isn't really going to add power. I guess it possibly could if the improper scaling is making the open loop portion run overly rich or overly lean, but I don't think the point is to add power. A properly scaled MAF should just make the car run better and be smoother overall. I noticed on one of my failed attempts I made it worse somehow and the car would feel a bit jerky when the trims would go from one end to the other. Meanwhile on my last attempt where my fuel trims are within +/-3 it feels much smoother overall.
06-19-2018, 11:32 PM | #18 | |
Yeah, I chickened out. Consulted Shiv for some feedback first before I do anything. I don't really know what I'm doing lol. But thankfully I don't have any of the noticeable symptoms of a poor MAF scaling as you described. Glad it worked out for you though.
06-20-2018, 03:13 AM | #19 | |
Drives: UK GT86
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Jasonb (06-20-2018) |
06-20-2018, 08:46 AM | #20 |
Your symptom is that your LTFT is in the double digits....
06-20-2018, 10:12 AM | #21 |
Ah, forgot to mention that those symptoms that could actually be felt while driving are gone completely. The visual LTFT symptoms are what remains to be fixed. Always happens to my car after re-flashing the ECU, it's most likely unrelated to the fuel trim issue and I probably shouldn't have mentioned it lol. It fixes itself after driving a few miles, as Shiv recommended via email.
06-20-2018, 11:04 AM | #22 |
Drives: 2014 GT86
Lakitu: maybe what you are experiencing is "dead pedal" problem, when after reflashing throttle pedal needs to learn it's travel, or LTFT fuel trims, which need to be learned driving a while in closed loop?
For dead pedal fix after flash turn key off, then to accessory mode, wait 30sec, turn key off, then to accessory, wait 30sec, turn key off, then turn engine on & let idle for 1 minute. |
06-20-2018, 06:18 PM | #23 |
Drives: UK GT86
Because the trims have adjusted so the fueling isn't totally off as they would be when the LTFT is 0 after a reflash. Poor driveability is due to not doing the pedal/throttle calibration and/or due to fueling error.
.: Stealth 86 :.
06-21-2018, 07:09 PM | #24 |
Well, I think I found the issue. The throttle body is open from the bottom at all times. Currently with the car off, I can push it closed from the top, but it just goes right back to open when I let go. From all the pictures of oem and aftermarket tb's, they are always completely closed. I hope there is a way to adjust this...
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact Last edited by Lakitu; 03-30-2019 at 07:55 PM. |
06-21-2018, 08:18 PM | #25 | |
06-21-2018, 08:28 PM | #26 |
06-21-2018, 10:17 PM | #27 | |
turn car on engine off ue something to hold accelerator pedal to floor full open. Throttle plate should be 100% open now clean any carbon/soot buildup of throttle plate and throttle body with cleaner Remove device holding accelerator full open. operate throttle a few times. turn car off and remove battery terminal for few minutes theis will reset ecu and force throttle learn. reconnect battery turn ignition on operate throttle a few times hopefully happy days. If not throttle body may have problem or throttle pedal sensor/actuator |
06-22-2018, 02:31 AM | #28 |
Get us another datalog after the intake modifications, your AFRS look fine so I don't think this is o2 or exhaust related but it would still be useful to use the high temp rtv around the exhaust. It seems intake related as when you go on the throttle it drops to -2.x
Similar Threads | ||||
Troubleshooting Idle | bfsnail | Forced Induction | 3 | 12-03-2016 05:05 PM |
BRZ DRL Troubleshooting | MaximaZero | Issues | Warranty | Recalls / TSB | 2 | 11-17-2015 03:31 AM |
Troubleshooting with a KW c38 | pgranberg11 | Forced Induction | 7 | 10-13-2015 07:05 AM |
Need troubleshooting help. | Camop82 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-14-2013 01:16 AM |
Start up troubleshooting. | Gost | Other Vehicles & General Automotive Discussions | 12 | 01-09-2011 05:45 PM |
