Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-25-2017, 01:24 PM | #15 |
Drives: '13 FR-S
See OP. I started this thread :-) it's a really basic setup, but after shopping coilovers I realized anything I was really interested in was out of my budget this year.
04-25-2017, 01:25 PM | #16 |
Drives: '13 FR-S
Also, damn, you're detailed! I just sub'd your youtube channel. Can't wait to see more. I got lazy and stopped filming a couple of years ago. I love it when people make good ones though, i'll be watching!
The Following User Says Thank You to CatDaddysBBQ For This Useful Post: | Stang70Fastback (04-26-2017) |
04-25-2017, 02:45 PM | #17 |
A 20mm front swaybar and a 16mm rear is IMO a good set-up without too much of that "big bar" feeling. Might even try just the front.
- andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | CatDaddysBBQ (04-25-2017), strat61caster (04-25-2017) |
04-25-2017, 09:32 PM | #18 |
Ive had my Tarmac springs for about 61k miles. For 99.9999993% daily driving and the rest auto x.
I'd for sure recommend a bigger front bar and leave the rear bar alone. So many options to choose from: Suspension Techniques (ST) 19mm Everybody: 20mm (arguably the best) Progress: 20.5mm Blox/agency power: 21mm I've been rocking a 22mm front for the same 3 years and while I thought the 22/14 setup was the bees kneez, I feel I've been missing out on rotation ability for a long time. |
The Following User Says Thank You to norcalpb For This Useful Post: | strat61caster (04-25-2017) |
04-26-2017, 12:06 PM | #19 |
Drives: '13 FR-S
I'm a bit worried about further dialing out oversteer. I'm enjoying getting better at autoX and building the car to be better too, but i'm not yet to the place where i need it to be as competitive as possible, and I want the car to still feel playful. As my only car, it's a balance. Someday it won't be my DD and i'll make it more focused, but for now I like the tail a bit happy!
04-26-2017, 12:14 PM | #20 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
Plus it's fun when you're going balls out, and you look more badass, when you're slightly drifting with some decent slip angle, as opposed to plowing wide with understeer. Makes for better photos, too. Lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
The Following User Says Thank You to Stang70Fastback For This Useful Post: | CatDaddysBBQ (04-26-2017) |
04-26-2017, 01:14 PM | #21 | |
Drives: '13 FRS - STX
Do you have camber bolts+plates and rear LCA's yet? If not, camber up front can unlock a lot more grip when you get up and over -2.5 degrees imo, if you leave the rears at the factory -1.5 or so it should keep the car very playful. I ran my car totally OE except for camber bolts+plates up front for a few months and when I got it just right it felt straight up magic. That's kind of why I'm a bit excited about this setup, seems like exactly like what I want, a little lower, a little stiffer, great damping, full alignment, and swaybars to tune past that and done. |
04-26-2017, 01:15 PM | #22 |
Drives: '13 FR-S
100% agree. It's more fun, and while wheelspin technically is slower, when you're cooking a TAD but the car rotated it doesn't feel like you lost any time. Like a nice slightly squeaking <5 degree powerslide seems pretty darn quick. (and looks/feels amazing).
04-26-2017, 01:27 PM | #23 | |
A.K.A. Starlord
Keep in mind that you can do a lot with tire pressures too to fine-tune the balance of the car at an autocross event. Even a 1-2 PSI change in the rear pressures can make a noticeable difference in how tail-happy the car is.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | CatDaddysBBQ (04-26-2017), strat61caster (04-26-2017) |
04-26-2017, 01:29 PM | #24 |
Drives: '13 FR-S
Good call.
I have had SPC front bolts for a few years, and recently dabbled in rear LCAs but went back to stock for this very reason. The lowering gave me a little neg camber in the rear but I wanted to keep it a bit more vertical so it didn't have TOO much grip. Before the springs, the front was roughly -1.6/7 and now i'd say it's closer to -2 or maybe a bit more. SO it's definitely has more camber up front, and that's fine with me for now. |
04-26-2017, 01:32 PM | #25 |
Drives: 2013 Raven FR-S
You guys don't find that setup to be too tail happy? I had a 20mm front and 16mm rear swaybar setup a while back and found it made the back a bit loose for my taste. Now I'm using a 22mm Strano bar up front and the stock bar in rear and it feels really well balanced. I'm on RCE T2's, so the even spring rates front and back may make the difference.
04-26-2017, 02:36 PM | #26 | |
- Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
04-26-2017, 03:02 PM | #27 |
I forgot to mention the 22mm Strano bar is tubular, not solid. I'm sure you guys know that, but some people may not. Just wanted to avoid any confusion.
The Following User Says Thank You to smg1138 For This Useful Post: | Racecomp Engineering (04-26-2017) |
04-26-2017, 03:10 PM | #28 |
Drives: '13 FR-S
Absolutely. If I get to the point where i'm trying to compete at solo nationals, I may change my tune but for now I like a little slip and slide at the limit.
The Following User Says Thank You to CatDaddysBBQ For This Useful Post: | Racecomp Engineering (04-26-2017) |
Similar Threads | ||||
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 589 | 11-21-2021 04:13 PM |
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 208 | 09-30-2016 03:43 PM |
rce tarmac 0 or 2 ? | FISHBURGLAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-06-2015 11:58 AM |
Tarmac r40 | ikeryder13 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-19-2014 06:13 PM |
