go_a_way1, Takumi788
Old 02-18-2019, 10:34 AM   #337
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Originally Posted by Takumi788 View Post
Sure thang. When you remove the bolts from the compressor unit the compressor splits apart in 3 pieces. Simply remove the 2 closest to the firewall and the parts that are inside. There is some nasty oil in the housing to be ready with some rags. There is a large e-clip that holds the pulley on. Don't remove that but remove everything else. Then bolt the part with the pulley back on the car in 2 front mounting locations. I have a feeling the pulley bearing may not last long like this since the back of it is exposed but this is what the Pirrelli World Challenge guys do and they told me they never had an issue. Hopefully this helps.
Here are some additional pics for more detail.
The front part of the compressor after dis-assembly - Back view
The front part of the compressor after dis-assembly - front view
The compressor housing bolts removed - compressor still assembled
End product
This is a cool free mod - I wonder how much weight is saved between this and the fluid. I know that the Raceseng AC Delete (discontinued, but still some out there) saves ~31lbs off your front end (not including fluids), but that's $400 (less if you manage to sell your compressor and condenser).
gkubed is offline   Reply With Quote
Old 02-18-2019, 11:34 AM   #338
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
No idea. If it wasn't for my accident I would have kept the AC until it stopped working. Unfortunately the accident punctured the condenser and I didn't want to spend the money to fix it. Most of the AC parts were surprisingly light.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-28-2019, 07:18 AM   #339
Takumi788
JHerbert Racing
Takumi788's Avatar
I had to replace the bent driver side control arm so I figured it was a good time to update the bushings with Whiteline's goodies. I am also replacing the inner tie rods because the driver side outer is seized onto the inner. Fun fun.
Installed
Even the packaging is top notch.
The Following User Says Thank You to Takumi788 For This Useful Post:
subielife (02-28-2019)
Old 03-24-2019, 04:23 PM   #340
Takumi788
JHerbert Racing
Takumi788's Avatar
I am pretty much ready for the track season other than waiting for a few parts to come in. And after watching some of Verus Engineering's work on the FT86 Speedfactory time attack car, I decided to take on sheet metal front air dams. The idea is to funnel the air into the cooling stack instead of the fender liners. My AC condenser was damaged in the accident so I used the threaded holes in the radiator to mount a custom oil cooler bracket. (see post 335 in this thread.) Then I built the air dams off of that. I also mounted them to the crash beam up top and plastic tray below. I have some foam coming in this week to block off the hole between the rad and the top radiator support along with a few other places.
I also have a fresh Verus front splitter coming in this week. 18 days left until Lime Rock!
Wrapped them in flat black vinyl
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
new2subaru (03-24-2019), subielife (03-25-2019)
Old 05-17-2019, 08:02 AM   #341
Takumi788
JHerbert Racing
Takumi788's Avatar
It has been a while.
I have already been to Lime Rock, Watkins Glen and NJMP since the last post. Headed to NYST this weekend. Here are a few pics to catch you up.
New tow rig: 2012 Silverado with zero options other than hd towing features. 5.3L 6 speed auto. (HD leaf springs, trans/oil cooler, tow mirrors, brake controller, 3.42 RG.) Got a killer deal on it. <3
Obligatory track pic from last weekend at NJMP - Just so happens to be taken at the corner where I binned it last year.
Most recent: Used set of 17x9 +35 Rays 57s w/ 235 RS4s tires. RR Racing front stage 2 & rear sport BBK. Got the wheels and BBK off of a friend about to trade his 86 in.
I may have a few other goodies coming this year but for now I will most likely just be posting pics from the track.
subielife (05-20-2019)
Old 05-17-2019, 08:12 AM   #342
Azzudien
Drives: 2017 Series Yellow BRZ
So jealous, I really need to find a decent tow rig. Car looks great.
I will be at NYST this weekend, I look forward to checking out your car. I will be the yellow BRZ.
Azzudien is offline   Reply With Quote
The Following User Says Thank You to Azzudien For This Useful Post:
Takumi788 (05-17-2019)
Old 05-17-2019, 08:17 AM   #343
Takumi788
JHerbert Racing
Takumi788's Avatar
Sweet! See you there! I love NYST
Not sure where you live in NY but check out North Coast Auto in Rochester. They are super cool guys and really hooked me up with my truck. They had a large selection on the lot when I picked mine up. - Not affiliated with them at all. Just a suggestion.
Old 05-17-2019, 09:19 AM   #344
aimforapex
aimforapex's Avatar
Drives: car
Coming back and looking amazing even more hardcore than before. love the new wheel setups and the black bumper looks very fitting.
aimforapex is offline   Reply With Quote
The Following User Says Thank You to aimforapex For This Useful Post:
Old 05-17-2019, 10:14 AM   #345
Takumi788
JHerbert Racing
Takumi788's Avatar
Thanks,
Paint and body work is for show cars. lol. I will have the rear quarter fixed and the car wrapped one day.
Old 07-12-2019, 01:06 PM   #346
Takumi788
JHerbert Racing
Takumi788's Avatar
Photo dump. I have been crazy busy at my day job and when I have a second I spend it working/coaching at a local track. Poor me right? lol. Enjoy.
Old 08-09-2019, 10:08 AM   #347
Takumi788
JHerbert Racing
Takumi788's Avatar
My work schedule is finally allowing me to get back to the track after a month and a half! Headed to Pocono with NASA Northeast this weekend and Palmer the 17th and 18th!
On a side note. All that overtime paid for a project I have wanted for a while. 1988 Nissan D21. As long as I don't crash the FRS again, this will be a winter project. I am hoping to get running and driving smoothly in time for an ice racing event or two this winter. Plans are to lower it, learn how to wrap a car with it (so I can wrap my FRS with some confidence) and SR20DET swap it eventually. She is ugly but she is clean clean.
subielife (09-11-2019)
Old 09-09-2019, 07:17 AM   #348
Takumi788
JHerbert Racing
Takumi788's Avatar
The "More track than street" FRS is now just all track. (sorry, the forum doesn't let me change the thread title.) Took her off the road last month which has allowed me the freedom to shed some additional weight. For starters I removed the remainder of the interior. (Center column, door cards, carpet.) Then I went a little further with the side windows/motors. I need the windows for transport so I made brackets to allow them to be removed at the track and re-installed on the trailer.
More lightweight mods to come.
Made a bracket to hold the traction control buttons out of the rear center console bracket.
Photo Dump:
Me and my brothers prelude at Pineview Run
Campsite at Pocono
Palmer fly by pic
Pineview Run
The Following 5 Users Say Thank You to Takumi788 For This Useful Post:
DarkSunrise (09-10-2019), jflogerzi (09-09-2019), ML (02-11-2020), Pat (09-09-2019), subielife (09-11-2019)
Old 09-10-2019, 07:04 AM   #349
Takumi788
JHerbert Racing
Takumi788's Avatar
Official weight reduction from the parts you see here plus the side window glass, carpet and hardware is 57 lbs! Not sure there is much left to remove. I want to keep the dash for convenience and heat for defrost.
jflogerzi (09-10-2019), SuperTom (03-10-2020)
Old 09-10-2019, 11:37 AM   #350
ML
ML's Avatar
Drives: 13 White MT FR-S
Its kinda crazy but we have almost the exact same build to a T. Do you have any plans to replace the glass with plastics?
Search this Thread:
Advanced Search
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
street + track oil question autobrz Tracking / Autocross / HPDE / Drifting 51 11-20-2013 11:32 AM
Street to track giraffee Australia Classifieds 1 10-31-2012 02:03 AM
Different pads for street and track Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-01-2012 02:55 PM
